    Custom CSS
    11 Posts 3 Posters 8.6k Views 3 Watching
      SoleLo
      Can someone share a simple way to create a custom .css file? I’ve been back and forth try to customize different stuff and I keep getting stuck.
      S BKeyportB 2 Replies Last reply
        sdetweil @SoleLo
        @SoleLo from the command prompt do
         touch ~/MagicMirror/css/custom.css
        or edit that file( it doesn’t exist), and save there
        • BKeyportB
          BKeyport Module Developer @SoleLo
          @SoleLo while sam is technically correct, the best kind of correct, i’m assuming you want to modify the css from your modules, etc.
          here’s what you do.
          in the module directories, there is CSS files to set up their default looks. Open those to see how they use CSS. With most modules, they’ll have the module name, and the css style name together.
          DO NOT EDIT THOSE FILES. instead, copy the CSS blocks into custom.css (you don’t need to change anything), then make the changes there.
          If you can’t figure out how to do something in particular, you can use dev tools in any web browser (typically F12), to peek at the finalized code, and go from there. For an example, I’ll give you part of mine, showing both global and one module’s changes.
          /* Global changes */
          /* Use the entire screen */
          :root {
            --color-text: #fff;
            --color-text-dimmed: #fff;
            --color-text-bright: #fff;
            --color-background: #fff;
            --font-primary: "Roboto Condensed";
            --font-secondary: "Roboto";
            --font-size: 20px;
            --font-size-small: 0.75rem;
            --gap-body-top: 60px;
            --gap-body-right: 60px;
            --gap-body-bottom: 60px;
            --gap-body-left: 60px;
            --gap-modules: 30px;
          html {
          	cursor: none;
          body {
          	margin: 0px;
          	height: 100vh;
          	width: 100vw;
          /* Adjust all modules */
           .module {
                  padding: 2px;
                  margin-bottom: 0px;
          /* Region mods */
          .region.left {
          	text-align:center;
          .region.right {
          	right: 0%;
          	text-align: center;
          .region.top.center {
            left: 63%;
            transform: translateX(-50%);
            text-align:center;
          .region.fullscreen {
            position: absolute;
            top: 0px;
            left: 0px;
            right: 0px;
            bottom: 0px;
            pointer-events: none;
          .region.fullscreen * {
          	background: rgba(0,0,0,0.7);
          /* CX3-Agenda */
          .CX3A {
            font-size: 17px;
            min-width: 300px;
            max-width: 400px;
            max-height: 900px;
            overflow-y: hidden;
            text-align: left;
            position: relative;
            color: white;
          S S 3 Replies Last reply
            sdetweil @BKeyport
            @BKeyport many people coming to pi, and Linux just don’t know how to create files. they are some used to the UI, and clicking on something
            that’s why my script creates the empty custom.css as part of install
              SoleLo @BKeyport
              @BKeyport This helps quite a bit, I started using the dev tools yesterday “npm start dev” and it really helped. Thanks!
                SoleLo @sdetweil
                @sdetweil That script does help, I already had the file created, but I made note of the script for the future.
                  SoleLo @BKeyport
                  @BKeyport one of the modules I’m trying to customize doesn’t seem to have “classes” to adjust, unless I’m missing something for example the Percent/ Range section if I wanted to change the margin-top to 150, how would I go about that?
                  BKeyportB S 2 Replies Last reply
                  • BKeyportB
                    @SoleLo I’d have to defer to the CSS masters around here. I’m hacky at best at it.
                    Maybe we can loop in @shin10 to help, who really helped me with a situation I needed help with.
                      sdetweil @SoleLo
                      @SoleLo when there isn’t a class, you can still use the selector syntax to get to an element
                      .module_name div div
                      etc
                      here is a cheatsheet I use on determining a selector, the thing before the {
                      https://www.w3schools.com/cssref/css_selectors.asp
                      currently, there is no syntax for selecting an element that has some content… but :has() is coming…
                      a discussion on using css for individual tags
                      https://stackoverflow.com/questions/27823405/how-to-override-a-displaynone-property-applied-to-parent-element-in-specific-ch
                        SoleLo @sdetweil
                        @sdetweil so for the Percent/ Range it would be something like
                        .MMM-Teslamate div div
                        margin-top: 100px
                          sdetweil @SoleLo
                          @SoleLo i think to get to the div with the link its
                          .MMM-Teslamate div div div
