    Struggling with Weather... module
    34 Posts 5 Posters 17.4k Views 6 Watching
      D3dl3g @sdetweil
      @sdetweil,
      apiBase commented out in config.
      server restart, and browser log request, showing loaded weather modules
      i still have “loading” in module location
      looking at source gives me the impression that i need to go and look at 2 more .js files. Previously i have been working with /default/weather/ukmetofficedatahub.js and /MagicMirror/config/config.js
      ill see if thes hold any info:
      /root/MagicMirror/modules/default/weather/weatherproviders.js
      (Edit: //weather provider properties: null, modified to:
      8bca5c6c-09d9-4987-8940-0233b5e827c7-image.png )
      /root/MagicMirror/modules/default/weather/weather.js
      (Edit: this file is set to “openweathermap”, changing to “ukmetofficedatahub”
      a2763dbe-9a57-47bc-b036-505bd38e8e4e-image.png )
      server restart, no effect noted :(
        D3dl3g
        @Kayababe @sdetweil
        openweathermap works… albiet the location its suggested is 3 miles down the road. (ukmetoffice has data for 2 streets away)
          sdetweil @D3dl3g
          @D3dl3g you ONLY setup from config.js
          please try with NO apibase set
            D3dl3g @sdetweil
            weather.js and weatherprovider.js i have set back to defaults.
            i have set config.js as requested
              weatherProvider: 'ukmetofficedatahub',
              lat: "52.###############",
              long: "-1.###############",
            //apiBase: 'https://api-metoffice.apiconnect.ibmcloud.com/v0/forecasts/point/daily/',
              apiKey: 'e52#############################',
              apiSecret: 'd3a#############################',
            the result:-
              sdetweil @D3dl3g
              @D3dl3g send me your API key… config from config.js via email or direct message so I can debug
              did u look in the browser messages?
              my email is my same userid at gmail
                D3dl3g
                Just to update the forum, as to what happened behind closed doors
                Sam kindly tested my code, and it worked for him.
                I am recieving browser errors (previously requested but i wasnt looking in the right bit of the browser window)… he is not
                Issues Tab
                Console Tab
                the last 5 entries here will reoccur, im guessing at every “retry” for weather info
                attempted to use useCorsProxy: true to no avail
                Sam kindly posted into git hub issues.
                https://github.com/MichMich/MagicMirror/issues/271
                • karsten13K Offline
                  karsten13 @D3dl3g
                  tested ukmetofficehub and it works out of the box (without setting the useCorsProxy flag).
                  Looking into the provided config
                  which is messed up. It has to be:
                    lat: 52.###############,
                    lon: -1.###############,
                    sdetweil @karsten13
                    @karsten13 I tested w those in quotes, and it worked ok
                      karsten13 @sdetweil
                      did only test without, but there is another error lon vs. long …
                      S D 3 Replies Last reply Reply Quote 0
                        sdetweil @karsten13
                        @karsten13 I just copy pasted and it worked.
                        weird
                          D3dl3g @karsten13
                          @karsten13
                          i too am getting this… showing me some 80+miles SEE of my actual location
                            D3dl3g @karsten13
                            @karsten13
                            also… replace the hash symbols with various numbers… im not posting my exact Lat/Long for obvious reasons…
                            make sure ur doing
                            lat:
                            and
                            lon:
                            i had it set to lat & lon(G) which is incorrect. hence why it was 80+miles, way tf over there!
                            quote marks or none surronding the numbers doesnt appear to matter, for me at least
                              D3dl3g
                              This “issue” is fixed.
                              Advised by Sam, I ran these 2 commands to find modified files that differ from a “clean install/default” of MM.
                              git status
                              git diff
                              Any that varied… I ran:
                              git checkout <dir-tree>/file.extension
                              Rebuilt my config.js and found that apiBase HAS to be commented out.
                              On reflection DO NOT CHANGE ANY FILE aside from “config.js”
                              I had 3 causes for this issue.
                              • (edit) i had longitude set in config.js to “long:”… it should be “lon:” and the lat/lon do not have to be surrounded by any quote marks.
                              • I’d modified other *.js files, that didn’t need to be modified.
                              • the “apiBase” argument listed in (MagicMirror Documentation > Modules > Weather Module > Configuration Options) was, in my case, not “REQUIRED”.
                              @sdetweil … Sam, publically, I cant thank you enough for your help with this. Sorry for being a n00b, your insight and help was invaluable, and you taught me some stuff, which is great!!
                              S 1 Reply Last reply Reply Quote 2
                                sdetweil @D3dl3g
                                @D3dl3g glad u got it working. we are all noobs at some of this stuff…
