    absolute date in calendar module
    19 Posts 9 Posters 15.5k Views 9 Watching
    • Q Offline
      qqqqqqqq
      Okay, made both the changes, fixed the case in “timeFormat” and added
      urgency: '0',
      right next to the timeFormat tag.
      But, now the events appear like this
      event 1 The day after tomorrow
      event 2 Feb 19th
      event 3 Feb 21st
      Still need to fix event 1
      • yawnsY Offline
        yawns Moderator
        Please replace '0' with 0
        Numbers should not be written with quotation marks
        • Q Offline
          qqqqqqqq
          Nope, still the same.
          Btw, i should let you know that I am start the MagicMirror by using the command
          npm start
          Should I be using some other method to start it? Do I need to clear cache or something like that? :slight_frown:
          • yawnsY Offline
            yawns Moderator @qqqqqqqq
            @qqqqqqqq
            Starting your mirror for testing purpose is just fine.
            Please try this:
            		timeFormat: 'absolute',
            		urgency: 0,
            		getRelative: 0,
            • Q Offline
              qqqqqqqq
              I’ve updated the values in both, the main config file & the calendar.js (in the modules folder) but it’s still the same.
              Here is the image. http://pasteboard.co/z6KcmVgLB.jpg
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @qqqqqqqq
                @qqqqqqqq with the current implementation this is the expected behaviour
                } else if (event.startDate - now < 2 * oneDay && event.startDate - now > 0) {
                  if (this.translate("DAYAFTERTOMORROW") !== "DAYAFTERTOMORROW") {
                    timeWrapper.innerHTML = this.capFirst(this.translate("DAYAFTERTOMORROW"));
                  } else {
                    timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").fromNow());
                it will be always relative
                EDIT: this is only for fullday events
                Q 1 Reply Last reply Reply Quote 1
                • yawnsY Offline
                  yawns Moderator
                  I tested it yesterday and my calendar showed “tomorrow at 15:30” and “Saturday at 14:00”
                  That is as absolute as it gets, imho
                  • Q Offline
                    qqqqqqqq @strawberry 3.141
                    @strawberry-3.141
                    Most of my events are Fullday events. So, yeah.
                    Right now, I guess it gets relative for next 3/4 days, and absolute thereafter.
                    • W Offline
                      wered
                      I was running into the same issue with not being able to disable the relative days, My issue was that when something was set to “The day after tomorrow” it made the module far to wide and overwrote other modules(Im using an older low res screen). To fix this I edited the file at MagicMirror/modules/default/calendar/calendar.js and replaced line 237 with the entry below, I changed it to two days which is much shorter but you can change it to whatever you want.
                      timeWrapper.innerHTML = this.capFirst(this.translate(“Two Days”));
                      The line originally was.
                      timeWrapper.innerHTML = this.capFirst(this.translate(“DAYAFTERTOMORROW”));
                        MarkNygaard
                        Is it a big task to change so that it displays weekdays for the current week and then dates when the event is further away?
                        So lets say it is Wednesday. The calendar would then display it like:
                        Event Today
                        Event Thursday
                        Event Saturday
                        Event Sunday
                        Event Oct 9
                        Event Oct 11
                        Edit: Can see that the urgency option takes x amount of days. Would be nice if the urgency function returns the days(Monday, Tuesday…) in stead of the amount of days away.
