absolute date in calendar module
 @qqqqqqqq with the current implementation this is the expected behaviour } else if (event.startDate - now < 2 * oneDay && event.startDate - now > 0) { if (this.translate("DAYAFTERTOMORROW") !== "DAYAFTERTOMORROW") { timeWrapper.innerHTML = this.capFirst(this.translate("DAYAFTERTOMORROW")); } else { timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").fromNow()); } }it will be always relative EDIT: this is only for fullday events
 I tested it yesterday and my calendar showed “tomorrow at 15:30” and “Saturday at 14:00” That is as absolute as it gets, imho
 Most of my events are Fullday events. So, yeah. Right now, I guess it gets relative for next 3/4 days, and absolute thereafter.
 I was running into the same issue with not being able to disable the relative days, My issue was that when something was set to “The day after tomorrow” it made the module far to wide and overwrote other modules(Im using an older low res screen). To fix this I edited the file at MagicMirror/modules/default/calendar/calendar.js and replaced line 237 with the entry below, I changed it to two days which is much shorter but you can change it to whatever you want. timeWrapper.innerHTML = this.capFirst(this.translate(“Two Days”)); The line originally was. timeWrapper.innerHTML = this.capFirst(this.translate(“DAYAFTERTOMORROW”));
 Is it a big task to change so that it displays weekdays for the current week and then dates when the event is further away? So lets say it is Wednesday. The calendar would then display it like:
 Event Today
 Event Thursday
 Event Saturday
 Event Sunday
 Event Oct 9
 Event Oct 11
 …Edit: Can see that the urgency option takes x amount of days. Would be nice if the urgency function returns the days(Monday, Tuesday…) in stead of the amount of days away.
 E’ possibile impostare un simbolo diverso da un altro a secondo dell’evento?In caso la risposta fosse SI potreste dirmi come dovrei fare ?Grazie. english Is it possible to set a different symbol from another according to the event? If the answer was YES could you tell me how I should do it? Thanks.
 Come si fa a mettere un simbolo diverso per ogni giorno della settimana?Grazie. english How do you put a different symbol for each day of the week? Thanks.
 @qqqqqqqq
 You must use:
 timeFormat: ‘absolute’,
 getRelative: 0,
 urgency: 0,
 in the config.js
 @pablo_z said in absolute date in calendar module: @qqqqqqqq
 You must use:
 getRelative: 0,
 urgency: 0,
 in the config.jsI wanted the same, to have just dates of events shown. This helped me, thanks.
