    MESA-LOADER: failed to open kms_swrast
    6 Posts 5 Posters 5.2k Views 9 Watching
    • T Offline
      tacotaco
      new to MM. I am receiving this error during startup of MM.
      MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/aarch64-linux-gnu/dri:$${ORIGIN}/dri:/usr/lib/dri)
      failed to load driver: kms_swrast
      default modules plus calendar-monthly and MMM-NOAA3 installed.
      Hardware : BCM2835
      Revision : c03114
      Serial : 100000001c249f69
      Model : Raspberry Pi 4 Model B Rev 1.4
      PRETTY_NAME=“Debian GNU/Linux 11 (bullseye)”
      NAME=“Debian GNU/Linux”
      VERSION_ID=“11”
      VERSION=“11 (bullseye)”
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL=“https://www.debian.org/”
      SUPPORT_URL=“https://www.debian.org/support”
      BUG_REPORT_URL=“https://bugs.debian.org/”
      can anyone advise? GPU driver problem?
      thx
      S K A 3 Replies Last reply Reply Quote 0
        sdetweil @tacotaco
        @tacotaco yes, probably.
        no fix that I can find yet
        • K Offline
          KI6UVE @tacotaco
          @tacotaco
          Did you ever get this resolved? I have the same error.
          Thanks,
          Hans
            bhepler Module Developer @KI6UVE
            @KI6UVE - I also have this error on a Innovatek Quadra (can’t find an RPi for sale for love or money).
            Bah. I thought I had something helpful to add. Never mind. It’s not working for me either.
              sdetweil @bhepler
              @bhepler @KI6UVE
              see
              https://forums.raspberrypi.com/viewtopic.php?t=338778
              but, looks like this is a known unsolved problem on 64 but pi os.
                andyrak @tacotaco
                @tacotaco
                I know this is an old issue, but I had this happen to me while setting up MM on a Le Potato board.
                Seems like a GPU issue, and you can bypass this by adding this snippet right before you call npm start:
                export ELECTRON_DISABLE_GPU=1
                In my case, I’m using PM2 to manage startup, so my ~/mm.sh file looks like this:
                cd ./MagicMirror
                DISPLAY=:0 npm start
                I don’t know the full extent of the issue, but I know that this works and allows me to run MM.
                Hopefully this helps you and anyone else looking for this in the future.
