    v2.20.0
    Scheduled Pinned Locked Moved MagicMirror
    1 Posts 1 Posters 17.6k Views 5 Watching
    • MichMichM Offline
      MichMich
      [2.20.0] - 2022-07-02
      https://github.com/MichMich/MagicMirror/releases/tag/v2.20.0
      Special thanks to the following contributors: @eouia, @khassel, @kolbyjack, @KristjanESPERANTO, @nathannaveen, @naveensrinivasan, @rejas, @rohitdharavath and @sdetweil.
      Added
      • Added a new config option httpHeaders used by helmet (see https://helmetjs.github.io/). You can now set own httpHeaders which will override the defaults in js/defauls.js which is useful e.g. if you want to embed MagicMirror into annother website (solves #2847).
      • Show endDate for calendar events when dateHeader is enabled and showEnd is set to true (#2192).
      • Added the notification emitting from the weather module on infromation updated.
      • Use recommended file extention for YAML files (#2864).
      Updated
      • Use latest node 18 when running tests on github actions.
      • Update electron to v19 and other dependencies.
      • Use internal fetch function of node instead external node-fetch library if used node version >= v18.
      • Include duplicate events in broadcasts.
      Fixed
      • Fix problems with non latin fonds caused by updating to fontsource (fixes #2835).
      • MichMichM MichMich locked this topic on
