    electron-rebuild problems with MagicMirror 2.22.0
    53 Posts 5 Posters 21.4k Views 6 Watching
      @sdetweil and it succeeded on pi4 w bullseye… I also tested with my
      upgrade script and backup/restore
      and both those executed and did rebuild on the modules… (using the postinstall script)
      • karsten13K Online
        karsten13 @sdetweil
        node@raspberrypi:/opt/magic_mirror/modules$ git clone https://github.com/sdetweil/MMM-Buttons.git
        Cloning into 'MMM-Buttons'...
        remote: Enumerating objects: 56, done.
        remote: Counting objects: 100% (4/4), done.
        remote: Compressing objects: 100% (4/4), done.
        remote: Total 56 (delta 0), reused 2 (delta 0), pack-reused 52
        Receiving objects: 100% (56/56), 11.86 KiB | 1.69 MiB/s, done.
        Resolving deltas: 100% (25/25), done.
        node@raspberrypi:/opt/magic_mirror/modules$ cd MMM-Buttons/
        node@raspberrypi:/opt/magic_mirror/modules/MMM-Buttons$ ls -la
        total 40
        drwxr-xr-x 3 node node 4096 Jan  6 19:39 .
        drwxr-xr-x 5 node node 4096 Jan  6 19:39 ..
        drwxr-xr-x 8 node node 4096 Jan  6 19:39 .git
        -rw-r--r-- 1 node node  530 Jan  6 19:39 CHANGELOG.md
        -rw-r--r-- 1 node node 3416 Jan  6 19:39 MMM-Buttons.js
        -rw-r--r-- 1 node node 5725 Jan  6 19:39 README.md
        -rw-r--r-- 1 node node 2778 Jan  6 19:39 node_helper.js
        -rw-r--r-- 1 node node  693 Jan  6 19:39 package.json
        -rwxr-xr-x 1 node node  179 Jan  6 19:39 postinstall
        node@raspberrypi:/opt/magic_mirror/modules/MMM-Buttons$ npm install
        > Magic-Mirror-Module-Buttons@1.0.0 postinstall
        > ./postinstall
        ⠧ Building module: epoll, Completed: 0make: Entering directory '/opt/magic_mirror/modules/MMM-Buttons/node_modules/epoll/build'
          CXX(target) Release/obj.target/epoll/src/epoll.o
        ⠙ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
        ⠼ Building module: epoll, Completed: 0  COPY Release/epoll.node
        make: Leaving directory '/opt/magic_mirror/modules/MMM-Buttons/node_modules/epoll/build'
        ✔ Rebuild Complete
        added 6 packages, and audited 7 packages in 2m
        found 0 vulnerabilities
          sdetweil @karsten13
          @karsten13 yep, looks good…
          • KristjanESPERANTOK Offline
            For me it looks like this:
            kristjan@debian:~/Infomonitor/MagicMirror/modules$ git clone https://github.com/sdetweil/MMM-Buttons.git
            kristjan@debian:~/Infomonitor/MagicMirror/modules$ cd MMM-Buttons/
            kristjan@debian:~/Infomonitor/MagicMirror/modules/MMM-Buttons$ npm install
            npm ERR! code 1
            npm ERR! path /home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll
            npm ERR! command failed
            npm ERR! command sh -c -- node-gyp rebuild
            npm ERR! make: Entering directory '/home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
            npm ERR!   CXX(target) Release/obj.target/epoll/src/epoll.o
            npm ERR!   SOLINK_MODULE(target) Release/obj.target/epoll.node
            npm ERR! make: Leaving directory '/home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
            npm ERR! gyp info it worked if it ends with ok
            npm ERR! gyp info using node-gyp@9.3.1
            npm ERR! gyp info using node@16.18.0 | linux | x64
            npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
            npm ERR! gyp info spawn /usr/bin/python3
            npm ERR! gyp info spawn args [
            npm ERR! gyp info spawn args   '/home/kristjan/Infomonitor/MagicMirror/node_modules/node-gyp/gyp/gyp_main.py',
            npm ERR! gyp info spawn args   'binding.gyp',
            npm ERR! gyp info spawn args   '-f',
            npm ERR! gyp info spawn args   'make',
            npm ERR! gyp info spawn args   '-I',
            npm ERR! gyp info spawn args   '/home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/config.gypi',
            npm ERR! gyp info spawn args   '/home/kristjan/Infomonitor/MagicMirror/node_modules/node-gyp/addon.gypi',
            npm ERR! gyp info spawn args   '/home/kristjan/.cache/node-gyp/16.18.0/include/node/common.gypi',
            npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
            npm ERR! gyp info spawn args   '-Dvisibility=default',
            npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/kristjan/.cache/node-gyp/16.18.0',
            npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/home/kristjan/Infomonitor/MagicMirror/node_modules/node-gyp',
            npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/kristjan/.cache/node-gyp/16.18.0/<(target_arch)/node.lib',
            npm ERR! gyp info spawn args   '-Dmodule_root_dir=/home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll',
            npm ERR! gyp info spawn args   '-Dnode_engine=v8',
            npm ERR! gyp info spawn args   '--depth=.',
            npm ERR! gyp info spawn args   '--no-parallel',
            npm ERR! gyp info spawn args   '--generator-output',
            npm ERR! gyp info spawn args   'build',
            npm ERR! gyp info spawn args   '-Goutput_dir=.'
            npm ERR! gyp info spawn args ]
            npm ERR! gyp info spawn make
            npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
            npm ERR! /usr/bin/ld: /lib/x86_64-linux-gnu/libm.so.6: unknown type [0x13] section `.relr.dyn'
            npm ERR! /usr/bin/ld: skipping incompatible /lib/x86_64-linux-gnu/libm.so.6 when searching for /lib/x86_64-linux-gnu/libm.so.6
            npm ERR! /usr/bin/ld: cannot find /lib/x86_64-linux-gnu/libm.so.6
            npm ERR! /usr/bin/ld: /lib/x86_64-linux-gnu/libmvec.so.1: unknown type [0x13] section `.relr.dyn'
            npm ERR! /usr/bin/ld: skipping incompatible /lib/x86_64-linux-gnu/libmvec.so.1 when searching for /lib/x86_64-linux-gnu/libmvec.so.1
            npm ERR! /usr/bin/ld: cannot find /lib/x86_64-linux-gnu/libmvec.so.1
            npm ERR! collect2: error: ld returned 1 exit status
            npm ERR! make: *** [epoll.target.mk:145: Release/obj.target/epoll.node] Error 1
            npm ERR! gyp ERR! build error
            npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
            npm ERR! gyp ERR! stack     at ChildProcess.onExit (/home/kristjan/Infomonitor/MagicMirror/node_modules/node-gyp/lib/build.js:203:23)
            npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
            npm ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:293:12)
            npm ERR! gyp ERR! System Linux 5.10.0-20-amd64
            npm ERR! gyp ERR! command "/home/kristjan/.nvm/versions/node/v16.18.0/bin/node" "/home/kristjan/Infomonitor/MagicMirror/node_modules/.bin/node-gyp" "rebuild"
            npm ERR! gyp ERR! cwd /home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll
            npm ERR! gyp ERR! node -v v16.18.0
            npm ERR! gyp ERR! node-gyp -v v9.3.1
            npm ERR! gyp ERR! not ok
            npm ERR!     /home/kristjan/.npm/_logs/2023-01-06T18_47_25_457Z-debug-0.log
            kristjan@debian:~/Infomonitor/MagicMirror/modules/MMM-Buttons$ uname -r
            5.10.0-20-amd64
            kristjan@debian:~/Infomonitor/MagicMirror/modules/MMM-Buttons$ lsb_release -a
            No LSB modules are available.
            Distributor ID:	Debian
            Description:	Debian GNU/Linux 11 (bullseye)
            Release:	11
            Codename:	bullseye
              sdetweil @wishmaster270
              @wishmaster270 i don’t see any issues for your module either (modified using postinstall script)
              sam@galliumos:~/MagicMirror/modules/MMM-GPIO-Notifications$ npm install --omit=dev --no-fund --no-audit
              npm WARN deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
              > MMM-GPIO-Notifications@0.0.5 postinstall
              > ./postinstall
              ⠧ Building module: epoll, Completed: 0make: Entering directory '/home/sam/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
              ⠴ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
              ⠧ Building module: epoll, Completed: 0  COPY Release/epoll.node
              ⠇ Building module: epoll, Completed: 0make: Leaving directory '/home/sam/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
              ✔ Rebuild Complete
              added 170 packages in 20s
              npm 8.11.0
              node 16.16.0
                sdetweil @KristjanESPERANTO
                @KristjanESPERANTO hm…
                my laptop uname
                Linux galliumos 4.16.18-galliumos #1 SMP PREEMPT Sun Jun 23 04:14:45 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
                  @KristjanESPERANTO but it didn’t execute the postinstall script…
                  tried to build without it… and it WILL fail without using electron-rebuild
                  what npm version is this?
                    @sdetweil npm -v: 8.19.2
                      @KristjanESPERANTO weird
                      sam@galliumos:~/MagicMirror/modules/MMM-Buttons$ npm -v
                      8.19.2
                      sam@galliumos:~/MagicMirror/modules/MMM-Buttons$ npm install --omit=dev --no-fund --no-audit
                      > ./postinstall
                      ⠋ Building module: epoll, Completed: 0make: Entering directory '/home/sam/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
                      ⠼ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                      ⠇ Building module: epoll, Completed: 0make: Leaving directory '/home/sam/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
                      ✔ Rebuild Complete
                      added 6 packages in 15s
                      • karsten13K Online
                        karsten13 @sdetweil
                        strange, I did npm install in the MMM-Buttons folder.
                        More info (running in a docker container):
                        node@raspberrypi:/opt/magic_mirror$ npx node-gyp -v
                        v9.3.1
                        node@raspberrypi:/opt/magic_mirror$ node -v
                        v19.3.0
                        node@raspberrypi:/opt/magic_mirror$ uname -a
                        Linux raspberrypi 5.15.76-v7l+ #1597 SMP Fri Nov 4 12:14:58 GMT 2022 armv7l GNU/Linux
                        node@raspberrypi:/opt/magic_mirror$ cat /etc/os-release
                        PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                        NAME="Debian GNU/Linux"
                        VERSION_ID="11"
                        VERSION="11 (bullseye)"
                        VERSION_CODENAME=bullseye
                        ID=debian
                        HOME_URL="https://www.debian.org/"
                        SUPPORT_URL="https://www.debian.org/support"
                        BUG_REPORT_URL="https://bugs.debian.org/"
                        node@raspberrypi:/opt/magic_mirror$ npm -v
                        9.2.0
                        • 1 / 6
