    PIR sensor problem after restart Raspi
    20 Posts 4 Posters 7.3k Views 4 Watching
      JoeFranz @Egnos
      @Egnos The sensor is correctly connected
        sdetweil @JoeFranz
        @JoeFranz and does it works correctly outside mm?
        there are python scripts that will show it working
          JoeFranz @sdetweil
          @sdetweil How can I test this?
            sdetweil @JoeFranz
            @JoeFranz Google search is your friend
            https://github.com/raspberrypilearning/physical-computing-guide/blob/master/test-pir-python.md
              JoeFranz @sdetweil
              @sdetweil Ok, that tests the PIR sensor. But since the Raspi doesn’t even let the monitor go into standby, I suspect that it’s due to Raspian. Screen blanking is activated in Raspi-Config, so the monitor should switch off after 10 minutes, right? But that doesn’t work either. Or does that have nothing to do with the PIR function of MM?
                sdetweil @JoeFranz
                @JoeFranz well, its shouldn’t go off by itself… as then u would have two things fighting for on or off…
                do this, i assume you have pm2 controlling mm at boot
                so, do
                pm2 status
                should only be one thing… defined
                  JoeFranz @sdetweil
                  @sdetweil ┌─────┬────────────────┬─────────────┬─────────┬─────────┬──────────┬────────┬──────┬───────────┬──────────┬──────────┬──────────┬──────────┐
                  │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
                  │ 0 │ MagicMirror │ default │ 2.20.0 │ fork │ 12738 │ 64s │ 0 │ online │ 0% │ 2.6mb │ pi │ disabled │
                  pi@raspberrypi:~ $
                    sdetweil @JoeFranz
                    @JoeFranz ok, it’s not a second process getting in the way
                    next to test the sensor w the python script
                    stop mm
                      JoeFranz @sdetweil
                      @sdetweil Nothing happens in the window. :-( PIR sensor broken?
                      • J JoeFranz referenced this topic on
                        JoeFranz @JoeFranz
                        @JoeFranz It is probably because of the current firmware 5.15
                        With
                        rpi-update b976c54917e240630c05a9b383010f1492bc61b4
                        I installed version 5.10. It now works again with the standby on the HDMI connection.
                        Greetings Joerg
                        edited due to wrong quotes outside code block
