    PIR problem
    19 Posts 6 Posters 6.8k Views 7 Watching
    • karsten13K Offline
      karsten13 @Peter
      I was not able to use vcgencmd under bullseye and AFAIK they are using xrandr under the hood for rotating the screen over the web ui menu.
      So beside testing if the sensor works you could test if you can deactivate the sceen with xrandr --output HDMI-1 --off and activate it again with xrandr --output HDMI-1 --rotate normal --auto.
      xrandr is also the default of commandType option of MMM-PIR-Sensor-Lite (see documentation).
      • P Offline
        Peter @karsten13
        @karsten13 I tried MMM-Pir-Sensor-Lite: counting down works and is re-activated whenever I move my hand in front of the sensor.
        But the screen does not turn off.
        Peter
        wishmaster270W S 2 Replies Last reply Reply Quote 0
        • wishmaster270W Offline
          wishmaster270 Module Developer @Peter
          @Peter
          @karsten13
          Just released version 0.0.7 of my MMM-Screen-Powersave-Notification module which supports either vcgencmd, tvservice and now also xrandr.
            sdetweil @Peter
            @Peter what mode are u trying? xrandr vcgencmd?
            only xrandr works on bullseye
            • P Offline
              Peter @sdetweil
              @sdetweil I used xrandr.
              Peter
                sdetweil @Peter
                @Peter and if you issue the commands yourself(via ssh)
                do they work?
                • P Offline
                  Peter @sdetweil
                  @sdetweil did not try that.
                  Peter
                  N6NGN 1 Reply Last reply Reply Quote 0
                  • N6NGN Offline
                    N6NG @Peter
                    @Peter Hello Peter… I’m not sure I understand… I ran the following test on my mirror and it worked as it should.
                    /usr/bin/vcgencmd display_power 0; echo “Display should now be off”; sleep 20; /usr/bin/vcgencmd display_power 1; echo “And now it should be on again”
                    But now I need to incorporate it into my config.js for my MMM-PIR-Sensor-Lite. I see the command type and ‘vcgencmd’ but once I get that in the config how do I do the turn on and turn off?
                    Thanks for all the help and you also Sam.
                    Dennis
                    • T Offline
                      TangoE30 @N6NG
                      @N6NG and @sdetweil
                      Hi All,
                      Passing along some info as I was also having problems with my ASUS VZ27EHE monitor staying off / my monitor coming back on with MMM-PIR-Sensor-Lite. The display would turn off, then a blue screen come on saying “HDMI No Signal” but then automatically turned back on. I used both xrandr and xset commands but nothing worked on my pi 4 running Bullseye.
                      After some digging and looking at this site “https://github.com/raspberrypi/linux/issues/2517”, I replaced the code in the node_helper.js (I know you’re not supposed to touch but this is what worked for me) and it works now. The only issue is on reboot, I have to run a command once to avoid the screen going to a gray state xsetroot -display :0 -solid Black.
                      case 'xset':
                      	exec("xset -display :0 s noblank", null);//default: xset dpms force off
                      	//Have to run 'xsetroot -display :0 -solid Black' on reboot to avoid gray screen
                      	exec("sleep 1", null);
                      	exec("xset -display :0 s off", null);
                      	exec("xset -display :0 -dpms", null);
                      	exec("xset -display :0 s 0 0", null);
                      	exec("xset -display :0 dpms 0 0 0", null);
                      	exec("xset dpms force off", null);
                      Don’t ask me how it works and I’ll give credit to E3V3A for posting that code. Hopefully this will help for those with a non-CEC compliant monitor and can fully turn off the monitor when not in use.
