    Default weather module question
    5 Posts 4 Posters 1.2k Views 4 Watching
    • earnestrichardsE Offline
      earnestrichards
      It seems that recently the default weather forecast has been showing what appears to be the forecast heat index instead of the forecast high. This may be an issue at the source?Screen Shot 2023-07-18 at 10.06.44 AM.png
      S ankonaskiff17A 2 Replies Last reply Reply Quote 0
        sdetweil @earnestrichards
        @earnestrichards I would open an issue on the MagicMirror GitHub
        please provide the config for the weather module… of course xxxxx out any apikey
        • ankonaskiff17A Offline
          ankonaskiff17 @earnestrichards
          @earnestrichards Which weather provider are you using?
            boblewis
            @ankonaskiff17 As I can see in the image snapshot the weather provider seems to be OpenWeather.
            ankonaskiff17A 1 Reply Last reply Reply Quote 0
              ankonaskiff17 @boblewis
              @boblewis I use weather.gov and look is different.
