    electron-rebuild problems with MagicMirror 2.22.0
    53 Posts 5 Posters 27.7k Views 6 Watching
      sdetweil @KristjanESPERANTO
      @KristjanESPERANTO epoll binary is dependent on the Electron version.
      no matter which lib drags it in … so you MUST run eb… to get it current…
      see my prior post for the troubles…
      NOBODY gives a crap about breaking changes anymore…
      they all feel if you don’t update, then your code dies. and they don’t care…
        @sdetweil and it succeeded on pi4 w bullseye… I also tested with my
        upgrade script and backup/restore
        and both those executed and did rebuild on the modules… (using the postinstall script)
        • karsten13K Offline
          karsten13 @sdetweil
          node@raspberrypi:/opt/magic_mirror/modules$ git clone https://github.com/sdetweil/MMM-Buttons.git
          Cloning into 'MMM-Buttons'...
          remote: Enumerating objects: 56, done.
          remote: Counting objects: 100% (4/4), done.
          remote: Compressing objects: 100% (4/4), done.
          remote: Total 56 (delta 0), reused 2 (delta 0), pack-reused 52
          Receiving objects: 100% (56/56), 11.86 KiB | 1.69 MiB/s, done.
          Resolving deltas: 100% (25/25), done.
          node@raspberrypi:/opt/magic_mirror/modules$ cd MMM-Buttons/
          node@raspberrypi:/opt/magic_mirror/modules/MMM-Buttons$ ls -la
          total 40
          drwxr-xr-x 3 node node 4096 Jan  6 19:39 .
          drwxr-xr-x 5 node node 4096 Jan  6 19:39 ..
          drwxr-xr-x 8 node node 4096 Jan  6 19:39 .git
          -rw-r--r-- 1 node node  530 Jan  6 19:39 CHANGELOG.md
          -rw-r--r-- 1 node node 3416 Jan  6 19:39 MMM-Buttons.js
          -rw-r--r-- 1 node node 5725 Jan  6 19:39 README.md
          -rw-r--r-- 1 node node 2778 Jan  6 19:39 node_helper.js
          -rw-r--r-- 1 node node  693 Jan  6 19:39 package.json
          -rwxr-xr-x 1 node node  179 Jan  6 19:39 postinstall
          node@raspberrypi:/opt/magic_mirror/modules/MMM-Buttons$ npm install
          > Magic-Mirror-Module-Buttons@1.0.0 postinstall
          > ./postinstall
          ⠧ Building module: epoll, Completed: 0make: Entering directory '/opt/magic_mirror/modules/MMM-Buttons/node_modules/epoll/build'
            CXX(target) Release/obj.target/epoll/src/epoll.o
          ⠙ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
          ⠼ Building module: epoll, Completed: 0  COPY Release/epoll.node
          make: Leaving directory '/opt/magic_mirror/modules/MMM-Buttons/node_modules/epoll/build'
          ✔ Rebuild Complete
          added 6 packages, and audited 7 packages in 2m
          found 0 vulnerabilities
            sdetweil @karsten13
            @karsten13 yep, looks good…
            • KristjanESPERANTOK Offline
              For me it looks like this:
              kristjan@debian:~/Infomonitor/MagicMirror/modules$ git clone https://github.com/sdetweil/MMM-Buttons.git
              kristjan@debian:~/Infomonitor/MagicMirror/modules$ cd MMM-Buttons/
              kristjan@debian:~/Infomonitor/MagicMirror/modules/MMM-Buttons$ npm install
              npm ERR! code 1
              npm ERR! path /home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll
              npm ERR! command failed
              npm ERR! command sh -c -- node-gyp rebuild
              npm ERR! make: Entering directory '/home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
              npm ERR!   CXX(target) Release/obj.target/epoll/src/epoll.o
              npm ERR!   SOLINK_MODULE(target) Release/obj.target/epoll.node
              npm ERR! make: Leaving directory '/home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
              npm ERR! gyp info it worked if it ends with ok
              npm ERR! gyp info using node-gyp@9.3.1
              npm ERR! gyp info using node@16.18.0 | linux | x64
              npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
              npm ERR! gyp info spawn /usr/bin/python3
              npm ERR! gyp info spawn args [
              npm ERR! gyp info spawn args   '/home/kristjan/Infomonitor/MagicMirror/node_modules/node-gyp/gyp/gyp_main.py',
              npm ERR! gyp info spawn args   'binding.gyp',
              npm ERR! gyp info spawn args   '-f',
              npm ERR! gyp info spawn args   'make',
              npm ERR! gyp info spawn args   '-I',
              npm ERR! gyp info spawn args   '/home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/config.gypi',
              npm ERR! gyp info spawn args   '/home/kristjan/Infomonitor/MagicMirror/node_modules/node-gyp/addon.gypi',
              npm ERR! gyp info spawn args   '/home/kristjan/.cache/node-gyp/16.18.0/include/node/common.gypi',
              npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
              npm ERR! gyp info spawn args   '-Dvisibility=default',
              npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/kristjan/.cache/node-gyp/16.18.0',
              npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/home/kristjan/Infomonitor/MagicMirror/node_modules/node-gyp',
              npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/kristjan/.cache/node-gyp/16.18.0/<(target_arch)/node.lib',
              npm ERR! gyp info spawn args   '-Dmodule_root_dir=/home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll',
              npm ERR! gyp info spawn args   '-Dnode_engine=v8',
              npm ERR! gyp info spawn args   '--depth=.',
              npm ERR! gyp info spawn args   '--no-parallel',
              npm ERR! gyp info spawn args   '--generator-output',
              npm ERR! gyp info spawn args   'build',
              npm ERR! gyp info spawn args   '-Goutput_dir=.'
              npm ERR! gyp info spawn args ]
              npm ERR! gyp info spawn make
              npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
              npm ERR! /usr/bin/ld: /lib/x86_64-linux-gnu/libm.so.6: unknown type [0x13] section `.relr.dyn'
              npm ERR! /usr/bin/ld: skipping incompatible /lib/x86_64-linux-gnu/libm.so.6 when searching for /lib/x86_64-linux-gnu/libm.so.6
              npm ERR! /usr/bin/ld: cannot find /lib/x86_64-linux-gnu/libm.so.6
              npm ERR! /usr/bin/ld: /lib/x86_64-linux-gnu/libmvec.so.1: unknown type [0x13] section `.relr.dyn'
              npm ERR! /usr/bin/ld: skipping incompatible /lib/x86_64-linux-gnu/libmvec.so.1 when searching for /lib/x86_64-linux-gnu/libmvec.so.1
              npm ERR! /usr/bin/ld: cannot find /lib/x86_64-linux-gnu/libmvec.so.1
              npm ERR! collect2: error: ld returned 1 exit status
              npm ERR! make: *** [epoll.target.mk:145: Release/obj.target/epoll.node] Error 1
              npm ERR! gyp ERR! build error
              npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
              npm ERR! gyp ERR! stack     at ChildProcess.onExit (/home/kristjan/Infomonitor/MagicMirror/node_modules/node-gyp/lib/build.js:203:23)
              npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
              npm ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:293:12)
              npm ERR! gyp ERR! System Linux 5.10.0-20-amd64
              npm ERR! gyp ERR! command "/home/kristjan/.nvm/versions/node/v16.18.0/bin/node" "/home/kristjan/Infomonitor/MagicMirror/node_modules/.bin/node-gyp" "rebuild"
              npm ERR! gyp ERR! cwd /home/kristjan/Infomonitor/MagicMirror/modules/MMM-Buttons/node_modules/epoll
              npm ERR! gyp ERR! node -v v16.18.0
              npm ERR! gyp ERR! node-gyp -v v9.3.1
              npm ERR! gyp ERR! not ok
              npm ERR!     /home/kristjan/.npm/_logs/2023-01-06T18_47_25_457Z-debug-0.log
              kristjan@debian:~/Infomonitor/MagicMirror/modules/MMM-Buttons$ uname -r
              5.10.0-20-amd64
              kristjan@debian:~/Infomonitor/MagicMirror/modules/MMM-Buttons$ lsb_release -a
              No LSB modules are available.
              Distributor ID:	Debian
              Description:	Debian GNU/Linux 11 (bullseye)
              Release:	11
              Codename:	bullseye
                sdetweil @wishmaster270
                @wishmaster270 i don’t see any issues for your module either (modified using postinstall script)
                sam@galliumos:~/MagicMirror/modules/MMM-GPIO-Notifications$ npm install --omit=dev --no-fund --no-audit
                npm WARN deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
                > MMM-GPIO-Notifications@0.0.5 postinstall
                > ./postinstall
                ⠧ Building module: epoll, Completed: 0make: Entering directory '/home/sam/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                ⠴ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                ⠧ Building module: epoll, Completed: 0  COPY Release/epoll.node
                ⠇ Building module: epoll, Completed: 0make: Leaving directory '/home/sam/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                ✔ Rebuild Complete
                added 170 packages in 20s
                npm 8.11.0
                node 16.16.0
                  @KristjanESPERANTO hm…
                  my laptop uname
                  Linux galliumos 4.16.18-galliumos #1 SMP PREEMPT Sun Jun 23 04:14:45 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
                    @KristjanESPERANTO but it didn’t execute the postinstall script…
                    tried to build without it… and it WILL fail without using electron-rebuild
                    what npm version is this?
                      @sdetweil npm -v: 8.19.2
                        @KristjanESPERANTO weird
                        sam@galliumos:~/MagicMirror/modules/MMM-Buttons$ npm -v
                        8.19.2
                        sam@galliumos:~/MagicMirror/modules/MMM-Buttons$ npm install --omit=dev --no-fund --no-audit
                        > ./postinstall
                        ⠋ Building module: epoll, Completed: 0make: Entering directory '/home/sam/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
                        ⠼ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                        ⠇ Building module: epoll, Completed: 0make: Leaving directory '/home/sam/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
                        ✔ Rebuild Complete
                        added 6 packages in 15s
                          karsten13 @sdetweil
                          strange, I did npm install in the MMM-Buttons folder.
                          More info (running in a docker container):
                          node@raspberrypi:/opt/magic_mirror$ npx node-gyp -v
                          v9.3.1
                          node@raspberrypi:/opt/magic_mirror$ node -v
                          v19.3.0
                          node@raspberrypi:/opt/magic_mirror$ uname -a
                          Linux raspberrypi 5.15.76-v7l+ #1597 SMP Fri Nov 4 12:14:58 GMT 2022 armv7l GNU/Linux
                          node@raspberrypi:/opt/magic_mirror$ cat /etc/os-release
                          PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                          NAME="Debian GNU/Linux"
                          VERSION_ID="11"
                          VERSION="11 (bullseye)"
                          VERSION_CODENAME=bullseye
                          ID=debian
                          HOME_URL="https://www.debian.org/"
                          SUPPORT_URL="https://www.debian.org/support"
                          BUG_REPORT_URL="https://bugs.debian.org/"
                          node@raspberrypi:/opt/magic_mirror$ npm -v
                          9.2.0
                            karsten13 @sdetweil
                            @sdetweil said in electron-rebuild problems with MagicMirror 2.22.0:
                            thats x86_64, not arm32v7, totally different concerning compiling stuff which is done in electron-rebuild …
                              sdetweil @karsten13
                              @karsten13 his was x86_64… (edit: i see his is amd64, oops, tldr;l!)…
                              I will see if I can get a vm on my new amd64 chromebook… had it til I powered off…
                              but I built on buster and bullseye on pi4 also … MM version 2.22
                              but his didn’t execute the postinstall script
                              karsten13K 2 Replies Last reply Reply Quote 0
                                karsten13 @sdetweil
                                his was x86_64…
                                he wrote “I use a fully patched Raspberry OS Bullseye 32Bit.” so I think this is arm32v7
                                strange
                                  sdetweil @karsten13
                                  @karsten13 yeh, his says
                                  5.10.0-20-amd64
                                  so not 32 bit.
                                  @KristjanESPERANTO
                                  can you go to the MMM-Buttons folder and do
                                  ./postinstall
                                    karsten13 @sdetweil
                                    so not 32 bit.
                                    he wrote 32 bit
                                    x86_64=amd64: No Raspian OS
                                    arm32v7=arm=aarch32: Raspian OS 32-bit
                                    arm64v8=arm64=aarch64: Raspian OS 64-bit
                                      sdetweil @karsten13
                                      @karsten13 yeh, haven’t tested on arm64 on pi for a while.
                                      but its still an npm problem if it doesn’t run the postinstall
                                      flashing image now
                                      worked fine
                                      pi@raspberrypi:~/MagicMirror/modules $ uname -a
                                      Linux raspberrypi 5.15.61-v8+ #1579 SMP PREEMPT Fri Aug 26 11:16:44 BST 2022 aarch64 GNU/Linux
                                      pi@raspberrypi:~/MagicMirror/modules $ node -v
                                      v16.19.0
                                      pi@raspberrypi:~/MagicMirror/modules $ npm -v
                                      8.19.3
                                      pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/sdetweil/MMM-Buttons.git
                                      Receiving objects: 100% (56/56), 11.86 KiB | 3.95 MiB/s, done.
                                      pi@raspberrypi:~/MagicMirror/modules $ cd MMM-Buttons/
                                      pi@raspberrypi:~/MagicMirror/modules/MMM-Buttons $ npm install --omit=dev --no-audit --no-fund
                                      > ./postinstall
                                      /home/pi/MagicMirror/modules/MMM-Buttons
                                      ⠙ Building module: epoll, Completed: 0make: Entering directory '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
                                      ⠸ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                                      make: Leaving directory '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
                                      ✔ Rebuild Complete
                                      added 6 packages in 2m
                                      • wishmaster270W Offline
                                        wishmaster270 Module Developer @sdetweil
                                        @sdetweil Sorry, had no Internet connection for a few hours.
                                        The version of my GPIO module in the development branch uses the postinstall script and there is where the error happens.
                                        It is a Raspberry 4 in my case with 32bit Bullseye.
                                        It is
                                        npm 9.2.0
                                        node 16.19.0
                                        arch armv7l
                                        in my case.
                                          @wishmaster270 hm, I modified your module and it works fine… will check your branch
                                          I just copy the postinstall script and change package.json
                                          intel x86-64 ok
                                          base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ git checkout development
                                          branch 'development' set up to track 'origin/development'.
                                          Switched to a new branch 'development'
                                          (base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ ls
                                          examples  LICENSE  MMM-GPIO-Notifications.js  node_helper.js  package.json  postinstall  README.md
                                          (base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ nano package.json
                                          (base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ npm install --omit=dev --no-audit --no-fund
                                          > MMM-GPIO-Notifications@0.0.6 postinstall
                                          > ./postinstall
                                          ⠇ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                                          ✔ Rebuild Complete
                                          added 6 packages in 10s
                                          pi 64 aarch64 ok
                                          (base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ ssh pi@192.168.2.44
                                          pi@192.168.2.44's password:
                                          The programs included with the Debian GNU/Linux system are free software;
                                          the exact distribution terms for each program are described in the
                                          individual files in /usr/share/doc/*/copyright.
                                          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                          permitted by applicable law.
                                          Last login: Fri Jan  6 14:10:59 2023 from 192.168.2.106
                                          pi@raspberrypi:~ $ pm2 stop all
                                          [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                                          [PM2] [MagicMirror](0) ✓
                                          │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                                          │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                                          pi@raspberrypi:~ $ cd MagicMirror/modules
                                          pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications.git
                                          Cloning into 'MMM-GPIO-Notifications'...
                                          remote: Enumerating objects: 159, done.
                                          remote: Counting objects: 100% (42/42), done.
                                          remote: Compressing objects: 100% (34/34), done.
                                          remote: Total 159 (delta 17), reused 22 (delta 8), pack-reused 117
                                          Receiving objects: 100% (159/159), 744.45 KiB | 3.48 MiB/s, done.
                                          Resolving deltas: 100% (74/74), done.
                                          pi@raspberrypi:~/MagicMirror/modules $ cd MMM-GPIO-Notifications/
                                          pi@raspberrypi:~/MagicMirror/modules/MMM-GPIO-Notifications $ git checkout development
                                          Branch 'development' set up to track remote branch 'development' from 'origin'.
                                          pi@raspberrypi:~/MagicMirror/modules/MMM-GPIO-Notifications $ npm install --omit=dev --no-audit --no-fund
                                          > ./postinstall
                                          ⠋ Building module: epoll, Completed: 0make: Entering directory '/home/pi/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                                          ⠹ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                                          ⠦ Building module: epoll, Completed: 0  COPY Release/epoll.node
                                          make: Leaving directory '/home/pi/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                                          ✔ Rebuild Complete
                                          pi@raspberrypi:~/MagicMirror/modules/MMM-GPIO-Notifications $ exit
                                          pi 32bit buster ok
                                          pi@raspberrypi42:~ $ cd MagicMirror/modules/
                                          pi@raspberrypi42:~/MagicMirror/modules $ git clone https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications.git
                                          Receiving objects: 100% (159/159), 744.45 KiB | 73.00 KiB/s, done.
                                          pi@raspberrypi42:~/MagicMirror/modules $ cd MMM-GPIO-Notifications/
                                          pi@raspberrypi42:~/MagicMirror/modules/MMM-GPIO-Notifications $ git checkout develoment
                                          error: pathspec 'develoment' did not match any file(s) known to git
                                          pi@raspberrypi42:~/MagicMirror/modules/MMM-GPIO-Notifications $ git checkout development
                                          pi@raspberrypi42:~/MagicMirror/modules/MMM-GPIO-Notifications $ npm install --omit=dev --no-audit --no-fund
                                          > ./postinstall
                                          ⠙ Building module: epoll, Completed: 0make: Entering directory '/home/pi/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                                          ✔ Rebuild Complete
                                          added 6 packages in 14s
                                          pi@raspberrypi42:~/MagicMirror/modules/MMM-GPIO-Notifications $ lsb_release -a
                                          Distributor ID:	Raspbian
                                          Description:	Raspbian GNU/Linux 10 (buster)
                                          Release:	10
                                          Codename:	buster
                                          32 bit bullseye, ok
                                          fribble@raspberrypi4:~ $ cd MagicMirror/modules/
                                          fribble@raspberrypi4:~/MagicMirror/modules $ lsb_release -a
                                          Description:	Raspbian GNU/Linux 11 (bullseye)
                                          Release:	11
                                          Codename:	bullseye
                                          fribble@raspberrypi4:~/MagicMirror/modules $ git clone https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications.git
                                          Receiving objects: 100% (159/159), 744.45 KiB | 3.26 MiB/s, done.
                                          fribble@raspberrypi4:~/MagicMirror/modules $ cd MMM-GPIO-Notifications/
                                          fribble@raspberrypi4:~/MagicMirror/modules/MMM-GPIO-Notifications $ git checkout development
                                          fribble@raspberrypi4:~/MagicMirror/modules/MMM-GPIO-Notifications $ npm install --omit=dev --no-audit --no-fund
                                          > ./postinstall
                                          ⠸ Building module: epoll, Completed: 0make: Entering directory '/home/fribble/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                                          ⠏ Building module: epoll, Completed: 0  COPY Release/epoll.node
                                          make: Leaving directory '/home/fribble/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                                          ✔ Rebuild Complete
                                          added 6 packages in 21s
                                            @wishmaster270 said in electron-rebuild problems with MagicMirror 2.22.0:
                                            kApiSystemPointerSize == kApiInt64Size,
                                            this looks like a compile header mismatch
                                            make sure u delete the electron-rebuild if its in your module folder
                                            AND the one in MagicMirror/node_modules in case there is a downlevel version,
                                            OR change the postinstall to always install it. vs checking if present and running the installed version…
