    JSON request module
    41 Posts 3 Posters 18.6k Views 4 Watching
    • E Offline
      ELMAGO
      hello,
      I am looking for a module that would display several JSON replies.
      I tested MMM-JSON but does not work black screen, MMM-JsonTable
      but is not multi url, MMM-json-feed the same.
      My urls are coordinated as follows:
      http://192.168.100.244:3000/ROOMTIME
      And the answer is
      // 20221123185334
      // http://192.168.100.244:3000/ROOMTIME
      “status”: “successful”,
      “url”: “/ROOMTIME”,
      “method”: “GET”,
      “data”: 21.4
      I will therefore need a module where I can display a specific name for each url, ex:
      Temp. Room 21.4°c
      Thank you in advance for your help.
      And sorry for my English.:face_savoring_food: :face_savoring_food:
      S wishmaster270W 2 Replies Last reply Reply Quote 0
      • E Offline
        ELMAGO @wishmaster270
        @wishmaster270
        Re Goodnight
        It’s awesome, it’s exactly what I wanted.
        Thank you so much.
          sdetweil @ELMAGO
          @ELMAGO I am not aware of any module that does interconnection between fetched tables.
          black screen, see the black screen item pinned at top of troubleshooting section
          • E Offline
            ELMAGO @sdetweil
            @sdetweil thank.
            • wishmaster270W Offline
              wishmaster270 Module Developer @ELMAGO
              @ELMAGO Hi,
              You can use a simple curl command to fetch the data and get the data send as notification with my MMM-CommandToNotification module. The module supports to call commands periodically.
              As you do have the data as payload of a notification then you can use my MMM-ValuesByNotification module to display it. This module is very powerful, allows parsing the payload as Json, selecting values in the Json with JSONPath syntax and even reformatting.
              • E Offline
                @wishmaster270
                Thank you for your reply.
                So I installed the two modules and configured my config as follows:
                //TEMPERATURE MAISON
                   module: "MMM-CommandToNotification",
                   disabled: false,
                    updateInterval: 10,
                    commands: [
                      script: "http://192.168.100.244:3000/TEMPSALLE",
                      args: "-10 10",
                      timeout: 5,
                      notifications: [
                       "TEMPSALLE",
                // AFFICHAGE
                   module: "MMM-ValuesByNotification",
                   header: "Module-1",
                    groups: [
                      items: [
                        notification: "TEMPSALLE",
                        itemTitle: "Item-1",
                        values: [
                          valueTitle: "Value-1",
                		valueUnit: "°C",
                		jsonpath: "data",
                and i get :
                Can you help me ?
                  @ELMAGO You can NOT enter the url directly into the Command module. You need to call a valid Shell Command.
                  In your case I will suggest curl.
                  The full command will be:
                  curl -vs  http://192.168.100.244:3000/TEMPSALLE2
                  So the command configuration should be something like:
                     disabled: false,
                      updateInterval: 10,
                      commands: [
                        script: "/usr/bin/curl",
                        args: "-vs  http://192.168.100.244:3000/TEMPSALLE2",
                        timeout: 5,
                        notifications: [
                         "TEMPSALLE",
                  As a result the output of the curl command will be send as notification “TEMPSALE”.
                  You can test the curl command in a terminal.
                  • E Offline
                    @wishmaster270 said in JSON request module:
                    Good evening
                    (I am in France)
                    Thanks for your answer but I still have the same result.
                       disabled: false,
                        updateInterval: 10,
                        commands: [
                          args: "-vs  http://192.168.100.244:3000/TEMPSALLE",
                          timeout: 5,
                          notifications: [
                           "TEMPSALLE",
                    // AFFICHAGE
                       header: "TEMPERATURE MAISON",
                        groups: [
                          items: [
                            itemTitle: "TEMPSALLE",
                            values: [
                              valueTitle: "TEMPSALLE",
                    		valueUnit: "C",
                    		jsonpath: "data",
                    I have to miss something but I don’t see what
                      @ELMAGO Hi, no problem let’s dive deeper. Can you please run the curl command manually on the console and paste the result here, please.
                      • E Offline
                        @wishmaster270
                        There she is
                          @ELMAGO
                          Sorry, my fault.
                          Can you please remove the v option of the curl command. It needs to be curl -s ....
                          • E Offline
                            @wishmaster270
                            It’s same
                               disabled: false,
                                updateInterval: 10,
                                commands: [
                                  args: "-s  http://192.168.100.244:3000/TEMPSALLE",
                                  timeout: 5,
                                  notifications: [
                                   "TEMPSALLE",
                            // AFFICHAGE
                                groups: [
                                  items: [
                                    values: [
                            		valueUnit: "C",
                            		jsonpath: "data",
                              @ELMAGO
                              Sorry, took me a moment to set up a test environment…
                              I think if your webserver is not very very fast you need to increase the timeout value in the command module.
                              The timeout is in milliseconds and you configured 5. I guess it should be 5000.
                              This config works fine in my development environment.
                              			disabled: false,
                              			 updateInterval: 60,
                              			 commands: [
                              			   timeout: 5000,
                              			   notifications: [
                              				"TEMPSALLE",
                              			 groups: [
                              			   items: [
                              				 values: [
                              				 valueUnit: "C",
                              				 jsonpath: "data",
                              Edit: I increased the updateInterval to 60
                              • E Offline
                                @wishmaster270
                                You are phenomenal…but I still have three problems:
                                1 - When I look for several values, it only shows me the first one.
                                2- The Celsius symbol does not seem to be accepted
                                3- 3- If I may abuse…is it possible to do the same formatting as this one. CSS and me…
                                Here is my code :
                                   disabled: false,
                                    updateInterval: 60,
                                    commands: [
                                      timeout: 5000,
                                      notifications: [
                                       "TEMPSALLE",
                                   disabled: false,
                                    updateInterval: 60,
                                    commands: [
                                      args: "-s  http://192.168.100.244:3000/TEMPBUREAU",
                                      timeout: 5000,
                                      notifications: [
                                       "TEMPBUREAU",
                                // AFFICHAGE
                                    groups: [
                                      items: [
                                        values: [
                                          valueTitle: "SALLE A MANGER",
                                		valueUnit: "°C",
                                		jsonpath: "data",
                                        notification: "TEMPBUREAU",
                                        values: [
                                          valueTitle: "BUREAU",
                                		valueUnit: "°C",
                                		jsonpath: "data",
                                Once again thank you for everything.
                                  @ELMAGO Step by Step closer to the goal😉
                                  1: You can/need to use one instance of the command module to fetch the data of the to urls.
                                  2: I use the Celsius sign in my setup without any problems but it may depend of the encoding of your operating system and Browser. You can try to use the html encoding ° instead.
                                     disabled: false,
                                      updateInterval: 60,
                                      commands: [
                                        timeout: 5000,
                                        notifications: [
                                         "TEMPSALLE",
                                             timeout: 5000,
                                             notifications: [
                                              "TEMPBUREAU",
                                  // AFFICHAGE
                                      groups: [
                                        items: [
                                          values: [
                                  		valueUnit: "°C",
                                  		jsonpath: "data",
                                          values: [
                                  		valueUnit: "°C",
                                  		jsonpath: "data",
                                  3: I provided a lot examples with screenshots in the modules doc directory (screenshots). You will find the corresponding config and css of each screenshot in the configs. Maybe there is a styling included you like. If not feel free to ask again.
                                  E 2 Replies Last reply Reply Quote 0
                                  • E Offline
                                    This post is deleted!
                                    • E Offline
                                      valueTitle
                                      I’m really sorry but I’m really bad at this.
                                      I did this:
                                      config:
                                         disabled: false,
                                          updateInterval: 60,
                                          commands: [
                                            timeout: 5000,
                                            notifications: [
                                             "TEMPSALLE",
                                                 timeout: 5000,
                                                 notifications: [
                                                  "TEMPBUREAU",
                                      // AFFICHAGE
                                      			updateInterval: 10,
                                      			reuseCount: 100,
                                      			addClassesRecursive: true,
                                      			groups: [
                                      					items: [
                                      							itemTitle: "Salle: ",
                                      							classes: "withIcons",
                                      							values: [
                                      									valueIcon: "fa fa-thermometer-full",
                                      									valueUnit: "°C",
                                      									valueFormat: "Number(${value}).toFixed(2)",
                                      									jsonpath: "data",
                                      									valueUnit: "%rH",
                                      									valueFormat: "Number(${value}).toFixed(1)",
                                      									jsonpath: "humidity",
                                      							itemTitle: "Bureau ",
                                      							values: [
                                      									valueUnit: "°CC",
                                      									jsonpath: "data",
                                      									valueUnit: "%rH",
                                      And use css :
                                      .MMM-ValuesByNotification .vbn .itemWrapper {
                                        flex-direction: row;
                                      .MMM-ValuesByNotification .vbn .itemTitle {
                                        min-width: 105px;
                                        text-decoration: none;
                                      .MMM-ValuesByNotification .vbn .itemTitle.withIcons {
                                        margin-top: 17px;
                                      .MMM-ValuesByNotification .vbn .itemWrapper.withIcons {
                                        line-height: 22px;
                                      .MMM-ValuesByNotification .vbn .itemWrapper:not(.withIcons) {
                                        line-height: 10px;
                                      and nothing is displayed
                                        @ELMAGO
                                        Great to see the data beeing displayed. We get the styling, too.
                                        Please do not edit files in the module folder. You can modify/override all css in the custom.css file in the css directory of MagicMirror.
                                        The examples only overrides the things needed.
                                        Currently I only have my mobile and can not test any things. Maybe I can look at it tomorrow.
                                        • E Offline
                                          @wishmaster270
                                          The custom file?
                                          there is no problem, you help me already it is a lot.
                                          There is nothing urgent, I just have this display to do on a whole home automation installation.
                                          I await your return and thank you again.
                                            sdetweil @ELMAGO
                                            @ELMAGO the CSS design is a stack, top down
                                            css/custom.css
                                            module_provided_css (in the module folder)
                                            css/main.css (provided by MM).
                                            so a search for a css setting starts with custom.css and stops at the 1st occurrence.
                                            • E Offline
                                              @wishmaster270 @sdetweil
                                              I correct myself, it is displayed but thus, having created the custom.css file in css:
                                              Here is my config file:
                                              // AFFICHAGE
                                              			updateInterval: 10,
                                              			reuseCount: 100,
                                              			groups: [
                                              					items: [
                                              							itemTitle: "Salle  ",
                                              							values: [
                                              									valueUnit: " °C",
                                              									jsonpath: "data",
                                              							values: [
                                              									valueUnit: " °C",
                                              									jsonpath: "data",
                                              • 1 / 3
