Magic Mirror logo appears at Boot and then the Raspberry desktop
21 Posts 2 Posters 6.0k Views 2 Watching
    Syosse
    Hello
    I ran following commands from a tutorial
    1.) Install Magic Mirror:
    bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
    2.) Turn off screen saver and setup pm2 to autostart MM on boot.
    bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)”
    3.) Add using pm2 to autostart MagicMirror at bootup
    bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)”
    This is the Command Screen:
    Anyone know why it shows only the Desktop and not the Magic Mirror ?
    Thanks!!!
    S 1 Reply Last reply Oct 22, 2023, 11:19 AM Reply Quote 0
      sdetweil @Syosse
      @Syosse you don’t need to run all the commands
      the install asks if u want to turn off the screensaver. if you said yes, then it’s done
      if u said no then you would run the screensaver off script it’s the exact same script code. it’s just there if you changed your mind.
      now on to the pm2 thing
      same same. but
      in some systems the automation script has trouble
      do this
      pm2 startup
      it will output a command to execute
      copy/paste that command and hit enter
      when it’s done do
      | edited
      pm2 start ~/MagicMirror/installers/pm2_MagicMirror_new.json
      pm2 save
      then reboot
      S 1 Reply Last reply Oct 22, 2023, 12:36 PM Reply Quote 0
        Syosse @sdetweil
        @sdetweil said in Magic Mirror logo appears at Boot and then the Raspberry desktop:
        same same. but
        do this
        pm2 startup
        when it’s done do
        pm2 start ~/MagicMirror/installers/pm2_MagicMirror.json
        pm2 save
        then reboot
        All right thanks for the Information with the Screensave, now its for me clear.
        I have done u Command but it shows me : [PM2][ERROR] Script not found: /home/Admin/up
        do u know why ?
        Thanyk so much!
        S 1 Reply Last reply Oct 22, 2023, 12:40 PM Reply Quote 0
          sdetweil @Syosse
          @Syosse if you used either of my scripts I download that file
          do
          ls ~/MagicMirror/installers -laF
          S 1 Reply Last reply Oct 22, 2023, 12:43 PM Reply Quote 0
            @sdetweil is Admin the root user, or the userid u created at SD card startup time?
            pm2 will run as user not root
            S 1 Reply Last reply Oct 22, 2023, 12:48 PM Reply Quote 0
              Syosse @sdetweil
              Admin is the Credentials that i insert at the beginning of Install Raspberry Pi Imager:
              ls ~/MagicMirror/installers -laF:
              Thanks so much!
              S 2 Replies Last reply Oct 22, 2023, 1:28 PM Reply Quote 0
                sdetweil @Syosse
                @Syosse can you do
                cat  ~/MagicMirror/installers/pm2_MagicMirror.json
                thx
                  sdetweil @Syosse
                  @Syosse can u also paste the contents of
                  ~/MagicMirror/installers/pm2_setup.log
                  S 1 Reply Last reply Oct 22, 2023, 3:19 PM Reply Quote 0
                    Syosse @sdetweil
                    yea of course:
                    Thanks so much!
                    S 1 Reply Last reply Oct 22, 2023, 3:20 PM Reply Quote 0
                      sdetweil @Syosse
                      @Syosse ok, try this then
                      cat  ~/MagicMirror/installers/pm2_MagicMirror_new.json
                      S 1 Reply Last reply Oct 22, 2023, 3:26 PM Reply Quote 0
                      1 / 3
