    MMM-PIR-Sensor-Lite modification
    27 Posts 4 Posters 14.4k Views 5 Watching
    • bugsounetB Offline
      bugsounet Banned @bugsounet
      @bugsounet said in MMM-PIR-Sensor-Lite modification:
      I will create MMM-Pir
      It’s done.
      It’s based with my EXT-Screen and EXT-Pir plugins
      I have rewrite and clean it for MMM using
      @wishmaster270:
      do you want to try to maintened it ?
      I can add you as contributor
      (I see that you fork EXT-Screen)
      I have really no time for any MMM :/
      • wishmaster270W Offline
        wishmaster270 Module Developer @bugsounet
        @bugsounet Hi,
        sorry but at the moment a do not have plans to maintain more modules than i already do.
        In addition i do not see a reason why there should be a need for a additional screensave module.
        Most of the features are present in the exiting ones. I do not like the idea of putting the GPIO logic and screensave logic into the same module and had problems with it in my setup in the past. Thats why i created the two separted modules.
        I forked MMM-Screen as i wanted to check if there is a easy way to implement the CEC logic to my screensave module. I do not think it would be a big deal. The problem is that i do not have a CEC aware monitor at the moment and do not have the time to build a dev environment with my tv.
        • F Offline
          Freddy_boy
          Terrific! I just installed MMM-Pir and it works properly as before. I am using mode 4 (HDMI CEC) and the monitor responds as expected. Thanks very much for the quick response! You guys are a real credit to this open source project!
          bugsounetB 1 Reply Last reply Reply Quote 0
          • F Freddy_boy referenced this topic on
            bugsounet Banned @Freddy_boy
            @Freddy_boy perfect !
            You understand now why i prefer works alone :D
            I repeat again … If someone have the time to maintened this new module,
            I will add a contributor access :)
            @sdetweil: this module can be referenced on the third party module page ;)
              sdetweil @bugsounet
              @bugsounet sure give me access
                bugsounet Banned @sdetweil
                @sdetweil said in MMM-PIR-Sensor-Lite modification:
                sended ;)
                  sdetweil @bugsounet
                  @bugsounet got it
