    Magic Mirror logo appears at Boot and then the Raspberry desktop
    21 Posts 2 Posters 9.3k Views 2 Watching
      Syosse @sdetweil
      @sdetweil said in Magic Mirror logo appears at Boot and then the Raspberry desktop:
      @Syosse can u also paste the contents of
      ~/MagicMirror/installers/pm2_setup.log
      yea of course:
      Thanks so much!
        sdetweil @Syosse
        @Syosse ok, try this then
        cat  ~/MagicMirror/installers/pm2_MagicMirror_new.json
          Syosse @sdetweil
          thanks so much!
            sdetweil @Syosse
            @Syosse and then if you do
            pm2 start  ~/MagicMirror/installers/pm2_MagicMirror_new.json
            if it works, then
            pm2 save
            then
            sudo reboot
              Syosse @sdetweil
              if it works, then
              pm2 save
              then
              sudo reboot
              Omg it works!!
              Oh man, what was the problem?
              Thanks soo much !!!
                sdetweil @Syosse
                @Syosse said in Magic Mirror logo appears at Boot and then the Raspberry desktop:
                the pm2 startup generated command fails when in a script suddenly
                but it works when done manually…
                I have issue open since May
                https://github.com/Unitech/pm2/issues/5582
                  Syosse @sdetweil
                  thanks man , unfortunately there is still a problem as soon as I enter the following commands it works and magic mirror starts but after reboot the desktop comes back
                  with this command Magic Mirror starts
                  after this command it still works
                  pm2 save
                  and after this reboot command the raspberry pi restarts and it shows the desktop instead Magic Mirror.
                   sudo reboot
                  thanks so much
                    sdetweil @Syosse
                    @Syosse did you execute the command output from first
                    pm2 startup
                      Syosse @sdetweil
                      pm2 startup
                      yea of course:
                      Admin@magicmirror:~ $ pm2 startup
                      [PM2] Init System found: systemd
                      [PM2] To setup the Startup Script, copy/paste the following command:
                      sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u Admin --hp /home/Admin
                      thanks so much
                        sdetweil @Syosse
                        @Syosse and copy paste THAT command and execute it
                        sudo env…
                          @Syosse we got it working in chat
                            Syosse @sdetweil
                            Finally it works many many thanks to @sdetweil
                              sdetweil @Syosse
                              @Syosse and your troubles convinced me to look at the pm2 setup problem from the script, and I was able to see the issue and fix it for others…
                              thanks…
