    CSS Help
    18 Posts 3 Posters 5.0k Views 3 Watching
      sdetweil @BKeyport
      @BKeyport
          .region.bar.top  div  {
              display:  inline-flex !important;
      element override wins over class
      need the !important
        @BKeyport if you override top bar, then EVERYTHING in top gets whacked…
        if you do top _center then only top center gets whacked…
        • BKeyportB Offline
          @sdetweil Yeah, Problem is, I’m using the top bar for that. Top Center is used for other things…
            sdetweil @BKeyport
            @BKeyport problem is that css selectors are ALL matching
            so that says EVERY div under .region.top.bar
            I tried div: first-child, and altho it SAID the new style was used, it didn’t DO it
            maybe easier in js code (jQuery) vs css
            u can try out the jQuery clauses in the dev window console at the >
            I do this in mmm config to change the styles dynamically.
            I also do the css of my module in newbustimes, using float… starting on line 140 on the modulename.js
            makes multiple instances line up sideways
            • BKeyportB Offline
              @sdetweil Yeah. Having access to the container div would be nice so to restrict it to the true top bar.
              Having all the top locations embedded under each other like that really stinks sometimes.
              • BKeyportB Offline
                As predicted, putting it in broke everything. It’s specifically got to fall into that container under top.bar. :/
                  sdetweil @BKeyport
                  @BKeyport so you could use code to fiddle w the styles.
                  https://www.w3schools.com/jsref/met_document_getelementsbyclassname.asp
                  you want it on .container under region top bar
                  not on top bar itself… else everything will be affected
                  • BKeyportB Offline
                    @sdetweil Exactly, I can’t seem to get far enough in custom.css
                    .region.top.bar.container don’t work, etc. The problem seems to be the style is hardcoded, perhaps, but I have no idea where.
                      sdetweil @BKeyport
                      @BKeyport when there is no space between classes it means has all
                      but this is split over 2 tags
                      div .region.top.bar
                      div .container
                      • BKeyportB Offline
                        @sdetweil So, how would I get down to container, and restrict it to within the top bar?
