    Throwing down the gauntlet
    85 Posts 11 Posters 99.0k Views 11 Watching
    • johnnyboyJ Offline
      johnnyboy @Mykle1
      This post is deleted!
        jbeck615 @strawberry 3.141
        @strawberry-3.141 So I can definitely post the css coding but my pi takes some time to start up some days it seems… anyway what I was ultimately trying to do was, using wunderground, get rid of the last column as you and Mykle1 showed above and get the icon for current to look realistic/color but keep the forecast icons as generic icons. so the way i attempted this was incorporate all of the edits you all provided above. then i repeated wunderground twice in the modules, one to show current and the color icon (realistic icon) and a second time just to show forecast but with generic icons. however when i stack them both in top right thats where i get the unwanted icons. if i put current wunderground in the top center then they go away. thoughts? i can provide css if needed for sure. thanks for even looking! ![alt text](0_1488306217254_Picturemirror.jpg image url)
          jbeck615 @Mykle1
          @Mykle1 thanks for sharing! the width of the monthly calendar was bothering me and i was going to research later anyway!
            Mykle1 Project Sponsor Module Developer @johnnyboy
            @johnnyboy said in Throwing down the gauntlet:
            is that why you put the ! important there?
            No sir, I do believe that this is the entry that constrains the module to 200 pixels ( and the color)
            .calendar_monthly {
              width: 200px;
              color: #6f6;
            johnnyboyJ 1 Reply Last reply Reply Quote 0
              Mykle1 Project Sponsor Module Developer @jbeck615
              @jbeck615 said in Throwing down the gauntlet:
              Cool. I’ve found answers that way too, before I even had the question
                You would have to repeat wunderground twice in the config.js file, not the modules, for starters
                  johnnyboy @Mykle1
                    jbeck615 @Mykle1
                    @Mykle1 thats what i meant but poorly wrote that. i got the idea from your script but im thinking that there may be a away to have the icon for the current different from the forecast icons
                    • strawberry 3.141S Offline
                      strawberry 3.141 Project Sponsor Module Developer @jbeck615
                      @jbeck615 can you share your wunderground config which leads to the unwanted icons?
                      J 2 Replies Last reply Reply Quote 0
                        @strawberry-3.141
                        /* global Module */
                        /* Magic Mirror
                         * Module: WunderGround
                         * By RedNax
                         * MIT Licensed.
                        Module.register("MMM-WunderGround", {
                            // Default module config.
                            defaults: {
                                apikey: "8cxxxxxx",
                                pws: "",
                                currentweather: 1,
                                coloricon: false,
                                units: config.units,
                                windunits: "mph", // choose from mph, bft
                                updateInterval: 10 * 60 * 1000, // every 10 minutes
                                animationSpeed: 1000,
                                timeFormat: config.timeFormat,
                                lang: config.language,
                                showWindDirection: true,
                                fade: false,
                                fadePoint: 0.25, // Start on 1/4th of the list.
                                tz: "",
                                fcdaycount: "5",
                                fcdaystart: "0",
                                hourly: "0",
                                hourlyinterval: "3",
                                hourlycount: "2",
                                fctext: "1",
                                alerttime: 5000,
                                roundTmpDecs: 1,
                                UseCardinals: 0,
                                layout: "vertical",
                                sysstat: 0,
                                scaletxt: 1,
                                retryDelay: 2500,
                                apiBase: "http://api.wunderground.com/api/",
                                iconTableDay: {
                                    "chanceflurries": "wi-day-snow-wind",
                                    "chancerain": "wi-day-showers",
                                    "chancesleet": "wi-day-sleet",
                                    "chancesnow": "wi-day-snow",
                                    "chancetstorms": "wi-day-storm-showers",
                                    "clear": "wi-day-sunny",
                                    "cloudy": "wi-cloud",
                                    "flurries": "wi-snow-wind",
                                    "fog": "wi-fog",
                                    "haze": "wi-day-haze",
                                    "hazy": "wi-day-haze",
                                    "mostlycloudy": "wi-cloudy",
                                    "mostlysunny": "wi-day-sunny-overcast",
                                    "partlycloudy": "wi-day-cloudy",
                                    "partlysunny": "wi-day-cloudy-high",
                                    "rain": "wi-rain",
                                    "sleet": "wi-sleet",
                                    "snow": "wi-snow",
                                    "tstorms": "wi-thunderstorm"
                                iconTableNight: {
                                    "chanceflurries": "wi-night-snow-wind",
                                    "chancerain": "wi-night-showers",
                                    "chancesleet": "wi-night-sleet",
                                    "chancesnow": "wi-night-alt-snow",
                                    "chancetstorms": "wi-night-alt-storm-showers",
                                    "clear": "wi-night-clear",
                                    "cloudy": "wi-night-alt-cloudy",
                                    "flurries": "wi-night-alt-snow-wind",
                                    "fog": "wi-night-fog",
                                    "haze": "wi-night-alt-cloudy-windy",
                                    "hazy": "wi-night-alt-cloudy-windy",
                                    "mostlycloudy": "wi-night-alt-cloudy",
                                    "mostlysunny": "wi-night-alt-partly-cloudy",
                                    "partlycloudy": "wi-night-alt-partly-cloudy",
                                    "partlysunny": "wi-night-alt-partly-cloudy",
                                    "rain": "wi-night-alt-rain",
                                    "sleet": "wi-night-alt-sleet",
                                    "snow": "wi-night-alt-snow",
                                    "tstorms": "wi-night-alt-thunderstorm"
                        • 6
                        • 7
                        • 8
                        • 9
                        • 6 / 9
