    electron-rebuild problems with MagicMirror 2.22.0
    53 Posts 5 Posters 20.4k Views 6 Watching
    • karsten13K Offline
      karsten13 @wishmaster270
      @wishmaster270 said in electron-rebuild problems with MagicMirror 2.22.0:
      and the postinstall script will work as excepted.
      yes, will work, but all the changes in the node_modules folder of mm are gone with the next restart of the container …
      • wishmaster270W Offline
        wishmaster270 Module Developer @karsten13
        @karsten13
        In case of electron-rebuild this is no problem as it is only required during compile but not at runtime.
          @wishmaster270
          o.k., but where are the compile results stored?
            @karsten13
            They are stored in the node_modules folder of the module which should be persistent
            Edit: Do not misunderstand me. In my opinion the best way to solve the electron-rebuild problems of a lot of modules would be to put “@electron/rebuild” as a dependency to “package.json” of MagicMirror.
            karsten13K 2 Replies Last reply Reply Quote 0
              @karsten13
              thats good, so the construction with installing electron-rebuild in mm folder has no side effects and works also in a docker setup.
                I don’t have a final opinion on that yet, but if so, we should put it under optionalDependencies as electron
                wishmaster270W S 2 Replies Last reply Reply Quote 1
                  @karsten13
                  You are right. I think optionalDependencies would be a great solution. Module developers could then add a hint to run npm ci in the MagicMirror directory to their installations instructions.
                  As the container it self is untouched it should be no problem. It only causes @electron/rebuild to be installed the next time the script is called.
                    sdetweil @KristjanESPERANTO
                    @KristjanESPERANTO but if u look at electron/rebuild after install u call electron-rebuild
                    still has to be installed in the base node_modules folder…
                    older unmaintained modules are broken either way. why I had to fork MMM-Buttons.
                      sdetweil @wishmaster270
                      @wishmaster270 optional is there so that IF electron is NOT installed, the install does not fail (needed on pi0w at least)
                      have nothing to do w ci
                      my script ONLY installs prod, no dev. as 99.5% of users are users not mm developers. has nothing to do w module developers
                        sdetweil @karsten13
                        @karsten13 and the postinstall checks for it being there, and if so skips the e-r install.
                        doesn’t know/care HOW it got installed before
                        • 6
                        • 5 / 6
