    MMM-Fritz-Box-Callmonitor: Notification formatting
    31 Posts 7 Posters 24.8k Views 7 Watching
      Jan 0 @coernel
      @coernel I now also pushed the changes into the master https://github.com/drtorchwood/MMM-FRITZ-Box-Callmonitor-py3/tree/master
      C 1 Reply Last reply Reply Quote 1
      • C Offline
        coernel @Jan 0
        @Jan-0
        This is so cool! It does work now. Has it been published to the list of modules?
        If you or @wishmaster270 are somewhere near Cologne you or are invited for a free professional solo session of Feldenkrais Functional Integration or a free professional singing lesson!
        • wishmaster270W Offline
          wishmaster270 Module Developer @coernel
          @coernel
          Great to hear and you are welcome. I try to help where I can.
          I live about 30km south of Munich but thanks for your invitation.
          • X Offline
            xIExodusIx
            Hi Everybody out there using MMM-FRITZ-Box-Callmonitor,
            I would love to use this Module, but I’m not really in the mod to code or to find errors.
            I tried to install your new branch under PiOS “Bookworm” but I get some errors using
            “sudo apt-get install python-dev libxml2-dev libxslt1-dev zlib1g-dev && sudo pip install fritzconnection”!
            The first error is: " E: For Package »python-dev« exists no Installationscandidate."
            The second error for pip install is: “externally-managed-environment …”
            How can I solve these problems?
            Sorry for my bad english, I’m german and over 60 years old.
            Thanks for helping.
              rabbit83ka @xIExodusIx
              @xIExodusIx that’s due to changes in the handling of the python packages. I installed “fritzconnection” in a virtual environment:
              python -m venv venv
              source venv/bin/activate
              python -m pip install fritzconnection
              to make the Callmonitor use the fritzconnection, I edited the nodehelper.js (in ~/MagicMirror/modules/MMM-FritzBox-Callmonitor-py3) in line 212 to look like this (user is “pi”, must be adapted if you use another user):
              pythonPath: '/home/pi/venv/bin/python',
              Don’t know if it’s the best solution, but it works.
                sdetweil @rabbit83ka
                @rabbit83ka you can set the venv in the mm.sh that starts MagicMirror
                then you don’t need to do that
                  rabbit83ka @sdetweil
                  @sdetweil Thanks, so it should look like this?
                  #!/bin/bash
                  # This file is still here to keep PM2 working on older installations.
                  cd ~/MagicMirror
                  export PYTHONPATH="/home/pi/venv/bin/python"
                  DISPLAY=:0 npm start
                    @rabbit83ka no, execute the venv command to set the virtual environment in place of the export
                    the same venv command you did before running pip
                      @sdetweil I used your script
                      fixuppm2.sh
                      when I set up the mirror
                      Now I modified ~/MagicMirror/installers/mm.sh to
                      #!/bin/bash
                      cd ~/MagicMirror
                      but that doesn’t work, error occures again because node_helper doesn’t seem to use the venv.
                        @rabbit83ka when I look at my .bashrc whichs sets up the default venv on shell open
                        I see
                        # Virtual Environment Wrapper
                        source /usr/local/bin/virtualenvwrapper.sh
                        PKG_CONFIG_PATH=$PKG_CONFIG_PATH:/usr/local/lib/pkgconfig
                        export PKG_CONFIG_PATH
                        cd ~
                        this topic seems applicable
                        https://unix.stackexchange.com/questions/87062/how-to-display-the-name-of-the-current-virtualenv
                          @rabbit83ka I also see this for background
                          https://arshovon.com/blog/python-background/
