    MMM-CalendarExt3
    679 Posts 82 Posters 2.7m Views 86 Watching
    • K Offline
      katalopapi @sdetweil
      @sdetweil Thanks for the info:
      “u can setup the default calendar and not give it a position, but have it broadcast events”
      I assume you are saying I can display the family calendar using the default calendar module, is that correct? If so, do you have a pointer to start me in the right direction? I don’t see an ICAL associated with the google family calendar. I thought I needed mmm-googleCalendar for that.
      “I don’t know if mmm-googlecalendar does the broadcast”
      From the CX3 github readme:
      Compatible with randomBrainstormer/MMM-GoogleCalendar
      eventTransformer: (e) => {
      e.startDate = new Date(e.start?.date || e.start?.dateTime).valueOf()
      e.endDate = new Date(e.end?.date || e.end?.dateTime).valueOf()
      e.title = e.summary
      e.fulldayEvent = (e.start?.date) ? true : false
      return e
      Do I need to add the eventTransformer code to get it to add the googleCalendar events?
        MMRIZE @katalopapi
        @katalopapi
        There is some tip explanation on readme doc to use with google-calendar module.
        • K Offline
          katalopapi
          @MMRIZE Do you have any example config you could share for using mmm-googleCalendar?
            sdetweil @katalopapi
            @katalopapi googlecalendar doc says broadcastEvents:true
              MMRIZE @katalopapi
              @katalopapi
              We both posted at same time, so your previous post was right.
              • K Offline
                katalopapi @MMRIZE
                @MMRIZE I’m getting the following error:
                I assume I’m doing something wrong with the transformer since it seems to be an issue with startDate. Here’s my config:
                FYI
                I had to manually update MMM-GoogleCalendar.js to enable broadcastEvents. I couldn’t seem to enable via the config.js (perhaps I did something wrong).
                Any ideas regarding the error? TIA
                  @katalopapi all you had to do was add
                  broadcastEvents: true,
                  inside the module config: {}
                  section
                  as it is a module parameter and not a MagicMirror parameter (like position, disabled or classes)
                  • K Offline
                    @sdetweil Thanks! I had it before the config. Works after moving it.
                    • K Offline
                      katalopapi
                      I’ve figured out what was causing the error. The US holiday events didn’t have the same fields as the google calendar so the transformer was messing those event us. I’ve fixed it with the following transformer:
                        agrusap
                        I’m on my phone sorry if this is messed up. I’m getting this error trying to use ext3 and cannot find an answer. I’m sure it’s something easy but…
                        Config is same as example given.
                        I don’t know how to post pictures so hope this helps
                        In dev window
                        Uncaught SyntaxError: unexpected token ? (Right side)
                        :8080/modules/MMM-calendarext3/MMM-calendarext3.js:54
                        • 19
                        • 20
                        • 21
                        • 22
                        • 23
                        • 67
                        • 68
                        • 21 / 68
