    Mirror broken after v2.22.0 upgrade
    29 Posts 4 Posters 10.4k Views 4 Watching
    • E Offline
      ecirpnaes
      Just upgraded to the latest MM version, and I’m getting an Electron error on startup.
      Specifically… .node_modules/[…]/dist/electron: symbol lookup error: undefined symbol: gbm_bo_get_modifier.
      I assumed I had some out of date core files, so I upgraded my core raspian OS, since I was sadly out of date, but no help. I tried rolling back Electron to the previous 19.1 version, but ran into other dependency issues.
      Anyone else experiencing anything like this? I’m tempted to just take some time and do a clean install, but was hoping someone knew of a simpler fix.
        sdetweil @ecirpnaes
        @ecirpnaes ok, do this
        cd ~/MagicMirror
        rm -rf node_modules
        npm install --omit=dev --no-audit --no-fund
        i just did this on my pi4 after upgrading from 2.21
        E P 2 Replies Last reply Reply Quote 1
          sdetweil @ecirpnaes
          @ecirpnaes how did u upgrade?
          • E Offline
            ecirpnaes @sdetweil
            @sdetweil Standard way. git pull & npm install
              sdetweil @ecirpnaes
              cd ~/MagicMirror
              rm -rf node_modules
              • E Offline
                ecirpnaes @sdetweil
                @sdetweil Thanks!
                I had already tried blowing away the node_modules and letting it rebuild doing a standard “npm install”, but hadn’t tried it with omitting the dev only files. That said, I just did it and still no go.
                To be clear, the mirror will run with a “server only” option, so the error is clearly with a library file with electron.
                /home/pi/MagicMirror/node_modules/electron/dist/electron: symbol lookup error: /home/pi/MagicMirror/node_modules/electron/dist/electron: undefined symbol: gbm_bo_get_modifier
                I’ll try a few other things but I guess worse comes to worse, I can pull a clean image and just clone everything down again.
                  sdetweil @ecirpnaes
                  @ecirpnaes ok, what system are u running on?
                  lsb_release-a
                  uname -a
                  I did the install on pi os, and on Intel Linux.
                  what desktop are u running?
                  Wayland, x11, ??
                  • E Offline
                    ecirpnaes @sdetweil
                    Distributor ID: Raspbian
                    Description: Raspbian GNU/Linux 9.13 (stretch)
                    Release: 9.13
                    Codename: stretch
                    Linux raspberrypi 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
                    Honestly not sure what desktop it is running. I usually just putty into it from a windows machine.
                    S 1 Reply Last reply Reply Quote -1
                      sdetweil @ecirpnaes
                      @ecirpnaes ok stretch is too old for this latest electron
                      I think u have to move up to buster(release after stretch) as least
                      bullseye is the current
                      and another one coming soon… this year I think.
                      u might be able to backup,/restore using my scripts
                      and use my script to install latest to restore config to.
                      E 2 Replies Last reply Reply Quote 0
                      • E Offline
                        ecirpnaes @sdetweil
                        @sdetweil That sounds about right. It’s been a couple years since I’ve updated my base image. I assumed it was going to come to that sooner or later.
                        Thanks for the confirmation. I’ll definitely take a look at your scripts.
                        • P Offline
                          Peter @sdetweil
                          @sdetweil said in Mirror broken after v2.22.0 upgrade:
                          cd ~/MagicMirror
                          rm -rf node_modules
                          Great!
                          Solved my problem too!
                          Thanks.
                          Peter
                          S K 2 Replies Last reply Reply Quote 1
                          • 1 / 3
