    MMM-CalendarExt3
    679 Posts 82 Posters 2.7m Views 86 Watching
      sdetweil @Wenike
      @Wenike your transformer is only doing style change,
      he wants to change the class , so his transformer is ok
        MMRIZE @chadjohn2
        @chadjohn2
        There were several issues on your code.
        1. You didn’t return event object in your eventTransformer function.
        2. CSS(Cascading Style Sheets) has a Speciality to determine the priority of the definitions by calculation.
          Your .CX3 .Daycare is lower than default .CX3 .event.fullday or .CX3 .event.multiday. So in case of your event is fullday/multiday thing, your color definition would be ignored.
          .CX3 .event.Daycare or .CX3 .event.Daycare.fullday, .CX3 .event.Daycare.multiday would work.
          DDE12
          How do I reference the specific instances of CExt3? Like on different carousel pages, where I would have a month mode on one page and a week mode on another. I have this config:
                      broadcastPastEvents: true,
                      maximumNumberOfDays: 300,
                          instanceId: "FamilyCal",
                          fade: false,
                          colored: true,
                          displaySymbol: false,
          		        url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
                                  color: "rgb(240,175,20)"
                                  url: "https://private.calendar.com",
                                  color: "rgb(60,250,60)"
                                  color: "rgb(250,40,150)"
                                  color: "rgb(180,40,250)"
                    module: "MMM-CalendarExt3",
                    position: "fullscreen_above",
                    title: "",
                          mode: "month",
                          instanceId: "FamilyMonth",
                          calendarSet: ['Holidays', 'Dad', 'Mom', 'Child'],
                          maxEventLines: 5,
                          firstDayOfWeek: 0,
                          minimalDaysOfNewYear: 1,
                          eventHeight: '18px',
                          useSymbol: false
                      title: "",
                          mode: "week",
                          instanceId: "FamilyWeek",
                          weekIndex: -1,
                          weeksInView: 5,
                          maxEventLines: 5,
                          firstDayOfWeek: 0,
                          useSymbol: false
            sdetweil @DDE12
            @DDE12 for each module you can ADD classes strings , by using the classes:“…”
            property after the
            module:“… name”
            then in pages you can use that name instead of the module name
            I prefer to configure pages differently
            in pages its
                    [  'page1'],
                    [  'page2' ]
            then for the modules u want on page1
            you add
              classes:'page1',
            and for modules on page2
               classes:'page2'
            you can do the same for fixed, etc
              DDE12 @sdetweil
              Thank you for looking at this. Is this the proper implementation for your suggestion?
              modules:  [
                 ['MonthPage'],
                 ['WeeksPage']
                        classes: 'MonthPage',
                                   mode: "month",
                        classes: 'WeeksPage'
                                   mode: "week",
                        module: "MMM-Carousel",
                                      mode: 'slides',
                                      slides: {
                                                 "Slide 2": ['MonthPage'],
                                                 "Slide 3": ['WeeksPage']
                sdetweil @DDE12
                @DDE12 no, I was giving you the config for the MMM-Pages module.
                I don’t use Carousel, so not sure there
                  DDE12 @sdetweil
                  Like so…?
                  modules:  [
                                       mode: "month",
                                       mode: "week",
                              module: 'MMM-pages',
                                                              ['MonthPage'],
                                                              ['WeeksPage']
                    sdetweil @DDE12
                    @DDE12 yes
                    I would label the pages ( in pages config)
                    page1
                    page2
                    cause that is the order they are shown.
                    you can have as many modules on a page as u want and can fit of course.
                      DDE12 @sdetweil
                      Yeah, that would definitely be less confusing. Do I have the classes: “FamilyWeek” and classes: “FamilyMonth” in the right place in the CalenderExt3 config(s)?
                        sdetweil @DDE12
                        @DDE12 either can be used in css to select elements to style
                        • 16
                        • 17
                        • 18
                        • 19
                        • 20
                        • 67
                        • 68
                        • 18 / 68
