    Can't install new version
    7 Posts 2 Posters 1.2k Views 2 Watching
      musson
      Clean install on PI 4 16gb sd card. Did the node 20 install from https://github.com/sdetweil/MagicMirror_scripts successfully.
      Then ran the install script and got this:
      Any ideas?
      (node:16817) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
      npm ERR! code ETIMEDOUT
      npm ERR! syscall read
      npm ERR! errno ETIMEDOUT
      npm ERR! network Invalid response body while trying to fetch https://registry.npmjs.org/playwright-core: read ETIMEDOUT
      npm ERR! network This is a problem related to network connectivity.
      npm ERR! network In most cases you are behind a proxy or have bad network settings.
      npm ERR! network
      npm ERR! network If you are behind a proxy, please make sure that the
      npm ERR! network ‘proxy’ config is set properly. See: ‘npm help config’
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-10-02T15_57_42_305Z-debug-0.log
      pi@piMM2a:~ $
        sdetweil @musson
        @musson I saw that on one system today. but it didn’t cause a problem…
        node v20 is a mess
        I just sent update to the scripts to install node 18 on buster
        but apt get update sets up node 20.5
        no fix yet
          musson @sdetweil
          @sdetweil Thank you
            sdetweil @musson
            @musson try the upgrade script again, with force instead of apply
            it will remove and and add the right version of node the right way, including on buster
            please advise your results
              musson @sdetweil
              @sdetweil I was doing a install on a fresh bullseye system.
              I will try the install script again. I have nothing to update, sorry.
                sdetweil @musson
                @musson sorry, missed 'install ’ words this morning…
                  musson
                  The install was successful :)
                  I still get a bunch of these waning’s though that’s probably not your issue.
                  Thanks for all the effort you put into this project.
                  (node:2431) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
                  • S sdetweil moved this topic from General Discussion on
