    Online Radio
    52 Posts 4 Posters 23.9k Views 4 Watching
    • bugsounetB Offline
      bugsounet Banned @wishmaster270
      @wishmaster270
      If you use Buster release sound is configured by asound, if you use Bullseye it is PulseAudio
      Nop… It’s pulseaudio too…
      • T Offline
        tanvir586 @wishmaster270
        @wishmaster270 Hi , Im using my monitors build in speaker. I don’t know which operating system I’m using. I downloaded yesterday. Will let you know once I go home
        • T Offline
          @wishmaster270 Hi just checked. its bullseye. and my config is
          		module: "MMM-MplayerRadio",
          		header: "Radio",
          		position: "top_center",
          			//autoplay: 0,
          			stations: [
          					title: "Al Mubarak",
          					url: "https://emasjidlive.co.uk/listen/almubarakradio",
          					logo: "https://upload.wikimedia.org/wikipedia/commons/a/ac/Antenne-bayern-logo.png",
          • wishmaster270W Offline
            wishmaster270 Module Developer @tanvir586
            @bugsounet Oh, good to know. I use Bullseye for a while but currently only have a mirror running without audio.
            @tanvir586
            In default mode (which you use) mplayer is used. As i wrote in the documentation mplayer has caused a lot of problems with many streams. You could try to switch to vlc instead which is working much better but does not provide the current stream information.
            		header: "Radio",
            			//autoplay: 0,
                                    customCommand: "/usr/bin/vlc",
                                    customCommandArgs: ["-I","dummy","###URL###"],
            			stations: [
            Make sure to install vlc first:
            sudo apt update && sudo apt install -y vlc
            T 2 Replies Last reply Reply Quote 0
            • T Offline
              @wishmaster270 Hi I’ve tried this aswell. And I installed the vlc. But still not working. I’ll try it again now.
              • T Offline
                @wishmaster270 ok. Didn’t work. I have another mirror with no speaker. And that’s os 11.2. I can copy that sd card and try on my new mirror. Do you think it will work or I should do something on this one?
                  @tanvir586 If you do have graphical access directly or via vnc you can check the audio settings first.
                  Maybe the sound is send to analog out instead of hdmi.
                    wishmaster270 Module Developer @wishmaster270
                    @wishmaster270 If you do a right click on the speaker symbol you can decide where to output the sound:
                    T 1 Reply Last reply Reply Quote 1
                    • T Offline
                      It’s on Hdmi. And I can play YouTube, sound OK on YouTube
                      wishmaster270W 1 Reply Last reply Reply Quote 1
                        @tanvir586 Ok. Maybe the vlc on the shell ignores it.
                        Found an interesting thread which suggests running vlc with a additional option:
                        		header: "Radio",
                        			//autoplay: 0,
                                                customCommandArgs: ["-I","dummy", "--alsa-audio-device", "hw:0,0", "###URL###"],
                        			stations: [
                        If you use a Raspberry Pi 4 with two hdmi you may need to change “hw:0,0” to “hw:1,0” depending of the port your monitor is connected to.
                        Maybe this helps. I can not test it at the moment.
                        Edit:
                        Some people suggest to add
                        dtoverlay=vc4-fkms-v3d
                        to “/boot/config.txt” additionally.
                        • 6
                        • 4 / 6
