    • Search
    mykle1 / MMM-EARTH-Live
    Entertainment
    • N6NG
      N6NG last edited by
      I’ve installed the above module which installed without a flaw. It does run ok but it stops after about an hour. I saw the line that needed to be install to take:
      “let mainWindow;
      function createWindow() {
      app.commandLine.appendSwitch(‘autoplay-policy’, ‘no-user-gesture-required’); //< -------- added”
      Which I added but it still stops after about an hour. Did anyone else run into this problem?
      Thanks all What a great and knowledgeable group.
      Dennis
      S cowboysdude 2 Replies Last reply Reply Quote 0
        sdetweil @N6NG last edited by
        @N6NG that line is already handled in the last 4 releases…
        don’t know why it stops
        did u look in the dev window for errors
        and in the console log (pm2 logs --lines=50)
        • cowboysdude
          cowboysdude Module Developer @N6NG last edited by cowboysdude
          @N6NG You gotta read the repo. 🧑🏼
          During "loss of signal" periods, viewers will see a blue screen. Since the station orbits the Earth once every 90 minutes, it experiences a sunrise or a sunset about every 45 minutes. When the station is in darkness, external camera video may appear black, but can sometimes provide spectacular views of lightning or city lights below.
          N6NG 1 Reply Last reply Reply Quote 1
          • N6NG
            N6NG @cowboysdude last edited by
            @cowboysdude Yes Cowboydude… Thanks for the reply. I do know about the dark sessions but this is where it stops and the only way to start it again is to click on the triangle in the circle in the center of the image…
            But it does start again for another hour or so… Can’t narrow it down to anything more specific…
            Dennis
