    MMM-SpaceX Only Showing 2020 Launches
    Scheduled Pinned Locked Moved Fun & Games
    9 Posts 5 Posters 5.1k Views 4 Watching
    • K Offline
      KungFuCharlie
      Re: MMM-SpaceX
      This is an awesome idea for a module and it is perfect since I am currently living near KSC. The problem is that it is only showing two launches from 2020 when I have it set to display “upcoming” launches. Is there an issue with the API or the parser? Thoughts on how to fix this?
      mumblebajM W ankonaskiff17A 3 Replies Last reply Reply Quote 0
      • mumblebajM Online
        mumblebaj Module Developer @KungFuCharlie
        @KungFuCharlie The API has changed for this. However, it also only returns evens from last year and nothing for this year. You can check this documentation. https://github.com/r-spacex/SpaceX-API/tree/master/docs#rspacex-api-docs
        • W Offline
          Wenike @KungFuCharlie
          @KungFuCharlie https://github.com/poketcalulator/MMM-Rocketlaunch works but does pull in more launches than at KSC.
          • ankonaskiff17A Offline
            ankonaskiff17 @KungFuCharlie
            @KungFuCharlie FWIW I would not expend too much energy on when SpaceX is going to launch anything other than paying satellites and provisions to ISS. That’s his prerogative as right now it is just a testing campaign but the dude launches on 420 because “heh heh weed” isn’t going to give you a schedule.
            Now if you can find anything coming out of KSC & CCSFS for ULA, SpaceX contracted missions probably accurate.
            Musk/SpaceX showboating Starship and the heavy lift booster and expecting them to stick to anything remotely like a schedule is a waste of your time.
            • K Offline
              KungFuCharlie @ankonaskiff17
              @ankonaskiff17 Your personal opinion about Elon Musk and SpaceX was not helpful and did not answer my question.
              ankonaskiff17A 1 Reply Last reply Reply Quote 0
                @KungFuCharlie Well, I’m not a fan of Musk but am a fan of SpaceX and have been following SpaceX for years and you are not going to get a posted schedule from SpaceX.
                Dude just doesn’t do things like that.
                The fact that you can’t find anything is because there is nothing, not because you have’t found it.
                KSC puts out a launch schedule for KSC and CCSFS may put out a schedule for launches on their base but military generally cagey about putting out schedules for anything under assumption you are providing possible information to adversaries.
                FWIW, I’ve been to 2 SpaceX launches and SpaceX DOES NOT PUT OUT A SCHEDULE
                The best you are going to get is to get on both KSC & SpaceX email notification lists and you’ll get an email heads-up when tickets go on sale.
                SpaceX is a privately owned business and as such they are under no obligation to put out a schedule to the public.
                • W Offline
                  Wenike @ankonaskiff17
                  @ankonaskiff17 Just throwing out there that the module I referenced earlier does indeed have SpaceX launches on it, it just also has launches elsewhere (China being one of them and non-SpaceX but US-based launches too). And outside of MagicMirror, SpaceFlight Now has various rocket launches listed, including SpaceX and some of them farther in the future (like there’s an Arctic Satellite Broadband Missing going up on SpaceX sometime in 4th quarter this year).
                    ankonaskiff17 @Wenike
                    @Wenike I think what you get into is how accurate you want your schedule to be. Having watched both KSC and SpaceX for the purpose of buying launch viewing tickets, many will be listed as NET rather than a specific date and time. That is one issue. Another is that there may be some technical issue with the satellite so it gets shuffled back to a point where the orbital requirements allow the launch to proceed.
                    Then you have government/military launches that tend to be very low profile.
                    I know other guy got offended by my weed comment relating to Musk, weed, and launches but it was a valid point.
                    The initial launch of the full stack Starship/Booster was scheduled for 4/17. Well there are a couple of sites, LabPadre and Nasa Space Fight (NSF) that aren’t garbage that follow SpaceX .
                    Me and lots of other people were tuned in to watch launch on 4/17 but in chat people were speculating if there would be a scrub on that day that pushed launch back to 4/20 and sure enough that’s what happened.
                    Commentary after the scrub was a lot of “LOL Who didn’t see that coming.”
                    A few years back, NASA Administrator under Trump went and semi-publicly chewed out Musk because of film footage of Musk and Joe Rogan smoking dope when Musk was interviewed by Rogan.
                    • C Offline
                      claytonstephens @Wenike
                      @Wenike It worked. I created this Modul thanks to your github link: https://github.com/poketcalulator/bloxd ioMMM-Rocketlaunch
