    Getting module's URL from node_helper before socket connected
    Scheduled Pinned Locked Moved Unsolved Feature Requests
    8 Posts 4 Posters 2.2k Views 4 Watching
    • M
      MMRIZE
      Is there any convenient way to get the related/launched MM module’s basic URL from node_helper?
      In the module itself, it has .file() can be used. But in node_helper, there is no equivalent. .path would return the local path for the module, not the URL.
      Of course, I might be able to calculate or assume the URL from the path and name, but that way looks not so elegant. Default core modules will have .../modules/default/moduleName but 3rd party would have .../modules/moduleName, I need to distinguish the cases.
      Or the module could send that info to node_helper through socketNotification. But I need that URL in the early initializing stage even when the socket is not connected yet.
      .file() or .url() method of node_helper would be helpful for me.
      S karsten13K 2 Replies Last reply
        sdetweil @MMRIZE
        @MMRIZE why do u need the url before socket connected.
        nothing ‘needs’ to be done before then. the helpers JOB is to service the module. if it needs config info, then it can’t start is job til notification w that info.
        as u wait for the calendar broadcast, your module has eons of time waiting.
          @MMRIZE also, u know that mm’s web server is routed at ~/MagicMirror
          so __dirname with give u path to this file, strip of everything before /modules
          back up one folder from this modules location and u know the root of where modules are located (mroot)
          and mroot/default/defaultmodules.js
          will give u the list of modules in defaults(that don’t use explicit name ‘default/modulename’)
          • karsten13K
            karsten13 @MMRIZE
            @MMRIZE
            AFAIS not really …
            You could iterate over the modules in the config.js doing something like this in the init() of your node_helper:
                const configFilename = path.resolve(
                  global.configuration_file || `${global.root_path}/config/config.js`
                let config;
                try {
                  fs.accessSync(configFilename, fs.F_OK);
                  const c = require(configFilename);
                  config = Object.assign(c);
                } catch (e) {
                  Log.error(name + ": Couldn't read config.js");
                  return;
                let modules = [];
                for (const module of config.modules) {
                  if (
                    !modules.includes(module.module) &&
                    !module.disabled
                  console.dir(module.module);
            So you have the names and for knowing what are default modules you could use modules/default/defaultmodules.js
              sdetweil @karsten13
              @karsten13 wow!!!.. i didn’t think config was available to node_helper…
              cowboysdudeC 1 Reply Last reply
              • cowboysdudeC
                cowboysdude Module Developer @sdetweil
                @sdetweil Yes I send my config to node_helper in my weather module :)
                  sdetweil @cowboysdude
                  @cowboysdude said in Getting module's URL from node_helper before socket connected:
                  but that is not the topic
                  without doing ANYTHING
                  in the node_helper
                  config points to the TOTAL config/config.js
                  ALL modules and ALL (config.js) parms to ALL modules…
                  this is NOT the merged with defaults view that you would send…
                  • M
                    MMRIZE
                    Assuming URL with PATH might be an almost general solution, but Sometimes, People install modules in weird ways like using Symlink. (That way could have some benefit, anyway, this is out of issues) In that case, assuming is somehow picky.
                    My purpose is to rewrite the Translator class to use in Module and node_helper together with one common class. (So that is the reason why pre-connection is needed.)To access translations in both layers, there could be many ways to achieve. However, if the exact URL could be obtained in the background layer, it would be easier and simpler and with the least dependency. (To work on browser and on nodejs layer together)
                    Of course, there could be many alternative approaches. I’m just curious if there could be a better way.
