    electron-rebuild problems with MagicMirror 2.22.0
    53 Posts 5 Posters 27.3k Views 6 Watching
      sdetweil @karsten13
      @karsten13 yeh, haven’t tested on arm64 on pi for a while.
      but its still an npm problem if it doesn’t run the postinstall
      flashing image now
      worked fine
      pi@raspberrypi:~/MagicMirror/modules $ uname -a
      Linux raspberrypi 5.15.61-v8+ #1579 SMP PREEMPT Fri Aug 26 11:16:44 BST 2022 aarch64 GNU/Linux
      pi@raspberrypi:~/MagicMirror/modules $ node -v
      v16.19.0
      pi@raspberrypi:~/MagicMirror/modules $ npm -v
      8.19.3
      pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/sdetweil/MMM-Buttons.git
      Cloning into 'MMM-Buttons'...
      remote: Enumerating objects: 56, done.
      remote: Counting objects: 100% (4/4), done.
      remote: Compressing objects: 100% (4/4), done.
      remote: Total 56 (delta 0), reused 2 (delta 0), pack-reused 52
      Receiving objects: 100% (56/56), 11.86 KiB | 3.95 MiB/s, done.
      Resolving deltas: 100% (25/25), done.
      pi@raspberrypi:~/MagicMirror/modules $ cd MMM-Buttons/
      pi@raspberrypi:~/MagicMirror/modules/MMM-Buttons $ npm install --omit=dev --no-audit --no-fund
      > Magic-Mirror-Module-Buttons@1.0.0 postinstall
      > ./postinstall
      /home/pi/MagicMirror/modules/MMM-Buttons
      ⠙ Building module: epoll, Completed: 0make: Entering directory '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
        CXX(target) Release/obj.target/epoll/src/epoll.o
      ⠸ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
      ⠧ Building module: epoll, Completed: 0  COPY Release/epoll.node
      make: Leaving directory '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
      ✔ Rebuild Complete
      added 6 packages in 2m
      • wishmaster270W Offline
        wishmaster270 Module Developer @sdetweil
        @sdetweil Sorry, had no Internet connection for a few hours.
        The version of my GPIO module in the development branch uses the postinstall script and there is where the error happens.
        It is a Raspberry 4 in my case with 32bit Bullseye.
        It is
        npm 9.2.0
        node 16.19.0
        arch armv7l
        in my case.
          sdetweil @wishmaster270
          @wishmaster270 hm, I modified your module and it works fine… will check your branch
          I just copy the postinstall script and change package.json
          intel x86-64 ok
          base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ git checkout development
          branch 'development' set up to track 'origin/development'.
          Switched to a new branch 'development'
          (base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ ls
          examples  LICENSE  MMM-GPIO-Notifications.js  node_helper.js  package.json  postinstall  README.md
          (base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ nano package.json
          (base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ npm install --omit=dev --no-audit --no-fund
          > MMM-GPIO-Notifications@0.0.6 postinstall
          > ./postinstall
          /home/sam/MagicMirror/modules/MMM-GPIO-Notifications
          ⠧ Building module: epoll, Completed: 0make: Entering directory '/home/sam/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
          ⠇ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
          make: Leaving directory '/home/sam/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
          ✔ Rebuild Complete
          added 6 packages in 10s
          pi 64 aarch64 ok
          (base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ ssh pi@192.168.2.44
          pi@192.168.2.44's password:
          The programs included with the Debian GNU/Linux system are free software;
          the exact distribution terms for each program are described in the
          individual files in /usr/share/doc/*/copyright.
          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
          permitted by applicable law.
          Last login: Fri Jan  6 14:10:59 2023 from 192.168.2.106
          pi@raspberrypi:~ $ pm2 stop all
          [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
          [PM2] [MagicMirror](0) ✓
          │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
          │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
          pi@raspberrypi:~ $ cd MagicMirror/modules
          pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications.git
          Cloning into 'MMM-GPIO-Notifications'...
          remote: Enumerating objects: 159, done.
          remote: Counting objects: 100% (42/42), done.
          remote: Compressing objects: 100% (34/34), done.
          remote: Total 159 (delta 17), reused 22 (delta 8), pack-reused 117
          Receiving objects: 100% (159/159), 744.45 KiB | 3.48 MiB/s, done.
          Resolving deltas: 100% (74/74), done.
          pi@raspberrypi:~/MagicMirror/modules $ cd MMM-GPIO-Notifications/
          pi@raspberrypi:~/MagicMirror/modules/MMM-GPIO-Notifications $ git checkout development
          Branch 'development' set up to track remote branch 'development' from 'origin'.
          pi@raspberrypi:~/MagicMirror/modules/MMM-GPIO-Notifications $ npm install --omit=dev --no-audit --no-fund
          > ./postinstall
          ⠋ Building module: epoll, Completed: 0make: Entering directory '/home/pi/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
          ⠹ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
          ⠦ Building module: epoll, Completed: 0  COPY Release/epoll.node
          make: Leaving directory '/home/pi/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
          ✔ Rebuild Complete
          added 6 packages in 15s
          pi@raspberrypi:~/MagicMirror/modules/MMM-GPIO-Notifications $ exit
          pi 32bit buster ok
          pi@raspberrypi42:~ $ cd MagicMirror/modules/
          pi@raspberrypi42:~/MagicMirror/modules $ git clone https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications.git
          Receiving objects: 100% (159/159), 744.45 KiB | 73.00 KiB/s, done.
          pi@raspberrypi42:~/MagicMirror/modules $ cd MMM-GPIO-Notifications/
          pi@raspberrypi42:~/MagicMirror/modules/MMM-GPIO-Notifications $ git checkout develoment
          error: pathspec 'develoment' did not match any file(s) known to git
          pi@raspberrypi42:~/MagicMirror/modules/MMM-GPIO-Notifications $ git checkout development
          pi@raspberrypi42:~/MagicMirror/modules/MMM-GPIO-Notifications $ npm install --omit=dev --no-audit --no-fund
          > ./postinstall
          ⠙ Building module: epoll, Completed: 0make: Entering directory '/home/pi/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
          ⠙ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
          ⠼ Building module: epoll, Completed: 0  COPY Release/epoll.node
          ✔ Rebuild Complete
          added 6 packages in 14s
          pi@raspberrypi42:~/MagicMirror/modules/MMM-GPIO-Notifications $ lsb_release -a
          No LSB modules are available.
          Distributor ID:	Raspbian
          Description:	Raspbian GNU/Linux 10 (buster)
          Release:	10
          Codename:	buster
          32 bit bullseye, ok
          fribble@raspberrypi4:~ $ cd MagicMirror/modules/
          fribble@raspberrypi4:~/MagicMirror/modules $ lsb_release -a
          Description:	Raspbian GNU/Linux 11 (bullseye)
          Release:	11
          Codename:	bullseye
          fribble@raspberrypi4:~/MagicMirror/modules $ git clone https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications.git
          Receiving objects: 100% (159/159), 744.45 KiB | 3.26 MiB/s, done.
          fribble@raspberrypi4:~/MagicMirror/modules $ cd MMM-GPIO-Notifications/
          fribble@raspberrypi4:~/MagicMirror/modules/MMM-GPIO-Notifications $ git checkout development
          fribble@raspberrypi4:~/MagicMirror/modules/MMM-GPIO-Notifications $ npm install --omit=dev --no-audit --no-fund
          > ./postinstall
          ⠸ Building module: epoll, Completed: 0make: Entering directory '/home/fribble/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
          ⠴ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
          ⠏ Building module: epoll, Completed: 0  COPY Release/epoll.node
          make: Leaving directory '/home/fribble/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
          ✔ Rebuild Complete
          added 6 packages in 21s
            @wishmaster270 said in electron-rebuild problems with MagicMirror 2.22.0:
            kApiSystemPointerSize == kApiInt64Size,
            this looks like a compile header mismatch
            make sure u delete the electron-rebuild if its in your module folder
            AND the one in MagicMirror/node_modules in case there is a downlevel version,
            OR change the postinstall to always install it. vs checking if present and running the installed version…
              Today i started a new approach and removed the “node_modules” folder of MagicMirror before the update to make sure no other electron-rebuild packages are installed.
              As i do have a second electron app running on my mirror (TeleFrame) is stopped this application and removed the “/home/pi/.electron-gyp” folder to make sure everything is clean before the update.
              I then did the update with your script and the “npm install” step of my MMM-GPIO-Notifications module fails.
              I cloned your “MMM-Buttons” module and tried to install only this module but i get the same compile error. I enabled the DEBUG flag. Maybe you see something i do not see but it looks like the correct electron-rebuild version is used:
              pi@mirror-eg:~/MagicMirror/modules/MMM-Buttons $ npm install
              > ./postinstall
              ⠋ Searching dependency tree  electron-rebuild rebuilding with args: [Arguments] {
                '0': {
                  buildPath: '/home/pi/MagicMirror/modules/MMM-Buttons',
                  electronVersion: '22.0.0',
                  arch: 'arm',
                  extraModules: [],
                  onlyModules: null,
                  force: undefined,
                  headerURL: undefined,
                  types: [ 'prod', 'optional' ],
                  mode: undefined,
                  debug: undefined,
                  prebuildTagPrefix: 'v',
                  forceABI: undefined,
                  useElectronClang: false,
                  disablePreGypCopy: false,
                  projectRootPath: '/home/pi/MagicMirror/modules/MMM-Buttons'
              } +0ms
                electron-rebuild rebuilding with args: /home/pi/MagicMirror/modules/MMM-Buttons 22.0.0 arm Set(0) {} false https://www.electronjs.org/headers [ 'prod', 'optional' ] false +8ms
                electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/onoff +0ms
                electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll +4ms
                electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/lodash.debounce +1ms
                electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/bindings +2ms
                electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/nan +1ms
                electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/file-uri-to-path +1ms
                electron-rebuild identified prod deps: Set(0) {
                onoff: true,
                epoll: true,
                'lodash.debounce': true,
                bindings: true,
                nan: true,
                'file-uri-to-path': true
              } +1ms
                electron-rebuild scanning: /home/pi/MagicMirror/modules/MMM-Buttons/node_modules +5ms
                electron-rebuild rebuilding epoll with args [
                'node',
                'node-gyp',
                'rebuild',
                '--runtime=electron',
                '--target=22.0.0',
                '--arch=arm',
                '--dist-url=https://www.electronjs.org/headers',
                '--build-from-source',
                '--verbose'
              ] +0ms
              gyp verb command rebuild []
              gyp verb command clean []
              gyp verb clean removing "build" directory
              ⠙ Building module: epoll, Completed: 0gyp verb command configure []
              gyp verb download using dist-url https://www.electronjs.org/headers
              gyp verb find Python Python is not set from command line or npm configuration
              gyp verb find Python Python is not set from environment variable PYTHON
              gyp verb find Python checking if "python3" can be used
              gyp verb find Python - executing "python3" to get executable path
              ⠹ Building module: epoll, Completed: 0gyp verb find Python - executable path is "/usr/bin/python3"
              gyp verb find Python - executing "/usr/bin/python3" to get version
              ⠸ Building module: epoll, Completed: 0gyp verb find Python - version is "3.7.3"
              gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3"
              gyp verb get node dir compiling against --target node version: 22.0.0
              gyp verb command install [ '22.0.0' ]
              gyp verb install input version string "22.0.0"
              gyp verb install installing version: 22.0.0
              gyp verb install --ensure was passed, so won't reinstall if already installed
              ⠼ Building module: epoll, Completed: 0gyp verb install version is already installed, need to check "installVersion"
              gyp verb got "installVersion" 9
              gyp verb needs "installVersion" 9
              gyp verb install version is good
              gyp verb get node dir target node version installed: 22.0.0
              gyp verb build dir attempting to create "build" dir: /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build
              gyp verb build dir "build" dir needed to be created? Yes
              gyp verb python symlink creating symlink to "/usr/bin/python3" at "/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/node_gyp_bins/python3"
              gyp verb build/config.gypi creating config file
              gyp verb build/config.gypi writing out config file: /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/config.gypi
              gyp verb config.gypi checking for gypi file: /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/config.gypi
              gyp verb common.gypi checking for gypi file: /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/common.gypi
              gyp verb gyp gyp format was not specified; forcing "make"
              gyp info spawn /usr/bin/python3
              gyp info spawn args [
              gyp info spawn args   '/home/pi/MagicMirror/node_modules/node-gyp/gyp/gyp_main.py',
              gyp info spawn args   'binding.gyp',
              gyp info spawn args   '-f',
              gyp info spawn args   'make',
              gyp info spawn args   '-I',
              gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/config.gypi',
              gyp info spawn args   '/home/pi/MagicMirror/node_modules/node-gyp/addon.gypi',
              gyp info spawn args   '/home/pi/.electron-gyp/22.0.0/include/node/common.gypi',
              gyp info spawn args   '-Dlibrary=shared_library',
              gyp info spawn args   '-Dvisibility=default',
              gyp info spawn args   '-Dnode_root_dir=/home/pi/.electron-gyp/22.0.0',
              gyp info spawn args   '-Dnode_gyp_dir=/home/pi/MagicMirror/node_modules/node-gyp',
              gyp info spawn args   '-Dnode_lib_file=/home/pi/.electron-gyp/22.0.0/<(target_arch)/node.lib',
              gyp info spawn args   '-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll',
              gyp info spawn args   '-Dnode_engine=v8',
              gyp info spawn args   '--depth=.',
              gyp info spawn args   '--no-parallel',
              gyp info spawn args   '--generator-output',
              gyp info spawn args   'build',
              gyp info spawn args   '-Goutput_dir=.'
              gyp info spawn args ]
              ⠙ Building module: epoll, Completed: 0gyp verb command build []
              gyp verb build type Release
              gyp verb architecture armv7l
              gyp verb node dev dir /home/pi/.electron-gyp/22.0.0
              gyp verb `which` succeeded for `make` /usr/bin/make
              gyp verb bin symlinks adding symlinks (such as Python), at "/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/node_gyp_bins", to PATH
              gyp info spawn make
              gyp info spawn args [ 'V=1', 'BUILDTYPE=Release', '-C', 'build' ]
              make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build“ wird betreten
                g++ -o Release/obj.target/epoll/src/epoll.o ../src/epoll.cc '-DNODE_GYP_MODULE_NAME=epoll' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-DELECTRON_ENSURE_CONFIG_GYPI' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-DUSING_ELECTRON_CONFIG_GYPI' '-DV8_COMPRESS_POINTERS' '-DV8_COMPRESS_POINTERS_IN_SHARED_CAGE' '-DV8_ENABLE_SANDBOX' '-DV8_31BIT_SMIS_ON_64BIT_ARCH' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DOPENSSL_NO_ASM' '-DBUILDING_NODE_EXTENSION' -I/home/pi/.electron-gyp/22.0.0/include/node -I/home/pi/.electron-gyp/22.0.0/src -I/home/pi/.electron-gyp/22.0.0/deps/openssl/config -I/home/pi/.electron-gyp/22.0.0/deps/openssl/openssl/include -I/home/pi/.electron-gyp/22.0.0/deps/uv/include -I/home/pi/.electron-gyp/22.0.0/deps/zlib -I/home/pi/.electron-gyp/22.0.0/deps/v8/include -I../../nan  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -Wno-deprecated-declarations -Wno-cast-function-type -O3 -fno-omit-frame-pointer -fno-rtti -fno-exceptions -std=gnu++17 -MMD -MF ./Release/.deps/Release/obj.target/epoll/src/epoll.o.d.raw  -std=c++17 -c
              ⠴ Building module: epoll, Completed: 0In file included from /home/pi/.electron-gyp/22.0.0/include/node/v8-local-handle.h:12,
                               from /home/pi/.electron-gyp/22.0.0/include/node/v8-array-buffer.h:12,
                               from /home/pi/.electron-gyp/22.0.0/include/node/v8.h:24,
                               from ../src/epoll.cc:11:
              /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:124:62: warning: left shift count >= width of type [-Wshift-count-overflow]
               constexpr size_t kPtrComprCageReservationSize = size_t{1} << 32;
              /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:124:59: error: right operand of shift expression ‘(1 << 32)’ is >= than the precision of the left operand [-fpermissive]
              /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:125:60: warning: left shift count >= width of type [-Wshift-count-overflow]
               constexpr size_t kPtrComprCageBaseAlignment = size_t{1} << 32;
              /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:125:57: error: right operand of shift expression ‘(1 << 32)’ is >= than the precision of the left operand [-fpermissive]
              /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:128:27: error: static assertion failed: Pointer compression can be enabled only for 64-bit architectures
              /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:186:38: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘1099511627776’ to ‘0’ [-Woverflow]
               constexpr size_t kSandboxSize = 1ULL << kSandboxSizeLog2;
              /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:204:50: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘34359738368’ to ‘0’ [-Woverflow]
               constexpr size_t kSandboxGuardRegionSize = 32ULL * GB;
              /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:220:56: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘8589934592’ to ‘0’ [-Woverflow]
               constexpr size_t kSandboxMinimumReservationSize = 8ULL * GB;
              /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:230:60: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘34359738367’ to ‘4294967295’ [-Woverflow]
               constexpr size_t kMaxSafeBufferSizeForSandbox = 32ULL * GB - 1;
              /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:231:44: error: static assertion failed: The maximum allowed buffer size must not be larger than the sandbox's guard regions
               static_assert(kMaxSafeBufferSizeForSandbox <= kSandboxGuardRegionSize,
              /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:236:48: error: static assertion failed: The maximum size of a BoundedSize must be synchronized with the kMaxSafeBufferSizeForSandbox
               static_assert(1ULL << (64 - kBoundedSizeShift) ==
                                 kMaxSafeBufferSizeForSandbox + 1,
              /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:260:56: error: static assertion failed: kExternalPointerTableReservationSize and kExternalPointerIndexShift don't match
               static_assert((1 << (32 - kExternalPointerIndexShift)) == kMaxExternalPointers,
              ⠴ Building module: epoll, Completed: 0make: *** [epoll.target.mk:129: Release/obj.target/epoll/src/epoll.o] Fehler 1
              make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build“ wird verlassen
              ✖ Rebuild Failed
              An unhandled error occurred inside electron-rebuild
              node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll'.
              For more information, rerun with the DEBUG environment variable set to "electron-rebuild".
              Error: `make` failed with exit code: 2
              Error: node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll'.
                  at NodeGyp.rebuildModule (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/module-type/node-gyp.js:120:19)
                  at processTicksAndRejections (node:internal/process/task_queues:96:5)
                  at async ModuleRebuilder.rebuildNodeGypModule (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/module-rebuilder.js:98:9)
                  at async ModuleRebuilder.rebuild (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/module-rebuilder.js:128:14)
                  at async Rebuilder.rebuildModuleAt (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/rebuild.js:149:13)
                  at async Rebuilder.rebuild (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/rebuild.js:112:17)
                  at async /home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/cli.js:158:9
              npm ERR! code 255
              npm ERR! path /home/pi/MagicMirror/modules/MMM-Buttons
              npm ERR! command failed
              npm ERR! command sh -c ./postinstall
              npm ERR!     /home/pi/.npm/_logs/2023-01-07T11_55_30_111Z-debug-0.log
              Edit: I will try to re-setup my mirror today to make sure no old things are messing up the installation but it will take a moment.
                wishmaster270 Module Developer @wishmaster270
                New installation, new luck!
                Everything works well now and i think if found the reason for the problems.
                As i wrote earlier i am running TeleFrame on the same Pi with MagicMirror. This time i installed TeleFrame manually instead of with the installer as i saw that the automatic installer of Teleframe installs a global version of Electron and adds architecture settings to the “.profile” file of the user.
                  @wishmaster270 cool. thx for feedback
                  don’t know Teleframe.
                  • KristjanESPERANTOK Offline
                    KristjanESPERANTO Module Developer @sdetweil
                    The problems on my machine are obviously of a different nature. I’ll investigate that later.
                    For the original issue it should be worth using @electron/rebuild instead of magicmirror-rebuild or electron-rebuild. I tested it in a virtual machine and it works great. Here is my solution which is less invasive:
                    https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications/pull/7
                    What do you think?
                    S wishmaster270W 2 Replies Last reply Reply Quote 0
                      sdetweil @KristjanESPERANTO
                      @KristjanESPERANTO my postinstall script uses electron-rebuild
                      his development branch
                        Yes, but @electron/rebuild is the successor of electron-rebuild. And the “trick” in the postinstall script seems not necessary at all.
                          wishmaster270 Module Developer @KristjanESPERANTO
                          @KristjanESPERANTO
                          Hi and thank you for contributing. I confirm that changing to magicmirror-rebuild did not make things batter but worse. I now followed the suggestion of @sdetweil and implemented his postinstall script. Things are working perfectly now and should work in future releases, too.
                          I merged the new changes to the master a few minutes ago and released version 0.0.7 of MMM-GPIO-Notifications. I will implement this approach in my other modules, too.
                            KristjanESPERANTO Module Developer @wishmaster270
                            @wishmaster270 OK, you’re welcome.
                            Since the thread is also for other developers: I recommend considering my approach, as I consider the other approach (installing to a higher-level directory) to be more error-prone. But it’s a creative workaround.
                              @KristjanESPERANTO
                              The problem with installing it in the module directory is that we need to compile the library against the electron version installed in the MagicMirror project.
                              If electron-rebuild is installed in the module directory it might fail to detect the right electron version (which was the cause of the rebuild problems in the past).
                              So the right way is to install electron-rebuild in the same project as electron and call it from there.
                              It might be worth to think about adding it as a dependency in the main project.
                              KristjanESPERANTOK karsten13K 2 Replies Last reply Reply Quote 1
                                @wishmaster270 Okay, thanks for the explanation! I haven’t been able to read that anywhere in such clear words and I haven’t dealt with the past problems. Then I withdraw my recommendation because I lack the overview.
                                  @KristjanESPERANTO ah I see
                                  haven’t heard of @electron/rebuild
                                  • karsten13K Offline
                                    karsten13 @wishmaster270
                                    installing module stuff in the node_modules folder of mm is a hack and will not work out of the box with a docker setup because this folder is only in the container (you have to map it on the host to get changes there persistent)
                                    in this case may the best solution
                                      sdetweil @karsten13
                                      @karsten13 yes, that’s what I think we come to but doesn’t help any existing broken modules
                                        sdetweil @karsten13
                                        @karsten13 docker is a pita with this stuff. too much/not enough in the container. which is supposed to be immutable.
                                          @sdetweil As a soft step, the broken modules could switch to @electron/rebuild. This should also work for docker.
                                          wishmaster270W S 2 Replies Last reply Reply Quote 0
                                            @KristjanESPERANTO
                                            I have a docker installation running for development here on my notebook.
                                            Everytime a module needs “npm install” I exec to the container and run the command in the container cause there will be called the correct npm and node version in the container and not the ones I currently use on my notebook.
                                            In this case the directory structure is the same as with a locally installed MagicMirror and the postinstall script will work as excepted.
                                            karsten13K 1 Reply Last reply Reply Quote 1
                                            • 2 / 3
