    Which calendar modul is able to get Nextcloud (WebDAV) calendars synchronized?
    9 Posts 3 Posters 2.2k Views 3 Watching
      bdream @MMRIZE
      @MMRIZE
      position: how do the MM know where to display?
      serverUrl: seriously. Thansk!
      .ics: you are right. That was a try after I got the error using credentials.
      I wantet so see if this module is working.
      Error shown by: npm run config:check
      Your configuration file contains syntax errors :(
      but I use
                              module: "MMM-CalDAV",
                              position: "bottom_left",
                                    serverUrl: "https://DOMAIN.TDL/NEXTCLOUD/remote.php/dav/calendars/USER/pers%c3%b6nlich/"
                                    credentials: {
                                      username: "USER",
                                      password: "GEHEIM",
                                  vcalendarHeader: true
      cheers, bdream
      mumblebajM M 2 Replies Last reply Reply Quote 0
      • mumblebajM Offline
        mumblebaj Module Developer @bdream
        @bdream You are missing a comma after the serverUrl
          bdream
          @mumblebaj you are right. My bad!
          Now it runs without failure but also without displaying the calendar.
          I deleted already position: "bottom_left",
          What module do I need to activate for display and how do I get the CalDAV module linked?
          cheers, bdream
            MMRIZE @bdream
            @bdream
            When you need oauth to use your Caldav server, I’ll upgrade the module sooner. Currently this module supports only basic auto.
              MMRIZE @bdream
              @bdream
              “http://YOURMM/modules/MMM-CalDAV/public/Test.ics” would be accessible. (See under the public directory of module.)
              Now you can use this as a ics feed and f default calendar module.
