    MMM-WOTD
    Scheduled Pinned Locked Moved Education
    16 Posts 7 Posters 4.9k Views 8 Watching
    • mumblebajM Offline
      mumblebaj Module Developer
      Hi Folks.
      I created what some would call, YET Another Word of the Day module. :-)
      The module has an option to either get Spanish or Portuguese Word of the Day. Other languages can possibly be added at a later stage on request and if I can find a page out there for it.
      I am stuck between just showing the single selected language for now and maybe building a table to display multiple language WOTD with examples. I am open to suggestions on this. (Please raise them on github)
      Check out the github page for it.
      https://github.com/mumblebaj/MMM-WOTD
      Spanish WOTD
      Portuguese WOTD
      Enjoy!!
      Updates:
      V1.1.0
      • Updated module to pull information from new elements as the sites used has changed.
      • Do git pull && npm install in the module folder.
      cowboysdudeC NiggichN 2 Replies Last reply Reply Quote 2
      • cowboysdudeC Offline
        cowboysdude Module Developer @mumblebaj
        @mumblebaj Looks great!!!
          mdefrancesco
          this is one of my favorite modules. i do have a question.
          i increased the font size of the header but cant figure out how to increase the distance between the header and the divider bar underneath
          am i missing something simple?
            sdetweil @mdefrancesco
            @mdefrancesco see https://www2.lawrence.edu/fast/GREGGJ/CMSC106/lectures/CSS/Boxes.html#:~:text=To create extra space between,extra space around the element.
            also see https://forum.magicmirror.builders/post/90135
            to learn how to use the developers window elements tab to test out your css changes live, without change, restart/reload, repeat…
            • E Offline
              ehjaysea
              @mumblebaj said in MMM-WOTD:
              Great work, thank you! FYI, for some strange reason as of right now the URL for english is throwing a 404, easily verified by going to https://www.englishpod101.com/english-phrases/
              mumblebajM 2 Replies Last reply Reply Quote 0
                mumblebaj Module Developer @ehjaysea
                @ehjaysea Hi. Seems like EnglishPod has now changed. The other languages seem to still be working, for now. Will start looking around for new sources.
                  @ehjaysea I have pushed a change and English should now work again. Please do a git pull && npm install in the module folder. Everything should work again.
                  • E Offline
                    ehjaysea @mumblebaj
                    @mumblebaj Wonderful, thank you! Working again :clapping_hands:
                    • NiggichN Offline
                      Niggich @mumblebaj
                      Hey @mumblebaj,
                      looks nice, but I couldn’t get it working. I install all the Dependencies, but it doesn’t work. Is the module not working with more pages and server mode?
                        mumblebaj Module Developer @Niggich
                        @Niggich said in MMM-WOTD:
                        Not sure I understand the above.
                        The module works fine, works with MMM-pages and in Container (server only mode) I have tested this.
                        Can you check in the logs if you see any errors in the logs and advise?
                        NiggichN 1 Reply Last reply Reply Quote 0
                        • NiggichN Offline
                          Niggich @mumblebaj
                          @mumblebaj Ok, this is what I mean. You said it is working with MMM-pages an server only mode. So, I’ve checked the Logs, but there are no errors.
                          I will try the module with my other Mirror Server. Maybe it’s something wrong with this server… Thanks.
                          S mumblebajM 2 Replies Last reply Reply Quote 0
                            sdetweil @Niggich
                            @Niggich All the UI is done at the client. modules tell MM that there is data to show, MM gets it and shows it
                            all the pages are done at the client. (pages/carousel/…) only cause a modules content to be hidden or shown.
                            the server helps modules collect data and send it to the clients.
                            • NiggichN Offline
                              Niggich @sdetweil
                              @sdetweil Okay, thanks. I learned something new.
                                @Niggich Have you also check for any errors in the Dev console (shift + ctrl + i)
                                • NiggichN Offline
                                  Niggich @mumblebaj
                                  @mumblebaj No, I don’t. I tried again and now it is working, but I don’t know why?! I’m not sure I think I made a mistake the first time I installed it.
                                  Thank you for your help!
                                  mumblebajM 1 Reply Last reply Reply Quote 1
                                    @Niggich Glad it is working for you now.
