    sample config and clock
    7 Posts 2 Posters 6.0k Views 2 Watching
    • E Offline
      emos
      Hello, I came a cross a topic on this forum saying that all you need to remove the second from the clock is
      displaySeconds: false,
      I stared out with the sample.config, added the info for seconds. When i start up the mirror now it just says i need to create a config. wtf?
      This is the full config
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
              port: 8080,
              ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120"],
              language: 'nb',
              timeFormat: 24,
              units: 'metric',
                              module: 'alert',
                              module: "updatenotification",
                              position: "top_bar"
                              module: 'clock',
                              position: 'top_left'
                              module: 'calendar',
                              header: 'US Holidays',
                              position: 'top_left',
                                                      symbol: 'calendar-check-o ',
                                                      url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics'
                              module: 'compliments',
                              position: 'lower_third'
                              module: 'currentweather',
                              position: 'top_right',
                                      locationID: '',  //ID from http://www.openweathermap.org
                                      appid: 'YOUR_OPENWEATHER_API_KEY'
                              module: 'weatherforecast',
                              header: 'Weather Forecast',
                                      locationID: '5128581',  //ID from http://www.openweathermap.org
                              module: 'newsfeed',
                              position: 'bottom_bar',
                                      feeds: [
                                                      title: "New York Times",
                                      showSourceTitle: true,
                                      showPublishDate: true
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @emos
        @emos you forgot an , behind the position
          module: 'clock',
        E 1 Reply Last reply Reply Quote 1
        • E Offline
          emos @strawberry 3.141
          @strawberry-3.141
          Thank you, it did the trick :)
          I see that you have removed the ‘,’ behind ‘false’. The last argument, or string, is that the only one that’s not suppose to have an ‘,’ at the end?
            @emos that’s correct it’s like writing a list you seperate them by comma except the last item
            • E Offline
              @strawberry-3.141 Thank you so much, that helped me alot :thumbsup:
              • E Offline
                emos
                one more question regarding the last ‘,’
                Does the same rule apply with the ‘[’ and ‘]’?
                                        position: 'lower_third',
                                                compliments: {
                                                        day_sunny: [
        'Today is a sunny day',
        'It\'s a beautiful day',
                                                        snow: [
        'Snowball battle!',
                                                        rain: [
        'Don\'t forget your umbrella'
                Or does each square bracket count as individual values. So if there’s only one you don’t need to close it?
                  @emos you have to seperate each level with commas things day_sunny, snow, rain has to be seperated with commas
                  thats what inside the square brackets has to be seperated by commasas well
