    electron-rebuild problems with MagicMirror 2.22.0
    53 Posts 5 Posters 22.2k Views 6 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer @KristjanESPERANTO
      @KristjanESPERANTO
      Hi and thank you for contributing. I confirm that changing to magicmirror-rebuild did not make things batter but worse. I now followed the suggestion of @sdetweil and implemented his postinstall script. Things are working perfectly now and should work in future releases, too.
      I merged the new changes to the master a few minutes ago and released version 0.0.7 of MMM-GPIO-Notifications. I will implement this approach in my other modules, too.
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @wishmaster270
        @wishmaster270 OK, you’re welcome.
        Since the thread is also for other developers: I recommend considering my approach, as I consider the other approach (installing to a higher-level directory) to be more error-prone. But it’s a creative workaround.
          @KristjanESPERANTO
          The problem with installing it in the module directory is that we need to compile the library against the electron version installed in the MagicMirror project.
          If electron-rebuild is installed in the module directory it might fail to detect the right electron version (which was the cause of the rebuild problems in the past).
          So the right way is to install electron-rebuild in the same project as electron and call it from there.
          It might be worth to think about adding it as a dependency in the main project.
          KristjanESPERANTOK karsten13K 2 Replies Last reply Reply Quote 1
            @wishmaster270 Okay, thanks for the explanation! I haven’t been able to read that anywhere in such clear words and I haven’t dealt with the past problems. Then I withdraw my recommendation because I lack the overview.
              sdetweil @KristjanESPERANTO
              @KristjanESPERANTO ah I see
              haven’t heard of @electron/rebuild
              • karsten13K Offline
                karsten13 @wishmaster270
                @wishmaster270 said in electron-rebuild problems with MagicMirror 2.22.0:
                installing module stuff in the node_modules folder of mm is a hack and will not work out of the box with a docker setup because this folder is only in the container (you have to map it on the host to get changes there persistent)
                in this case may the best solution
                  sdetweil @karsten13
                  @karsten13 yes, that’s what I think we come to but doesn’t help any existing broken modules
                    sdetweil @karsten13
                    @karsten13 docker is a pita with this stuff. too much/not enough in the container. which is supposed to be immutable.
                      KristjanESPERANTO Module Developer @sdetweil
                      @sdetweil As a soft step, the broken modules could switch to @electron/rebuild. This should also work for docker.
                      wishmaster270W S 2 Replies Last reply Reply Quote 0
                        @KristjanESPERANTO
                        I have a docker installation running for development here on my notebook.
                        Everytime a module needs “npm install” I exec to the container and run the command in the container cause there will be called the correct npm and node version in the container and not the ones I currently use on my notebook.
                        In this case the directory structure is the same as with a locally installed MagicMirror and the postinstall script will work as excepted.
                        karsten13K 1 Reply Last reply Reply Quote 1
                        • 6
                        • 4 / 6
