    Magic Mirror logo appears at Boot and then the Raspberry desktop
    21 Posts 2 Posters 9.3k Views 2 Watching
      Syosse @sdetweil
      @sdetweil said in Magic Mirror logo appears at Boot and then the Raspberry desktop:
      @Syosse ok, try this then
      cat  ~/MagicMirror/installers/pm2_MagicMirror_new.json
      thanks so much!
        sdetweil @Syosse
        @Syosse and then if you do
        pm2 start  ~/MagicMirror/installers/pm2_MagicMirror_new.json
        if it works, then
        pm2 save
        then
        sudo reboot
          Syosse @sdetweil
          if it works, then
          pm2 save
          then
          sudo reboot
          Omg it works!!
          Oh man, what was the problem?
          Thanks soo much !!!
            sdetweil @Syosse
            @Syosse said in Magic Mirror logo appears at Boot and then the Raspberry desktop:
            the pm2 startup generated command fails when in a script suddenly
            but it works when done manually…
            I have issue open since May
            https://github.com/Unitech/pm2/issues/5582
              Syosse @sdetweil
              thanks man , unfortunately there is still a problem as soon as I enter the following commands it works and magic mirror starts but after reboot the desktop comes back
              with this command Magic Mirror starts
              after this command it still works
              pm2 save
              and after this reboot command the raspberry pi restarts and it shows the desktop instead Magic Mirror.
               sudo reboot
              thanks so much
                sdetweil @Syosse
                @Syosse did you execute the command output from first
                pm2 startup
                  Syosse @sdetweil
                  pm2 startup
                  yea of course:
                  Admin@magicmirror:~ $ pm2 startup
                  [PM2] Init System found: systemd
                  [PM2] To setup the Startup Script, copy/paste the following command:
                  sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u Admin --hp /home/Admin
                  thanks so much
                    sdetweil @Syosse
                    @Syosse and copy paste THAT command and execute it
                    sudo env…
                      @Syosse we got it working in chat
                        Syosse @sdetweil
                        Finally it works many many thanks to @sdetweil
                          sdetweil @Syosse
                          @Syosse and your troubles convinced me to look at the pm2 setup problem from the script, and I was able to see the issue and fix it for others…
                          thanks…
