    electron-rebuild problems with MagicMirror 2.22.0
    53 Posts 5 Posters 27.9k Views 6 Watching
      sdetweil @KristjanESPERANTO
      @KristjanESPERANTO hm…
      my laptop uname
      Linux galliumos 4.16.18-galliumos #1 SMP PREEMPT Sun Jun 23 04:14:45 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
        @KristjanESPERANTO but it didn’t execute the postinstall script…
        tried to build without it… and it WILL fail without using electron-rebuild
        what npm version is this?
        • KristjanESPERANTOK Offline
          @sdetweil npm -v: 8.19.2
            @KristjanESPERANTO weird
            sam@galliumos:~/MagicMirror/modules/MMM-Buttons$ npm -v
            8.19.2
            sam@galliumos:~/MagicMirror/modules/MMM-Buttons$ npm install --omit=dev --no-fund --no-audit
            > Magic-Mirror-Module-Buttons@1.0.0 postinstall
            > ./postinstall
            ⠋ Building module: epoll, Completed: 0make: Entering directory '/home/sam/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
              CXX(target) Release/obj.target/epoll/src/epoll.o
            ⠼ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
            ⠧ Building module: epoll, Completed: 0  COPY Release/epoll.node
            ⠇ Building module: epoll, Completed: 0make: Leaving directory '/home/sam/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
            ✔ Rebuild Complete
            added 6 packages in 15s
            • karsten13K Offline
              karsten13 @sdetweil
              strange, I did npm install in the MMM-Buttons folder.
              More info (running in a docker container):
              node@raspberrypi:/opt/magic_mirror$ npx node-gyp -v
              v9.3.1
              node@raspberrypi:/opt/magic_mirror$ node -v
              v19.3.0
              node@raspberrypi:/opt/magic_mirror$ uname -a
              Linux raspberrypi 5.15.76-v7l+ #1597 SMP Fri Nov 4 12:14:58 GMT 2022 armv7l GNU/Linux
              node@raspberrypi:/opt/magic_mirror$ cat /etc/os-release
              PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
              NAME="Debian GNU/Linux"
              VERSION_ID="11"
              VERSION="11 (bullseye)"
              VERSION_CODENAME=bullseye
              ID=debian
              HOME_URL="https://www.debian.org/"
              SUPPORT_URL="https://www.debian.org/support"
              BUG_REPORT_URL="https://bugs.debian.org/"
              node@raspberrypi:/opt/magic_mirror$ npm -v
              9.2.0
                karsten13 @sdetweil
                @sdetweil said in electron-rebuild problems with MagicMirror 2.22.0:
                thats x86_64, not arm32v7, totally different concerning compiling stuff which is done in electron-rebuild …
                  sdetweil @karsten13
                  @karsten13 his was x86_64… (edit: i see his is amd64, oops, tldr;l!)…
                  I will see if I can get a vm on my new amd64 chromebook… had it til I powered off…
                  but I built on buster and bullseye on pi4 also … MM version 2.22
                  but his didn’t execute the postinstall script
                  karsten13K 2 Replies Last reply Reply Quote 0
                    karsten13 @sdetweil
                    his was x86_64…
                    he wrote “I use a fully patched Raspberry OS Bullseye 32Bit.” so I think this is arm32v7
                    strange
                      sdetweil @karsten13
                      @karsten13 yeh, his says
                      kristjan@debian:~/Infomonitor/MagicMirror/modules/MMM-Buttons$ uname -r
                      5.10.0-20-amd64
                      so not 32 bit.
                      @KristjanESPERANTO
                      can you go to the MMM-Buttons folder and do
                      ./postinstall
                        karsten13 @sdetweil
                        so not 32 bit.
                        he wrote 32 bit
                        x86_64=amd64: No Raspian OS
                        arm32v7=arm=aarch32: Raspian OS 32-bit
                        arm64v8=arm64=aarch64: Raspian OS 64-bit
                          sdetweil @karsten13
                          @karsten13 yeh, haven’t tested on arm64 on pi for a while.
                          but its still an npm problem if it doesn’t run the postinstall
                          flashing image now
                          worked fine
                          pi@raspberrypi:~/MagicMirror/modules $ uname -a
                          Linux raspberrypi 5.15.61-v8+ #1579 SMP PREEMPT Fri Aug 26 11:16:44 BST 2022 aarch64 GNU/Linux
                          pi@raspberrypi:~/MagicMirror/modules $ node -v
                          v16.19.0
                          pi@raspberrypi:~/MagicMirror/modules $ npm -v
                          8.19.3
                          pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/sdetweil/MMM-Buttons.git
                          Cloning into 'MMM-Buttons'...
                          remote: Enumerating objects: 56, done.
                          remote: Counting objects: 100% (4/4), done.
                          remote: Compressing objects: 100% (4/4), done.
                          remote: Total 56 (delta 0), reused 2 (delta 0), pack-reused 52
                          Receiving objects: 100% (56/56), 11.86 KiB | 3.95 MiB/s, done.
                          Resolving deltas: 100% (25/25), done.
                          pi@raspberrypi:~/MagicMirror/modules $ cd MMM-Buttons/
                          pi@raspberrypi:~/MagicMirror/modules/MMM-Buttons $ npm install --omit=dev --no-audit --no-fund
                          > ./postinstall
                          /home/pi/MagicMirror/modules/MMM-Buttons
                          ⠙ Building module: epoll, Completed: 0make: Entering directory '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
                          ⠸ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                          make: Leaving directory '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
                          ✔ Rebuild Complete
                          added 6 packages in 2m
                          • wishmaster270W Offline
                            wishmaster270 Module Developer @sdetweil
                            @sdetweil Sorry, had no Internet connection for a few hours.
                            The version of my GPIO module in the development branch uses the postinstall script and there is where the error happens.
                            It is a Raspberry 4 in my case with 32bit Bullseye.
                            It is
                            npm 9.2.0
                            node 16.19.0
                            arch armv7l
                            in my case.
                              sdetweil @wishmaster270
                              @wishmaster270 hm, I modified your module and it works fine… will check your branch
                              I just copy the postinstall script and change package.json
                              intel x86-64 ok
                              base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ git checkout development
                              branch 'development' set up to track 'origin/development'.
                              Switched to a new branch 'development'
                              (base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ ls
                              examples  LICENSE  MMM-GPIO-Notifications.js  node_helper.js  package.json  postinstall  README.md
                              (base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ nano package.json
                              (base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ npm install --omit=dev --no-audit --no-fund
                              > MMM-GPIO-Notifications@0.0.6 postinstall
                              > ./postinstall
                              /home/sam/MagicMirror/modules/MMM-GPIO-Notifications
                              ⠧ Building module: epoll, Completed: 0make: Entering directory '/home/sam/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                              ⠇ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                              make: Leaving directory '/home/sam/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                              ✔ Rebuild Complete
                              added 6 packages in 10s
                              pi 64 aarch64 ok
                              (base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ ssh pi@192.168.2.44
                              pi@192.168.2.44's password:
                              The programs included with the Debian GNU/Linux system are free software;
                              the exact distribution terms for each program are described in the
                              individual files in /usr/share/doc/*/copyright.
                              Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                              permitted by applicable law.
                              Last login: Fri Jan  6 14:10:59 2023 from 192.168.2.106
                              pi@raspberrypi:~ $ pm2 stop all
                              [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                              [PM2] [MagicMirror](0) ✓
                              │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                              │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                              pi@raspberrypi:~ $ cd MagicMirror/modules
                              pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications.git
                              Cloning into 'MMM-GPIO-Notifications'...
                              remote: Enumerating objects: 159, done.
                              remote: Counting objects: 100% (42/42), done.
                              remote: Compressing objects: 100% (34/34), done.
                              remote: Total 159 (delta 17), reused 22 (delta 8), pack-reused 117
                              Receiving objects: 100% (159/159), 744.45 KiB | 3.48 MiB/s, done.
                              Resolving deltas: 100% (74/74), done.
                              pi@raspberrypi:~/MagicMirror/modules $ cd MMM-GPIO-Notifications/
                              pi@raspberrypi:~/MagicMirror/modules/MMM-GPIO-Notifications $ git checkout development
                              Branch 'development' set up to track remote branch 'development' from 'origin'.
                              pi@raspberrypi:~/MagicMirror/modules/MMM-GPIO-Notifications $ npm install --omit=dev --no-audit --no-fund
                              > ./postinstall
                              ⠋ Building module: epoll, Completed: 0make: Entering directory '/home/pi/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                              ⠹ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                              ⠦ Building module: epoll, Completed: 0  COPY Release/epoll.node
                              make: Leaving directory '/home/pi/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                              ✔ Rebuild Complete
                              pi@raspberrypi:~/MagicMirror/modules/MMM-GPIO-Notifications $ exit
                              pi 32bit buster ok
                              pi@raspberrypi42:~ $ cd MagicMirror/modules/
                              pi@raspberrypi42:~/MagicMirror/modules $ git clone https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications.git
                              Receiving objects: 100% (159/159), 744.45 KiB | 73.00 KiB/s, done.
                              pi@raspberrypi42:~/MagicMirror/modules $ cd MMM-GPIO-Notifications/
                              pi@raspberrypi42:~/MagicMirror/modules/MMM-GPIO-Notifications $ git checkout develoment
                              error: pathspec 'develoment' did not match any file(s) known to git
                              pi@raspberrypi42:~/MagicMirror/modules/MMM-GPIO-Notifications $ git checkout development
                              pi@raspberrypi42:~/MagicMirror/modules/MMM-GPIO-Notifications $ npm install --omit=dev --no-audit --no-fund
                              > ./postinstall
                              ⠙ Building module: epoll, Completed: 0make: Entering directory '/home/pi/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                              ⠙ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                              ⠼ Building module: epoll, Completed: 0  COPY Release/epoll.node
                              ✔ Rebuild Complete
                              added 6 packages in 14s
                              pi@raspberrypi42:~/MagicMirror/modules/MMM-GPIO-Notifications $ lsb_release -a
                              No LSB modules are available.
                              Distributor ID:	Raspbian
                              Description:	Raspbian GNU/Linux 10 (buster)
                              Release:	10
                              Codename:	buster
                              32 bit bullseye, ok
                              fribble@raspberrypi4:~ $ cd MagicMirror/modules/
                              fribble@raspberrypi4:~/MagicMirror/modules $ lsb_release -a
                              Description:	Raspbian GNU/Linux 11 (bullseye)
                              Release:	11
                              Codename:	bullseye
                              fribble@raspberrypi4:~/MagicMirror/modules $ git clone https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications.git
                              Receiving objects: 100% (159/159), 744.45 KiB | 3.26 MiB/s, done.
                              fribble@raspberrypi4:~/MagicMirror/modules $ cd MMM-GPIO-Notifications/
                              fribble@raspberrypi4:~/MagicMirror/modules/MMM-GPIO-Notifications $ git checkout development
                              fribble@raspberrypi4:~/MagicMirror/modules/MMM-GPIO-Notifications $ npm install --omit=dev --no-audit --no-fund
                              > ./postinstall
                              ⠸ Building module: epoll, Completed: 0make: Entering directory '/home/fribble/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                              ⠴ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                              ⠏ Building module: epoll, Completed: 0  COPY Release/epoll.node
                              make: Leaving directory '/home/fribble/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                              ✔ Rebuild Complete
                              added 6 packages in 21s
                                @wishmaster270 said in electron-rebuild problems with MagicMirror 2.22.0:
                                kApiSystemPointerSize == kApiInt64Size,
                                this looks like a compile header mismatch
                                make sure u delete the electron-rebuild if its in your module folder
                                AND the one in MagicMirror/node_modules in case there is a downlevel version,
                                OR change the postinstall to always install it. vs checking if present and running the installed version…
                                  Today i started a new approach and removed the “node_modules” folder of MagicMirror before the update to make sure no other electron-rebuild packages are installed.
                                  As i do have a second electron app running on my mirror (TeleFrame) is stopped this application and removed the “/home/pi/.electron-gyp” folder to make sure everything is clean before the update.
                                  I then did the update with your script and the “npm install” step of my MMM-GPIO-Notifications module fails.
                                  I cloned your “MMM-Buttons” module and tried to install only this module but i get the same compile error. I enabled the DEBUG flag. Maybe you see something i do not see but it looks like the correct electron-rebuild version is used:
                                  pi@mirror-eg:~/MagicMirror/modules/MMM-Buttons $ npm install
                                  > ./postinstall
                                  ⠋ Searching dependency tree  electron-rebuild rebuilding with args: [Arguments] {
                                    '0': {
                                      buildPath: '/home/pi/MagicMirror/modules/MMM-Buttons',
                                      electronVersion: '22.0.0',
                                      arch: 'arm',
                                      extraModules: [],
                                      onlyModules: null,
                                      force: undefined,
                                      headerURL: undefined,
                                      types: [ 'prod', 'optional' ],
                                      mode: undefined,
                                      debug: undefined,
                                      prebuildTagPrefix: 'v',
                                      forceABI: undefined,
                                      useElectronClang: false,
                                      disablePreGypCopy: false,
                                      projectRootPath: '/home/pi/MagicMirror/modules/MMM-Buttons'
                                  } +0ms
                                    electron-rebuild rebuilding with args: /home/pi/MagicMirror/modules/MMM-Buttons 22.0.0 arm Set(0) {} false https://www.electronjs.org/headers [ 'prod', 'optional' ] false +8ms
                                    electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/onoff +0ms
                                    electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll +4ms
                                    electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/lodash.debounce +1ms
                                    electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/bindings +2ms
                                    electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/nan +1ms
                                    electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/file-uri-to-path +1ms
                                    electron-rebuild identified prod deps: Set(0) {
                                    onoff: true,
                                    epoll: true,
                                    'lodash.debounce': true,
                                    bindings: true,
                                    nan: true,
                                    'file-uri-to-path': true
                                  } +1ms
                                    electron-rebuild scanning: /home/pi/MagicMirror/modules/MMM-Buttons/node_modules +5ms
                                    electron-rebuild rebuilding epoll with args [
                                    'node',
                                    'node-gyp',
                                    'rebuild',
                                    '--runtime=electron',
                                    '--target=22.0.0',
                                    '--arch=arm',
                                    '--dist-url=https://www.electronjs.org/headers',
                                    '--build-from-source',
                                    '--verbose'
                                  ] +0ms
                                  gyp verb command rebuild []
                                  gyp verb command clean []
                                  gyp verb clean removing "build" directory
                                  ⠙ Building module: epoll, Completed: 0gyp verb command configure []
                                  gyp verb download using dist-url https://www.electronjs.org/headers
                                  gyp verb find Python Python is not set from command line or npm configuration
                                  gyp verb find Python Python is not set from environment variable PYTHON
                                  gyp verb find Python checking if "python3" can be used
                                  gyp verb find Python - executing "python3" to get executable path
                                  ⠹ Building module: epoll, Completed: 0gyp verb find Python - executable path is "/usr/bin/python3"
                                  gyp verb find Python - executing "/usr/bin/python3" to get version
                                  ⠸ Building module: epoll, Completed: 0gyp verb find Python - version is "3.7.3"
                                  gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3"
                                  gyp verb get node dir compiling against --target node version: 22.0.0
                                  gyp verb command install [ '22.0.0' ]
                                  gyp verb install input version string "22.0.0"
                                  gyp verb install installing version: 22.0.0
                                  gyp verb install --ensure was passed, so won't reinstall if already installed
                                  ⠼ Building module: epoll, Completed: 0gyp verb install version is already installed, need to check "installVersion"
                                  gyp verb got "installVersion" 9
                                  gyp verb needs "installVersion" 9
                                  gyp verb install version is good
                                  gyp verb get node dir target node version installed: 22.0.0
                                  gyp verb build dir attempting to create "build" dir: /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build
                                  gyp verb build dir "build" dir needed to be created? Yes
                                  gyp verb python symlink creating symlink to "/usr/bin/python3" at "/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/node_gyp_bins/python3"
                                  gyp verb build/config.gypi creating config file
                                  gyp verb build/config.gypi writing out config file: /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/config.gypi
                                  gyp verb config.gypi checking for gypi file: /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/config.gypi
                                  gyp verb common.gypi checking for gypi file: /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/common.gypi
                                  gyp verb gyp gyp format was not specified; forcing "make"
                                  gyp info spawn /usr/bin/python3
                                  gyp info spawn args [
                                  gyp info spawn args   '/home/pi/MagicMirror/node_modules/node-gyp/gyp/gyp_main.py',
                                  gyp info spawn args   'binding.gyp',
                                  gyp info spawn args   '-f',
                                  gyp info spawn args   'make',
                                  gyp info spawn args   '-I',
                                  gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/config.gypi',
                                  gyp info spawn args   '/home/pi/MagicMirror/node_modules/node-gyp/addon.gypi',
                                  gyp info spawn args   '/home/pi/.electron-gyp/22.0.0/include/node/common.gypi',
                                  gyp info spawn args   '-Dlibrary=shared_library',
                                  gyp info spawn args   '-Dvisibility=default',
                                  gyp info spawn args   '-Dnode_root_dir=/home/pi/.electron-gyp/22.0.0',
                                  gyp info spawn args   '-Dnode_gyp_dir=/home/pi/MagicMirror/node_modules/node-gyp',
                                  gyp info spawn args   '-Dnode_lib_file=/home/pi/.electron-gyp/22.0.0/<(target_arch)/node.lib',
                                  gyp info spawn args   '-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll',
                                  gyp info spawn args   '-Dnode_engine=v8',
                                  gyp info spawn args   '--depth=.',
                                  gyp info spawn args   '--no-parallel',
                                  gyp info spawn args   '--generator-output',
                                  gyp info spawn args   'build',
                                  gyp info spawn args   '-Goutput_dir=.'
                                  gyp info spawn args ]
                                  ⠙ Building module: epoll, Completed: 0gyp verb command build []
                                  gyp verb build type Release
                                  gyp verb architecture armv7l
                                  gyp verb node dev dir /home/pi/.electron-gyp/22.0.0
                                  gyp verb `which` succeeded for `make` /usr/bin/make
                                  gyp verb bin symlinks adding symlinks (such as Python), at "/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/node_gyp_bins", to PATH
                                  gyp info spawn make
                                  gyp info spawn args [ 'V=1', 'BUILDTYPE=Release', '-C', 'build' ]
                                  make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build“ wird betreten
                                    g++ -o Release/obj.target/epoll/src/epoll.o ../src/epoll.cc '-DNODE_GYP_MODULE_NAME=epoll' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-DELECTRON_ENSURE_CONFIG_GYPI' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-DUSING_ELECTRON_CONFIG_GYPI' '-DV8_COMPRESS_POINTERS' '-DV8_COMPRESS_POINTERS_IN_SHARED_CAGE' '-DV8_ENABLE_SANDBOX' '-DV8_31BIT_SMIS_ON_64BIT_ARCH' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DOPENSSL_NO_ASM' '-DBUILDING_NODE_EXTENSION' -I/home/pi/.electron-gyp/22.0.0/include/node -I/home/pi/.electron-gyp/22.0.0/src -I/home/pi/.electron-gyp/22.0.0/deps/openssl/config -I/home/pi/.electron-gyp/22.0.0/deps/openssl/openssl/include -I/home/pi/.electron-gyp/22.0.0/deps/uv/include -I/home/pi/.electron-gyp/22.0.0/deps/zlib -I/home/pi/.electron-gyp/22.0.0/deps/v8/include -I../../nan  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -Wno-deprecated-declarations -Wno-cast-function-type -O3 -fno-omit-frame-pointer -fno-rtti -fno-exceptions -std=gnu++17 -MMD -MF ./Release/.deps/Release/obj.target/epoll/src/epoll.o.d.raw  -std=c++17 -c
                                  ⠴ Building module: epoll, Completed: 0In file included from /home/pi/.electron-gyp/22.0.0/include/node/v8-local-handle.h:12,
                                                   from /home/pi/.electron-gyp/22.0.0/include/node/v8-array-buffer.h:12,
                                                   from /home/pi/.electron-gyp/22.0.0/include/node/v8.h:24,
                                                   from ../src/epoll.cc:11:
                                  /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:124:62: warning: left shift count >= width of type [-Wshift-count-overflow]
                                   constexpr size_t kPtrComprCageReservationSize = size_t{1} << 32;
                                  /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:124:59: error: right operand of shift expression ‘(1 << 32)’ is >= than the precision of the left operand [-fpermissive]
                                  /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:125:60: warning: left shift count >= width of type [-Wshift-count-overflow]
                                   constexpr size_t kPtrComprCageBaseAlignment = size_t{1} << 32;
                                  /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:125:57: error: right operand of shift expression ‘(1 << 32)’ is >= than the precision of the left operand [-fpermissive]
                                  /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:128:27: error: static assertion failed: Pointer compression can be enabled only for 64-bit architectures
                                  /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:186:38: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘1099511627776’ to ‘0’ [-Woverflow]
                                   constexpr size_t kSandboxSize = 1ULL << kSandboxSizeLog2;
                                  /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:204:50: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘34359738368’ to ‘0’ [-Woverflow]
                                   constexpr size_t kSandboxGuardRegionSize = 32ULL * GB;
                                  /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:220:56: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘8589934592’ to ‘0’ [-Woverflow]
                                   constexpr size_t kSandboxMinimumReservationSize = 8ULL * GB;
                                  /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:230:60: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘34359738367’ to ‘4294967295’ [-Woverflow]
                                   constexpr size_t kMaxSafeBufferSizeForSandbox = 32ULL * GB - 1;
                                  /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:231:44: error: static assertion failed: The maximum allowed buffer size must not be larger than the sandbox's guard regions
                                   static_assert(kMaxSafeBufferSizeForSandbox <= kSandboxGuardRegionSize,
                                  /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:236:48: error: static assertion failed: The maximum size of a BoundedSize must be synchronized with the kMaxSafeBufferSizeForSandbox
                                   static_assert(1ULL << (64 - kBoundedSizeShift) ==
                                                     kMaxSafeBufferSizeForSandbox + 1,
                                  /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:260:56: error: static assertion failed: kExternalPointerTableReservationSize and kExternalPointerIndexShift don't match
                                   static_assert((1 << (32 - kExternalPointerIndexShift)) == kMaxExternalPointers,
                                  ⠴ Building module: epoll, Completed: 0make: *** [epoll.target.mk:129: Release/obj.target/epoll/src/epoll.o] Fehler 1
                                  make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build“ wird verlassen
                                  ✖ Rebuild Failed
                                  An unhandled error occurred inside electron-rebuild
                                  node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll'.
                                  For more information, rerun with the DEBUG environment variable set to "electron-rebuild".
                                  Error: `make` failed with exit code: 2
                                  Error: node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll'.
                                      at NodeGyp.rebuildModule (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/module-type/node-gyp.js:120:19)
                                      at processTicksAndRejections (node:internal/process/task_queues:96:5)
                                      at async ModuleRebuilder.rebuildNodeGypModule (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/module-rebuilder.js:98:9)
                                      at async ModuleRebuilder.rebuild (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/module-rebuilder.js:128:14)
                                      at async Rebuilder.rebuildModuleAt (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/rebuild.js:149:13)
                                      at async Rebuilder.rebuild (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/rebuild.js:112:17)
                                      at async /home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/cli.js:158:9
                                  npm ERR! code 255
                                  npm ERR! path /home/pi/MagicMirror/modules/MMM-Buttons
                                  npm ERR! command failed
                                  npm ERR! command sh -c ./postinstall
                                  npm ERR!     /home/pi/.npm/_logs/2023-01-07T11_55_30_111Z-debug-0.log
                                  Edit: I will try to re-setup my mirror today to make sure no old things are messing up the installation but it will take a moment.
                                    wishmaster270 Module Developer @wishmaster270
                                    New installation, new luck!
                                    Everything works well now and i think if found the reason for the problems.
                                    As i wrote earlier i am running TeleFrame on the same Pi with MagicMirror. This time i installed TeleFrame manually instead of with the installer as i saw that the automatic installer of Teleframe installs a global version of Electron and adds architecture settings to the “.profile” file of the user.
                                      @wishmaster270 cool. thx for feedback
                                      don’t know Teleframe.
                                        The problems on my machine are obviously of a different nature. I’ll investigate that later.
                                        For the original issue it should be worth using @electron/rebuild instead of magicmirror-rebuild or electron-rebuild. I tested it in a virtual machine and it works great. Here is my solution which is less invasive:
                                        https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications/pull/7
                                        What do you think?
                                        S wishmaster270W 2 Replies Last reply Reply Quote 0
                                          @KristjanESPERANTO my postinstall script uses electron-rebuild
                                          his development branch
                                            Yes, but @electron/rebuild is the successor of electron-rebuild. And the “trick” in the postinstall script seems not necessary at all.
