    Performance of Raspbian Bullseye on Pi 3B
    5 Posts 2 Posters 2.3k Views 2 Watching
      j.e.f.f Project Sponsor Module Developer
      I recently rebuilt my mirror and installed Raspbian Bullseye as the base OS. I’m finding the performance to be REALLY slow… when my PIR sensor picks up motion, it takes a good 5-10 seconds or so for the mirror to respond, and when it does the transition from my screensaver module to normal layout is nowhere near smooth. Like 2-3 FPS.
      Am I expecting too much from a Pi 3B with running Bullseye? If so, what OS should I redo the build on that performs well, but is not so outdated to the point I’ll run into unsupported code problems?
      I don’t really want to purchase a Pi4 for this, as the Pi3B was at one point in time fine for this project and I’m not demanding anything more from it than I originally did.
        j.e.f.f Project Sponsor Module Developer @sdetweil
        @sdetweil Yep! A rebuild on Buster made all the difference. Performance is back up to what I remember it being under Jesse.
        Thanks for the tip!
          Also does installing Raspbian lite make a difference performance-wise or does it just save space?
            sdetweil @j.e.f.f
            @j-e-f-f mm doesn’t run on lite.
              sdetweil @j.e.f.f
              @j-e-f-f go back to legacy/buster… they are still tuning bullseye.
              increase the swap space will help, but will wear thru the SD card faster. I boot from read only sd card, run from 1tb SSD stick. lot faster disk
              buster will run out of support sometime.
                Thanks for the tip!
