    Magic Mirror logo appears at Boot and then the Raspberry desktop
    21 Posts 2 Posters 9.3k Views 2 Watching
      sdetweil @Syosse
      @Syosse if you used either of my scripts I download that file
      do
      ls ~/MagicMirror/installers -laF
        @sdetweil is Admin the root user, or the userid u created at SD card startup time?
        pm2 will run as user not root
          Syosse @sdetweil
          @sdetweil said in Magic Mirror logo appears at Boot and then the Raspberry desktop:
          Admin is the Credentials that i insert at the beginning of Install Raspberry Pi Imager:
          ls ~/MagicMirror/installers -laF:
          Thanks so much!
            sdetweil @Syosse
            @Syosse can you do
            cat  ~/MagicMirror/installers/pm2_MagicMirror.json
            thx
              sdetweil @Syosse
              @Syosse can u also paste the contents of
              ~/MagicMirror/installers/pm2_setup.log
                Syosse @sdetweil
                yea of course:
                Thanks so much!
                  sdetweil @Syosse
                  @Syosse ok, try this then
                  cat  ~/MagicMirror/installers/pm2_MagicMirror_new.json
                    Syosse @sdetweil
                    thanks so much!
                      sdetweil @Syosse
                      @Syosse and then if you do
                      pm2 start  ~/MagicMirror/installers/pm2_MagicMirror_new.json
                      if it works, then
                      pm2 save
                      then
                      sudo reboot
                        Syosse @sdetweil
                        if it works, then
                        pm2 save
                        then
                        sudo reboot
                        Omg it works!!
                        Oh man, what was the problem?
                        Thanks soo much !!!
                          sdetweil @Syosse
                          @Syosse said in Magic Mirror logo appears at Boot and then the Raspberry desktop:
                          the pm2 startup generated command fails when in a script suddenly
                          but it works when done manually…
                          I have issue open since May
                          https://github.com/Unitech/pm2/issues/5582
                            Syosse @sdetweil
                            thanks man , unfortunately there is still a problem as soon as I enter the following commands it works and magic mirror starts but after reboot the desktop comes back
                            with this command Magic Mirror starts
                            after this command it still works
                            pm2 save
                            and after this reboot command the raspberry pi restarts and it shows the desktop instead Magic Mirror.
                             sudo reboot
                            thanks so much
                              sdetweil @Syosse
                              @Syosse did you execute the command output from first
                              pm2 startup
                                Syosse @sdetweil
                                pm2 startup
                                yea of course:
                                Admin@magicmirror:~ $ pm2 startup
                                [PM2] Init System found: systemd
                                [PM2] To setup the Startup Script, copy/paste the following command:
                                sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u Admin --hp /home/Admin
                                thanks so much
                                  sdetweil @Syosse
                                  @Syosse and copy paste THAT command and execute it
                                  sudo env…
                                    @Syosse we got it working in chat
                                      Syosse @sdetweil
                                      Finally it works many many thanks to @sdetweil
                                        sdetweil @Syosse
                                        @Syosse and your troubles convinced me to look at the pm2 setup problem from the script, and I was able to see the issue and fix it for others…
                                        thanks…
