    calendar
    10 Posts 3 Posters 2.9k Views 3 Watching
    • V Offline
      videogame95
      Re: CSS 101 - Getting started with CSS and understanding how CSS works
      I have no under standing how to change my calendar ,
      what do put at beginning of the custom css to select Calendar to make board black or gray around it,
      I have read you help but not were to start
      sorry ,any help please
        JohnGalt
        You can try the following in your custom.css file. The first 3 lines are comments, explaining what is happening. Next the background is applied to the clock module. Finally it is applied to the calendar module, with a different transparency - it produces a dark grey background.
        // background-color: rgba(red, green, blue, alpha)
        // red, green, blue: 0 - 255
        // alpha: 0 -1 (0=transparent, 1=opaque)
        .module.clock {
          background-color:rgba(0,0,0,0.4);
          border-radius:8px;
          padding:8px;
        .module.calendar {
          background-color:rgba(0,0,0,0.6);
          border-radius:8px;
          padding:8px;
          sdetweil @JohnGalt
          @JohnGalt dont need .module
          J 2 Replies Last reply Reply Quote 0
            sdetweil @videogame95
            @videogame95 sorry, I missed your question
            https://docs.magicmirror.builders/modules/customcss.html#target-a-specific-module
            .modulename .... {
            like
            .clock {
            applies to the stuff in the clock module output
            the .modulename … before the { is called the css selector clause… it ‘selects’ the elements the data inside the {} will apply to
            I use this to remind me of the things that can go there …
            https://www.w3schools.com/cssref/css_selectors.php
            here is a clause in my MMM-Config module form to hide a useless element I have no control over
            .possibly-hidden-tab div:nth-child(2)  > div > div >div >ul >li:only-child >a[rel*="Item 1"] {
              display: none;
            the selector clause ALWAYS selects ALL elements in the document that match the selector… SO .modulename prefix means u only mess up your stuff!
              JohnGalt @sdetweil
              @sdetweil - Thanks! I will clean up my code some, when I get a chance. I appreciate the input.
                JohnGalt @sdetweil
                @sdetweil – BTW, it this also true for all modules? That is, also for non-default modules? [Somehow I had internalized that even if default modules could be addressed this way, others required something like the following]:
                .module.MMM-WeatherAlerts header {text-align: left;
                .module.MMM-WeatherAlerts {  background-color:rgba(255,255,255,0.2);
                  sdetweil @JohnGalt
                  @JohnGalt its the same for all modules…
                  .clock
                  .calendar
                  .MMM-Config
                  whatever
                  when MM puts the content in a section it adds a class (.modulename) to that block of content
                    JohnGalt @sdetweil
                    @sdetweil - Great, good to know.
                      sdetweil @JohnGalt
                      @JohnGalt here is a copy out of some of the content for a weather module
                      <div class="container" style="display: block;">
                           <div id="module_5_weather" class="module weather weather">
                               <header class="module-header" style="display: none;"></header>
                                 <div class="module-content">
                                     // module content would go here
                                    <div class="dimmed light small"> Cargando … </div>
                                </div>
                          </div>
                      </div>
                      on this line
                      you have the modulename as a class
                      and the id “module_5_weather”
                      as the selectable elements to target the content inside
                      module_5 is the count of modules top down starting at 0
                      good if u had multiple instances of a module and wanted to target different ones for different styles
                        JohnGalt @sdetweil
                        @sdetweil - Thanks Sam. This will help when I work on cleaning up my display overall, as i do have multiple instances of both calendar and weather running!
