    absolute date in calendar module
    19 Posts 9 Posters 15.3k Views 9 Watching
    • Q Offline
      qqqqqqqq
      I want the calendar to display the exact day of the event(birthdays), instead of saying “in 3 days” or “The day after tomorrow” since it takes up too much of space.
      I tried changing it in the main config file & the calendar.js file (both), but no change is reflected.
      strawberry 3.141S P 2 Replies Last reply Reply Quote 0
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @qqqqqqqq
        @qqqqqqqq can you post your config?
        • Q Offline
          qqqqqqqq
          Here is my main config file
          			module: 'calendar',
          			header: 'Your Calendar',
          			position: 'top_left',
          				timeformat: 'absolute',
          						symbol: 'calendar-check-o ',
          						url: 'webcal://calendar.google.com/calendar/ical/....ics'
          						symbol: 'facebook-official ',
          						url: 'webcal://localhost:8080/modules/Cals/FbBirthday.ics'
          						symbol: 'calendar ',
          						url: 'webcal://calendar.google.com/c.....ics'
          			module: 'compliments',
          • brobergB Offline
            broberg Project Sponsor
            You should also set urgency to 0
            • yawnsY Offline
              yawns Moderator
              Please try to write timeFormat instead of timeformat, this is case sensitive :)
              Also try to play around with urgency
              https://github.com/MichMich/MagicMirror/tree/master/modules/default/calendar
              • Q Offline
                qqqqqqqq
                Okay, made both the changes, fixed the case in “timeFormat” and added
                urgency: '0',
                right next to the timeFormat tag.
                But, now the events appear like this
                event 1 The day after tomorrow
                event 2 Feb 19th
                event 3 Feb 21st
                Still need to fix event 1
                • yawnsY Offline
                  yawns Moderator
                  Please replace '0' with 0
                  Numbers should not be written with quotation marks
                  • Q Offline
                    qqqqqqqq
                    Nope, still the same.
                    Btw, i should let you know that I am start the MagicMirror by using the command
                    npm start
                    Should I be using some other method to start it? Do I need to clear cache or something like that? :slight_frown:
                    • yawnsY Offline
                      yawns Moderator @qqqqqqqq
                      @qqqqqqqq
                      Starting your mirror for testing purpose is just fine.
                      Please try this:
                      		timeFormat: 'absolute',
                      		urgency: 0,
                      		getRelative: 0,
                      • Q Offline
                        qqqqqqqq
                        I’ve updated the values in both, the main config file & the calendar.js (in the modules folder) but it’s still the same.
                        Here is the image. http://pasteboard.co/z6KcmVgLB.jpg
