    Magic Mirror logo appears at Boot and then the Raspberry desktop
    21 Posts 2 Posters 9.6k Views 2 Watching
      Syosse
      Hello
      I ran following commands from a tutorial
      1.) Install Magic Mirror:
      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
      2.) Turn off screen saver and setup pm2 to autostart MM on boot.
      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)”
      3.) Add using pm2 to autostart MagicMirror at bootup
      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
      This is the Command Screen:
      Anyone know why it shows only the Desktop and not the Magic Mirror ?
      Thanks!!!
        sdetweil @Syosse
        @Syosse you don’t need to run all the commands
        the install asks if u want to turn off the screensaver. if you said yes, then it’s done
        if u said no then you would run the screensaver off script it’s the exact same script code. it’s just there if you changed your mind.
        now on to the pm2 thing
        same same. but
        in some systems the automation script has trouble
        do this
        pm2 startup
        it will output a command to execute
        copy/paste that command and hit enter
        when it’s done do
        | edited
        pm2 start ~/MagicMirror/installers/pm2_MagicMirror_new.json
        pm2 save
        then reboot
          Syosse @sdetweil
          @sdetweil said in Magic Mirror logo appears at Boot and then the Raspberry desktop:
          same same. but
          do this
          pm2 startup
          when it’s done do
          pm2 start ~/MagicMirror/installers/pm2_MagicMirror.json
          pm2 save
          then reboot
          All right thanks for the Information with the Screensave, now its for me clear.
          I have done u Command but it shows me : [PM2][ERROR] Script not found: /home/Admin/up
          do u know why ?
          Thanyk so much!
            sdetweil @Syosse
            @Syosse if you used either of my scripts I download that file
            do
            ls ~/MagicMirror/installers -laF
              @sdetweil is Admin the root user, or the userid u created at SD card startup time?
              pm2 will run as user not root
                Syosse @sdetweil
                Admin is the Credentials that i insert at the beginning of Install Raspberry Pi Imager:
                ls ~/MagicMirror/installers -laF:
                Thanks so much!
                S 2 Replies Last reply
                  sdetweil @Syosse
                  @Syosse can you do
                  cat  ~/MagicMirror/installers/pm2_MagicMirror.json
                  thx
                    sdetweil @Syosse
                    @Syosse can u also paste the contents of
                    ~/MagicMirror/installers/pm2_setup.log
                      Syosse @sdetweil
                      yea of course:
                      Thanks so much!
                        sdetweil @Syosse
                        @Syosse ok, try this then
                        cat  ~/MagicMirror/installers/pm2_MagicMirror_new.json
                          Syosse @sdetweil
                          thanks so much!
                            sdetweil @Syosse
                            @Syosse and then if you do
                            if it works, then
                            pm2 save
                            then
                            sudo reboot
                              Syosse @sdetweil
                              if it works, then
                              pm2 save
                              then
                              sudo reboot
                              Omg it works!!
                              Oh man, what was the problem?
                              Thanks soo much !!!
                                sdetweil @Syosse
                                @Syosse said in Magic Mirror logo appears at Boot and then the Raspberry desktop:
                                the pm2 startup generated command fails when in a script suddenly
                                but it works when done manually…
                                I have issue open since May
                                https://github.com/Unitech/pm2/issues/5582
                                  Syosse @sdetweil
                                  thanks man , unfortunately there is still a problem as soon as I enter the following commands it works and magic mirror starts but after reboot the desktop comes back
                                  with this command Magic Mirror starts
                                  after this command it still works
                                  pm2 save
                                  and after this reboot command the raspberry pi restarts and it shows the desktop instead Magic Mirror.
                                   sudo reboot
                                  thanks so much
                                    sdetweil @Syosse
                                    @Syosse did you execute the command output from first
                                    pm2 startup
                                      Syosse @sdetweil
                                      pm2 startup
                                      yea of course:
                                      Admin@magicmirror:~ $ pm2 startup
                                      [PM2] Init System found: systemd
                                      [PM2] To setup the Startup Script, copy/paste the following command:
                                      sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u Admin --hp /home/Admin
                                      thanks so much
                                        sdetweil @Syosse
                                        @Syosse and copy paste THAT command and execute it
                                        sudo env…
                                          @Syosse we got it working in chat
                                            Syosse @sdetweil
                                            Finally it works many many thanks to @sdetweil
