    Online Radio
    52 Posts 4 Posters 23.8k Views 4 Watching
    • T Offline
      tanvir586
      Is there any working online Radio module available? Tried couple of modules but no luck
      • wishmaster270W Offline
        wishmaster270 Module Developer @tanvir586
        @tanvir586 Hi,
        i developed MMM-MplayerRadio a couple of years ago. It still should be functional.
        • T Offline
          tanvir586 @wishmaster270
          @wishmaster270 Hi, tried your one. But no sound. Installed vlc still no sound. Will share my config once I go home. Thanks for replying mate
          wishmaster270W 1 Reply Last reply Reply Quote -1
            @tanvir586 Had a lot of problems with the sound of Raspberry as well. It do not think that it is a problem with the modules it might be a problem with the asound or pulseaudio configuration of the operating system.
            If you use Buster release sound is configured by asound, if you use Bullseye it is PulseAudio.
            Do you use the build in sound of the board or a external sound card?
            bugsounetB T 3 Replies Last reply Reply Quote 0
            • bugsounetB Offline
              bugsounet Banned @wishmaster270
              @wishmaster270
              Nop… It’s pulseaudio too…
              • T Offline
                @wishmaster270 Hi , Im using my monitors build in speaker. I don’t know which operating system I’m using. I downloaded yesterday. Will let you know once I go home
                • T Offline
                  @wishmaster270 Hi just checked. its bullseye. and my config is
                  		module: "MMM-MplayerRadio",
                  		header: "Radio",
                  		position: "top_center",
                  			//autoplay: 0,
                  			stations: [
                  					title: "Al Mubarak",
                  					url: "https://emasjidlive.co.uk/listen/almubarakradio",
                  					logo: "https://upload.wikimedia.org/wikipedia/commons/a/ac/Antenne-bayern-logo.png",
                    @bugsounet Oh, good to know. I use Bullseye for a while but currently only have a mirror running without audio.
                    @tanvir586
                    In default mode (which you use) mplayer is used. As i wrote in the documentation mplayer has caused a lot of problems with many streams. You could try to switch to vlc instead which is working much better but does not provide the current stream information.
                    		header: "Radio",
                    			//autoplay: 0,
                                            customCommand: "/usr/bin/vlc",
                                            customCommandArgs: ["-I","dummy","###URL###"],
                    			stations: [
                    Make sure to install vlc first:
                    sudo apt update && sudo apt install -y vlc
                    T 2 Replies Last reply Reply Quote 0
                    • T Offline
                      @wishmaster270 Hi I’ve tried this aswell. And I installed the vlc. But still not working. I’ll try it again now.
                      • T Offline
                        @wishmaster270 ok. Didn’t work. I have another mirror with no speaker. And that’s os 11.2. I can copy that sd card and try on my new mirror. Do you think it will work or I should do something on this one?
                        • 1 / 6
