    Magic Mirror logo appears at Boot and then the Raspberry desktop
    21 Posts 2 Posters 8.8k Views 2 Watching
      sdetweil @Syosse
      @Syosse can u also paste the contents of
      ~/MagicMirror/installers/pm2_setup.log
        Syosse @sdetweil
        @sdetweil said in Magic Mirror logo appears at Boot and then the Raspberry desktop:
        yea of course:
        Thanks so much!
          sdetweil @Syosse
          @Syosse ok, try this then
          cat  ~/MagicMirror/installers/pm2_MagicMirror_new.json
            Syosse @sdetweil
            thanks so much!
              sdetweil @Syosse
              @Syosse and then if you do
              pm2 start  ~/MagicMirror/installers/pm2_MagicMirror_new.json
              if it works, then
              pm2 save
              then
              sudo reboot
                Syosse @sdetweil
                if it works, then
                pm2 save
                then
                sudo reboot
                Omg it works!!
                Oh man, what was the problem?
                Thanks soo much !!!
                  sdetweil @Syosse
                  @Syosse said in Magic Mirror logo appears at Boot and then the Raspberry desktop:
                  the pm2 startup generated command fails when in a script suddenly
                  but it works when done manually…
                  I have issue open since May
                  https://github.com/Unitech/pm2/issues/5582
                    Syosse @sdetweil
                    thanks man , unfortunately there is still a problem as soon as I enter the following commands it works and magic mirror starts but after reboot the desktop comes back
                    with this command Magic Mirror starts
                    after this command it still works
                    pm2 save
                    and after this reboot command the raspberry pi restarts and it shows the desktop instead Magic Mirror.
                     sudo reboot
                    thanks so much
                      sdetweil @Syosse
                      @Syosse did you execute the command output from first
                      pm2 startup
                        Syosse @sdetweil
                        pm2 startup
                        yea of course:
                        Admin@magicmirror:~ $ pm2 startup
                        [PM2] Init System found: systemd
                        [PM2] To setup the Startup Script, copy/paste the following command:
                        sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u Admin --hp /home/Admin
                        thanks so much
                          sdetweil @Syosse
                          @Syosse and copy paste THAT command and execute it
                          sudo env…
                            @Syosse we got it working in chat
                              Syosse @sdetweil
                              Finally it works many many thanks to @sdetweil
                                sdetweil @Syosse
                                @Syosse and your troubles convinced me to look at the pm2 setup problem from the script, and I was able to see the issue and fix it for others…
                                thanks…
