    CSS Help
    18 Posts 3 Posters 5.9k Views 3 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      I’m wanting to get my Top Bar to display modules side-by-side.
      Using devtools, I found that it’s the “container” div, within the top bar div that is blocking it from happening.
      Changing that display: block to display:inline-flex does it for me, without effects to modules outside the top bar.
      I can’t figure out how to get to that container in css code, without the use of Devtools. Can someone help?
      here’s what I want to do - This:
      to this (minus the debug text, obviously):
      Thanks.
      S BKeyportB 2 Replies Last reply Reply Quote 0
        sdetweil @BKeyport
        @BKeyport
            .region.bar.top  div  {
                display:  inline-flex !important;
        element override wins over class
        need the !important
          @BKeyport if you override top bar, then EVERYTHING in top gets whacked…
          if you do top _center then only top center gets whacked…
          • BKeyportB Offline
            @sdetweil Yeah, Problem is, I’m using the top bar for that. Top Center is used for other things…
              sdetweil @BKeyport
              @BKeyport problem is that css selectors are ALL matching
              so that says EVERY div under .region.top.bar
              I tried div: first-child, and altho it SAID the new style was used, it didn’t DO it
              maybe easier in js code (jQuery) vs css
              u can try out the jQuery clauses in the dev window console at the >
              I do this in mmm config to change the styles dynamically.
              I also do the css of my module in newbustimes, using float… starting on line 140 on the modulename.js
              makes multiple instances line up sideways
              • BKeyportB Offline
                @sdetweil Yeah. Having access to the container div would be nice so to restrict it to the true top bar.
                Having all the top locations embedded under each other like that really stinks sometimes.
                • BKeyportB Offline
                  BKeyport Module Developer @BKeyport
                  As predicted, putting it in broke everything. It’s specifically got to fall into that container under top.bar. :/
                    sdetweil @BKeyport
                    @BKeyport so you could use code to fiddle w the styles.
                    https://www.w3schools.com/jsref/met_document_getelementsbyclassname.asp
                    you want it on .container under region top bar
                    not on top bar itself… else everything will be affected
                    • BKeyportB Offline
                      @sdetweil Exactly, I can’t seem to get far enough in custom.css
                      .region.top.bar.container don’t work, etc. The problem seems to be the style is hardcoded, perhaps, but I have no idea where.
                        sdetweil @BKeyport
                        @BKeyport when there is no space between classes it means has all
                        but this is split over 2 tags
                        div .region.top.bar
                        div .container
                        • BKeyportB Offline
                          @sdetweil So, how would I get down to container, and restrict it to within the top bar?
                            sdetweil @BKeyport
                            @BKeyport in css you can’t as it selects all
                            using code you can, cause u can change one element
                              shin10 Module Developer
                              Just use
                              .region.top.bar .module {
                                  display: inline-block;
                              or even better, explicitly the modules you want in one line (to avoid notifications shifting everything to the left in case they pop up)
                              .MMM-FlipClock, .MMM-Worldclock {
                              (*oops - edited)
                              BKeyportB 1 Reply Last reply Reply Quote 1
                              • BKeyportB Offline
                                BKeyport Module Developer @shin10
                                @shin10 2nd option is near perfect! Thanks! (changed it to inline-flex, and it lines up correct)
                                  sdetweil @BKeyport
                                  @BKeyport but you asked to modify top_bar, not your module…
                                  • BKeyportB Offline
                                    @sdetweil True, because I didn’t know the solution was to specify per-module.
                                      sdetweil @BKeyport
                                      @BKeyport ah , requirements… lol
                                      • BKeyportB Offline
                                        Devil in the details, again. :)
