    absolute date in calendar module
    19 Posts 9 Posters 17.1k Views 9 Watching
    • yawnsY
      yawns Moderator
      Please try to write timeFormat instead of timeformat, this is case sensitive :)
      Also try to play around with urgency
      https://github.com/MichMich/MagicMirror/tree/master/modules/default/calendar
      • Q
        qqqqqqqq
        Okay, made both the changes, fixed the case in “timeFormat” and added
        urgency: '0',
        right next to the timeFormat tag.
        But, now the events appear like this
        event 1 The day after tomorrow
        event 2 Feb 19th
        event 3 Feb 21st
        Still need to fix event 1
        • yawnsY
          yawns Moderator
          Please replace '0' with 0
          Numbers should not be written with quotation marks
          • Q
            qqqqqqqq
            Nope, still the same.
            Btw, i should let you know that I am start the MagicMirror by using the command
            npm start
            Should I be using some other method to start it? Do I need to clear cache or something like that? :slight_frown:
            yawnsY 1 Reply Last reply
            • yawnsY
              yawns Moderator @qqqqqqqq
              @qqqqqqqq
              Starting your mirror for testing purpose is just fine.
              Please try this:
              		timeFormat: 'absolute',
              		urgency: 0,
              		getRelative: 0,
              • Q
                qqqqqqqq
                I’ve updated the values in both, the main config file & the calendar.js (in the modules folder) but it’s still the same.
                Here is the image. http://pasteboard.co/z6KcmVgLB.jpg
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @qqqqqqqq
                  @qqqqqqqq with the current implementation this is the expected behaviour
                  } else if (event.startDate - now < 2 * oneDay && event.startDate - now > 0) {
                    if (this.translate("DAYAFTERTOMORROW") !== "DAYAFTERTOMORROW") {
                      timeWrapper.innerHTML = this.capFirst(this.translate("DAYAFTERTOMORROW"));
                    } else {
                      timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").fromNow());
                  it will be always relative
                  EDIT: this is only for fullday events
                  Q 1 Reply Last reply
                  • yawnsY
                    yawns Moderator
                    I tested it yesterday and my calendar showed “tomorrow at 15:30” and “Saturday at 14:00”
                    That is as absolute as it gets, imho
                    • Q
                      qqqqqqqq @strawberry 3.141
                      @strawberry-3.141
                      Most of my events are Fullday events. So, yeah.
                      Right now, I guess it gets relative for next 3/4 days, and absolute thereafter.
                      • W
                        wered
                        I was running into the same issue with not being able to disable the relative days, My issue was that when something was set to “The day after tomorrow” it made the module far to wide and overwrote other modules(Im using an older low res screen). To fix this I edited the file at MagicMirror/modules/default/calendar/calendar.js and replaced line 237 with the entry below, I changed it to two days which is much shorter but you can change it to whatever you want.
                        timeWrapper.innerHTML = this.capFirst(this.translate(“Two Days”));
                        The line originally was.
                        timeWrapper.innerHTML = this.capFirst(this.translate(“DAYAFTERTOMORROW”));
                          MarkNygaard
                          Is it a big task to change so that it displays weekdays for the current week and then dates when the event is further away?
                          So lets say it is Wednesday. The calendar would then display it like:
                          Event Today
                          Event Thursday
                          Event Saturday
                          Event Sunday
                          Event Oct 9
                          Event Oct 11
                          Edit: Can see that the urgency option takes x amount of days. Would be nice if the urgency function returns the days(Monday, Tuesday…) in stead of the amount of days away.
                          • Alex2020A
                            Alex2020
                            E’ possibile impostare un simbolo diverso da un altro a secondo dell’evento?In caso la risposta fosse SI potreste dirmi come dovrei fare ?Grazie.
                            english
                            Is it possible to set a different symbol from another according to the event? If the answer was YES could you tell me how I should do it? Thanks.
                            • Alex2020A
                              Alex2020
                              Come si fa a mettere un simbolo diverso per ogni giorno della settimana?Grazie.
                              english
                              How do you put a different symbol for each day of the week? Thanks.
                                pablo_z @qqqqqqqq
                                @qqqqqqqq
                                You must use:
                                timeFormat: ‘absolute’,
                                getRelative: 0,
                                urgency: 0,
                                in the config.js
                                uros76U 1 Reply Last reply
                                • uros76U
                                  uros76 @pablo_z
                                  @pablo_z said in absolute date in calendar module:
                                  @qqqqqqqq
                                  You must use:
                                  getRelative: 0,
                                  urgency: 0,
                                  in the config.js
                                  I wanted the same, to have just dates of events shown. This helped me, thanks.
