    Repeating entries don't appear in Upcoming Events.
    11 Posts 3 Posters 4.2k Views 3 Watching
    • Cliff365C Offline
      Cliff365
      Not sure if this is a bug, or working as designed. If I have an event that occurs for multiple days, it only appears in the upcoming events on the first day.
      My preferred choice would be to have the event appear on each day of the repeating event. Is there a setting I can flip so this happens?
        sdetweil @Cliff365
        @Cliff365 is this using the default calendar module?
        Cliff365C 1 Reply Last reply Reply Quote 0
        • Cliff365C Offline
          Cliff365 @sdetweil
          @sdetweil Yes, it’s the default module.
            sdetweil @Cliff365
            @Cliff365 we only display the start date/time. and tomorrow we will display nth day of list, and the next day shows nth+1. we WILL NOT display today start AND tomorrow AND the next all at once
            • Cliff365C Offline
              Cliff365 @sdetweil
              @sdetweil That’s what I suspected. FWIW, in my case it would be extremely helpful for the repeating entry to appear for each day the appointment repeats.
              S lavolp3L 2 Replies Last reply Reply Quote 0
                sdetweil @Cliff365
                @Cliff365 it would take recoding the module to make the additional entries appear.
                I would look to other modules that provide that support
                • lavolp3L Offline
                  lavolp3 Module Developer @Cliff365
                  @Cliff365 Just so I understand correctly: You want a multi-day event, like a holiday, appear for every upcoming day?
                  You could consider using the daily view of the calendar, there your event would be split into days. Maybe it helps?
                  IIRC it is the timeFormat: 'dateheaders'option in the config
                  "timeFormat
                  Display event times as absolute dates, or relative time, or using absolute date headers with times for each event next to it
                  Possible values: absolute or relative or dateheaders
                  Default value: relative"
                  How to troubleshoot modules
                  MMM-soccer v2, MMM-AVStock
                  • Cliff365C Offline
                    Cliff365 @lavolp3
                    @lavolp3 This might help. We use a calendar to let the kids know it is their turn to clean the recroom on a weekend. So ‘Tommy-Recroom’ appears in upcoming events for Friday. If Tommy forgets on Friday, his alert is now gone. To compensate for that, I have to enter Tommy for Friday, Saturday, Sunday so his name stays on upcoming events.
                    In my case, it would be fantastic if a single ‘Tommy-Recroom’ appeared on a recurring event for that day.
                    Does that make sense now?
                      sdetweil @Cliff365
                      @Cliff365 in the default calendar you can do
                      sliceMultiDayEvents: true
                      this will separate each day of multi day into separates…
                      but now you will have the opposite problem…
                      one event with recurring for f/s/s will be 3 events. 1 for each day
                      Cliff365C 2 Replies Last reply Reply Quote 0
                      • Cliff365C Offline
                        Cliff365 @sdetweil
                        @sdetweil I’ll give that a try. That might just work for my situation. Thanks!
                        • Cliff365C Offline
                          Cliff365 @sdetweil
                          @sdetweil “one event with recurring for f/s/s will be 3 events. 1 for each day”
                          Totally fine with that. That’s what I have now, but now I have much less typing.
