    Hide a module by default
    11 Posts 3 Posters 4.0k Views 3 Watching
      rudiau
      Re: Hide a module by default
      Been following Sams instructions on this subject but cannot get it working.
      Below is the helloworld module I am experimenting with.
      Any help greatly appreciated, thanks.```
      /* MagicMirror²
       * Module: HelloWorld
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
      Module.register("helloworld", {
      	// Default module config.
      	defaults: {
              hidden: false,
      		text: "Hello World!"
      	getTemplate: function () {
      		return "helloworld.njk";
      	getTemplateData: function () {
      		return this.config;
        suspend: function (){
          this.hidden=true
        resume: function (){
           this.hidden=false
          notificationReceived: function (notification, payload, source) {
         // this comes before the first call to getDom()
         if(notification === "ALL_MODULES_STARTED")
            this.hidden=true;
      getDom: function (){
       var wrapper=document.createElement('div')
      if(this.hidden==false){
           //create normal content
      return wrapper;
      S 3 Replies Last reply Reply Quote 0
        sdetweil @rudiau
        @rudiau there is a new setting in config.js
        after module:
        hidden: true,
          sdetweil @rudiau
          @rudiau said in Hide a module by default:
          if(notification === “ALL_MODULES_STARTED”)
          this.hidden=true;
          also, it would be
          this.hide()
          it will do all the work and call your suspend() function
            sdetweil @rudiau
            @rudiau also, the code wrapper things have to be on their own line
            paste you text
            select it
            and hit the button above that looks like this
              rudiau
              Thanks for the quick response Sam.
              Still no good.
              Posted below are the config.js and helloworld .js(part of), is that what you meant by the ‘this.hide()’ placement.
              BTW on your code you posted on May 30, 2020, 6:07 AM
              there is a fullstop after the closing curly bracket, should that be a comma or nothing ie just a closing bracket.
              Thanks for the code posting tip, much easier.
              (closing bracket query)
              notificationReceived: function(notification, payload, source){
                    this.hidden=true;
                  module: "helloworld",
                  hidden: true,
                  position: "middle_center", // This can be any of the regions.
                    text: "Hello world!",
              (this.hide query)
                 //if(notification === "ALL_MODULES_STARTED")
                    //this.hidden=true;
                      this.hide()
              S BKeyportB 2 Replies Last reply Reply Quote 0
                sdetweil @rudiau
                @rudiau ok, full-stop? you mean semi-colon?
                not required in js unless everything is on the same line
                as for hidden, I am an idiot, see the doc
                  rudiau
                  hiddenOnStartup
                  Perfect.
                  Thank you Sam.
                  • BKeyportB Offline
                    @sdetweil “fullstop” is the period. In your original, it looks like there was a comma. :)
                      sdetweil @BKeyport
                      @BKeyport ok, I don’t see where you are referencing
                      • BKeyportB Offline
                        BKeyport Module Developer @rudiau
                        @sdetweil:
                        >       this.hidden=true;
                        Looks it was all his actually. The last line of that code has the fullstop after a closing curly bracket.
                          sdetweil @BKeyport
                          @BKeyport ah, I see the question… never heard a period called that
