    MMM-ValuesByNotification, CSS Advice...
    8 Posts 2 Posters 1.0k Views 2 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      I can’t seem to figure this out.
      I currently have the following display set up:
      What I want is something more like this, ignoring the lines and font size (Excel)
      Can anyone help figure this out? ( @wishmaster270 tagged as author )
      Existing CSS changes in custom.css:
      /* ValuesByNotification */
      .MMM-ValuesByNotification .vbn .groupWrapper {
          border-radius: 0px;
          border-style: none;
      .MMM-ValuesByNotification .vbn .groupsWrapper, .MMM-ValuesByNotification .vbn .groupWrapper, .MMM-ValuesByNotification .vbn .itemsWrapper, .MMM-ValuesByNotification .vbn .valueWrapper{
          flex-direction: row;
          column-gap: 20px;
          flex-grow: 1;
      .MMM-ValuesByNotification .vbn .groupsWrapper {
          column-gap: 10px;
      .MMM-ValuesByNotification .vbn .itemsWrapper {
      	row-gap: 0px;
      	column-gap: 0px;
      	flex-direction: column;
      .MMM-ValuesByNotification .vbn .itemTitle {
          text-decoration: none;
          margin: 0px;
      .MMM-ValuesByNotification .vbn .valuesWrapper {
      	gap: 0px;
      	row-gap: 0px;
      	column-gap: 0px;
      Thanks!
      wishmaster270W 2 Replies Last reply Reply Quote 0
      • wishmaster270W Offline
        wishmaster270 Module Developer @BKeyport
        @BKeyport Hi and sure I will try to help.
        I think a possible way would be to set some min-width.
        Can you share your module config?
        It’s easier for me to setup a test environment with it.
          @BKeyport Hi,
          tested some things. You want it to look something like this, right:
          I used these special config options:
          • As you do not display any group or item title i set the positions to “e” only. Which means only elements, nothing else.
          • As the titles of the first and second column are very different (the second column has shorter titles) i decided to add the classes “col1” and “col2” to the items.
          • As i did not want to setup a complete environment i set the “naValue” of each value to the values of your screenshot. Please skip that step!
          			module: "MMM-ValuesByNotification",
          			position: "top_center",
          			//header: "Module-1",
          				updateInterval: 3600,
          				groupPositions: "e",
          				itemPositions: "e",
          				unitSpace: true,
          				groups: [
          						items: [
          								notification: "TEST1",
          								classes: "col1",
          								values: [
          										valueTitle: "Temperature Outdoors",
          										naValue: "68.60",
          										valueUnit: "°"
          								notification: "TEST2",
          								classes: "col2",
          								values: [
          										valueTitle: "Indoor Humidity",
          										naValue: "26.8",
          										valueUnit: "%"
          								notification: "TEST3",
          								classes: "col1",
          								values: [
          										valueTitle: "My Office Temperature",
          										naValue: "77.59",
          										valueUnit: "°"
          								notification: "TEST4",
          								classes: "col2",
          								values: [
          										valueTitle: "Outdoor Humidity",
          										naValue: "58.4",
          										valueUnit: "%"
          								notification: "TEST5",
          								classes: "col1",
          								values: [
          										valueTitle: "CPU Case Temperature",
          										naValue: "87.15",
          										valueUnit: "°"
          								notification: "TEST6",
          								classes: "col2",
          								values: [
          										valueTitle: "Wind Speed",
          										naValue: "0",
          										valueUnit: "MPH"
          								notification: "TEST7",
          								classes: "col1",
          								values: [
          										valueTitle: "Utility Room Temperature",
          										naValue: "92.50",
          										valueUnit: "°"
          								notification: "TEST8",
          								classes: "col2",
          								values: [
          										valueTitle: "Wind Direction",
          										naValue: "N",
          										valueUnit: " "
          I then set the following custom.css options:
          .MMM-ValuesByNotification{
            width: 700px;
            border-radius: 0px;
            border-style: none;
            flex-wrap: wrap;
            column-gap: 30px;
          .MMM-ValuesByNotification .vbn .itemWrapper {
            justify-content: unset;
          .MMM-ValuesByNotification .vbn .valueWrapper {
            column-gap: 10px;
          .MMM-ValuesByNotification .vbn .col1 .valueWrapper {
            min-width: 277px;
          .MMM-ValuesByNotification .vbn .col2 .valueWrapper {
            min-width: 213px;
          .MMM-ValuesByNotification .vbn .valueTitle {
            text-align: left;
          .MMM-ValuesByNotification .vbn .col1 .valueTitle {
            min-width: 210px;
          .MMM-ValuesByNotification .vbn .col2 .valueTitle {
            min-width: 150px;
          • BKeyportB Offline
            BKeyport Module Developer @wishmaster270
            CSS in custom.css is exactly as you did, with the exception of having the overall display “inline-flex” with other modules to have the top bar fill horizontally rather than vertically.
            Here’s my config as present.
            			module: "MMM-ValuesByNotification", // https://github.com/Tom-Hirschberger/MMM-ValuesByNotification
            			position: "top_bar",
            				animationSpeed: 0,
            				updateInterval: 15,
            				itemPositions: "e",
            				reuseCount: 99,
            				transformerFunctions: {
            					degToCompass: (num) => {
            						val = ((num/22.5)+.5) | 0;
            						arr = ["N","NNE","NE","ENE","E","ESE", "SE", "SSE","S","SSW","SW","WSW","W","WNW","NW","NNW"];
            						res = arr[(val % 16)];
            						return res;
            				groups: [
            						items: [
            								notification: "WeatherLink",
            								classes: "col1",
            								values: [
            										valueUnit: "°",
            										jsonpath: "data.conditions[0].temp",
            										valueFormat: "Number(${value}).toFixed(2)",
            								notification: "TempRoom",
            								classes: "col1",
            								values: [
            										valueUnit: "°",
            										jsonpath: "temperature_f",
            								notification: "TempCase",
            								classes: "col1",
            								values: [
            										valueUnit: "°",
            								classes: "col1",
            								values: [
            										valueUnit: "°",
            										jsonpath: "data.conditions[1].temp_in",
            								classes: "col2",
            								values: [
            										valueUnit: "%",
            										jsonpath: "data.conditions[1].hum_in",
            										valueUnit: "%",
            										jsonpath: "data.conditions[0].hum",
            										valueUnit: "MPH",
            										jsonpath: "data.conditions[0].wind_speed_last",
            										unitSpace: true,
            										jsonpath: "data.conditions[0].wind_dir_last",
            										valueTransformers: ["degToCompass"],
              @BKeyport Hi,
              thank you for the config. There was a main difference in yours and mine. You added the last four values in one item, i had single items.
              There was a problem with the column definitions in you config, but i think i figured the things out.
              Its a little bit messy but i think it will work:
              custom.css
                width: 700px;
                border-radius: 0px;
                border-style: none;
                flex-wrap: wrap;
                column-gap: 30px;
                justify-content: space-around;
                column-gap: 10px;
                min-width: 290px;
                min-width: 260px;
              .MMM-ValuesByNotification .vbn .wrap1 {
                justify-content: flex-start;
                text-align: left;
                min-width: 210px;
                min-width: 200px;
              config.js:
              		animationSpeed: 0,
              		updateInterval: 15,
              		itemPositions: "e",
              		reuseCount: 99,
              				return res;
              		groups: [
              				items: [
              						classes: "col1",
              						values: [
              								valueUnit: "°",
              						classes: "col2",
              						values: [
              								valueUnit: "°",
              						classes: "col1",
              						values: [
              								valueUnit: "°",
              						classes: "col2",
              						values: [
              								valueUnit: "°",
              						classes: "col1",
              						values: [
              								valueUnit: "%",
              						classes: "col2",
              						values: [
              								valueUnit: "%",
              						classes: "col1",
              						values: [
              								valueUnit: "MPH",
              								unitSpace: true,
              						classes: "col2",
              						values: [
              Edit: Maybe i have time to search for an easier solution at the weekend.
              • BKeyportB Offline
                @wishmaster270 Getting closer, now just out of order, but much better organized.
                It is also not sharing the top bar the way I like on the test screen, haven’t had time to go check the real display.
                  @BKeyport Hi and sorry, my fault.
                  I added the items in the wrong order to the group.
                  The main idea is that all items are in a row. Every time the space on the right side is not enough to display the next item a new line starts.
                  As the maximum width of the module is set to 700px only two items fit in a row. Thats why we get two columns here but the order of the items in the config matters.
                  In the config i additionally add the classes col1 and col2 to the items. This way i can set the width of the titles in the first column different to the ones of the second column.
                  I re-arranged the items to the structure of the initial post and increased the width of the titles a little bit:
                  		animationSpeed: 0,
                  		itemPositions: "e",
                  		reuseCount: 99,
                  				return res;
                  		groups: [
                  				items: [
                  						classes: "col1",
                  						values: [
                  								valueUnit: "°",
                  						classes: "col2",
                  						values: [
                  								valueUnit: "%",
                  						classes: "col1",
                  						values: [
                  								valueUnit: "°",
                  						classes: "col2",
                  						values: [
                  								valueUnit: "%",
                  						classes: "col1",
                  						values: [
                  								valueUnit: "°",
                  						classes: "col2",
                  						values: [
                  								valueUnit: "MPH",
                  								unitSpace: true,
                  						classes: "col1",
                  						values: [
                  								valueUnit: "°",
                  						classes: "col2",
                  						values: [
                    width: 700px;
                    border-radius: 0px;
                    border-style: none;
                    flex-wrap: wrap;
                    column-gap: 30px;
                    column-gap: 10px;
                    min-width: 310px;
                    min-width: 285px;
                    text-align: left;
                    min-width: 220px;
                    min-width: 210px;
                  • BKeyportB Offline
                    @wishmaster270 Great start, now to adjust to fit… 🤣
                    Edit: here I am adjusting it and trying to figure out why it wouldn’t move up to the bar, then I realized, you had it in Top Center. 😞😞😞😞😖😖😖😖
