    PIR problem
    19 Posts 6 Posters 7.7k Views 7 Watching
    • P Offline
      Peter
      Hi smart people,
      My MM has been running without major problems for 5 years.
      Lately I experienced some problems, so decided to make a fresh install: Bullseye, MM 2.22 on a Pi 3.
      After a lot of work (I am not really good at this, mostly copy-paste) the MM is running.
      Just 2 problems: major problem: I cannot get de PIR sensor to work anymore (worked perfectly for 5 year).
      I tried MMM-Pir (nothing), and MMM-Pir-Sensor-Light (I can see it countdown from 15 minutes, but after 15 minutes the counter starts allover), so it does not turn off the screen.
      Smaller problem: the default Calendar module disappears after some time and gets back after some more time, strange behaviour.
      Can somebody give me an answer (maybe two …)?
      Thanks in advance!
      Peter
      • wishmaster270W Offline
        wishmaster270 Module Developer @Peter
        @Peter
        There can be a lot of reasons why the PIR modules are not working anymore.
        What module did you use in the previous setup?
        Did you run “npm install” in the module again? Or did you only copy the directory to the new setup?
        Are there any errors during the installation of the module?
        You can use my test script to check if the sensor it self triggers an event.
        Next step would be to test if the command which controls the screen. Most modules use vcgencmd
        If you run the following command to display should be shut off and 20 seconds later it should be shut on again.
        Best way is to run the command via ssh shell.
        /usr/bin/vcgencmd display_power 0; echo "Display should now be off"; sleep 20; /usr/bin/vcgencmd display_power 1; echo "And now it should be on again"
        S P 3 Replies Last reply Reply Quote 0
          sdetweil @wishmaster270
          @wishmaster270 note vcgencmd is sensitive to the pi firmware level
            wishmaster270 Module Developer @sdetweil
            @sdetweil I saw your post about firmware level in one of the other posts. Additionally i think it is depending of the graphical driver used (vc4-kms-v3d vs vc4-fkms-v3d).
            But if it works with the posted command most of the modules should be fine.
              @wishmaster270 https://forum.magicmirror.builders/topic/17185/pir-sensor-problem-after-restart-raspi/19?_=1663206370580
              • P Offline
                Peter @wishmaster270
                @wishmaster270 said in PIR problem:
                @Peter
                Thanks for your answer.
                I used MMM-Pir_Sensor in my previous setup.
                I made a complete new install, so I did not copy the directory to the new setup.
                I will try your commands in the next days, will keep you informed.
                Peter
                  I think it is more a problem of the graphical stack. Just checked my new installation of today.
                  With “vc4-kms-v3d” my test commands from above result in the screen being unchanged after i changed back to the “vc4-fkms-v3d” driver in the “/boot/config.txt” and a reboot everything is working as before.
                  I run the kernel 5.15.84-v7l+ at the moment.
                  • P Offline
                    @wishmaster270 sorry for my stupid question, I use Gpio pin 17, do I have to use that number in line 6 of your test script?
                    Peter
                      @Peter
                      No stupid question more a lack of information/documentation of me ;-)
                      You can call the script with the GPIO number as first argument. In your case it should be:
                      ./testGPIO.py 17
                      After some research i am pretty sure the problem is the graphics stack in your case. I am working on a solution for the problem
                      • P Offline
                        @wishmaster270 great!
                        I will try it as soon as I find time …
                        Have a nice evening!
                        Peter
                        • karsten13K Offline
                          karsten13 @Peter
                          I was not able to use vcgencmd under bullseye and AFAIK they are using xrandr under the hood for rotating the screen over the web ui menu.
                          So beside testing if the sensor works you could test if you can deactivate the sceen with xrandr --output HDMI-1 --off and activate it again with xrandr --output HDMI-1 --rotate normal --auto.
                          xrandr is also the default of commandType option of MMM-PIR-Sensor-Lite (see documentation).
                          • P Offline
                            Peter @karsten13
                            @karsten13 I tried MMM-Pir-Sensor-Lite: counting down works and is re-activated whenever I move my hand in front of the sensor.
                            But the screen does not turn off.
                            Peter
                            wishmaster270W S 2 Replies Last reply Reply Quote 0
                              @Peter
                              @karsten13
                              Just released version 0.0.7 of my MMM-Screen-Powersave-Notification module which supports either vcgencmd, tvservice and now also xrandr.
                                sdetweil @Peter
                                @Peter what mode are u trying? xrandr vcgencmd?
                                only xrandr works on bullseye
                                • P Offline
                                  Peter @sdetweil
                                  @sdetweil I used xrandr.
                                  Peter
                                    sdetweil @Peter
                                    @Peter and if you issue the commands yourself(via ssh)
                                    do they work?
                                    • P Offline
                                      Peter @sdetweil
                                      @sdetweil did not try that.
                                      Peter
                                      N6NGN 1 Reply Last reply Reply Quote 0
                                      • N6NGN Offline
                                        N6NG @Peter
                                        @Peter Hello Peter… I’m not sure I understand… I ran the following test on my mirror and it worked as it should.
                                        /usr/bin/vcgencmd display_power 0; echo “Display should now be off”; sleep 20; /usr/bin/vcgencmd display_power 1; echo “And now it should be on again”
                                        But now I need to incorporate it into my config.js for my MMM-PIR-Sensor-Lite. I see the command type and ‘vcgencmd’ but once I get that in the config how do I do the turn on and turn off?
                                        Thanks for all the help and you also Sam.
                                        Dennis
                                        • T Offline
                                          TangoE30 @N6NG
                                          @N6NG and @sdetweil
                                          Hi All,
                                          Passing along some info as I was also having problems with my ASUS VZ27EHE monitor staying off / my monitor coming back on with MMM-PIR-Sensor-Lite. The display would turn off, then a blue screen come on saying “HDMI No Signal” but then automatically turned back on. I used both xrandr and xset commands but nothing worked on my pi 4 running Bullseye.
                                          After some digging and looking at this site “https://github.com/raspberrypi/linux/issues/2517”, I replaced the code in the node_helper.js (I know you’re not supposed to touch but this is what worked for me) and it works now. The only issue is on reboot, I have to run a command once to avoid the screen going to a gray state xsetroot -display :0 -solid Black.
                                          case 'xset':
                                          	exec("xset -display :0 s noblank", null);//default: xset dpms force off
                                          	//Have to run 'xsetroot -display :0 -solid Black' on reboot to avoid gray screen
                                          	exec("sleep 1", null);
                                          	exec("xset -display :0 s off", null);
                                          	exec("xset -display :0 -dpms", null);
                                          	exec("xset -display :0 s 0 0", null);
                                          	exec("xset -display :0 dpms 0 0 0", null);
                                          	exec("xset dpms force off", null);
                                          Don’t ask me how it works and I’ll give credit to E3V3A for posting that code. Hopefully this will help for those with a non-CEC compliant monitor and can fully turn off the monitor when not in use.
