    Magic Mirror logo appears at Boot and then the Raspberry desktop
    21 Posts 2 Posters 9.4k Views 2 Watching
      @sdetweil is Admin the root user, or the userid u created at SD card startup time?
      pm2 will run as user not root
        Syosse @sdetweil
        @sdetweil said in Magic Mirror logo appears at Boot and then the Raspberry desktop:
        Admin is the Credentials that i insert at the beginning of Install Raspberry Pi Imager:
        ls ~/MagicMirror/installers -laF:
        Thanks so much!
          sdetweil @Syosse
          @Syosse can you do
          cat  ~/MagicMirror/installers/pm2_MagicMirror.json
          thx
            sdetweil @Syosse
            @Syosse can u also paste the contents of
            ~/MagicMirror/installers/pm2_setup.log
              Syosse @sdetweil
              yea of course:
              Thanks so much!
                sdetweil @Syosse
                @Syosse ok, try this then
                cat  ~/MagicMirror/installers/pm2_MagicMirror_new.json
                  Syosse @sdetweil
                  thanks so much!
                    sdetweil @Syosse
                    @Syosse and then if you do
                    pm2 start  ~/MagicMirror/installers/pm2_MagicMirror_new.json
                    if it works, then
                    pm2 save
                    then
                    sudo reboot
                      Syosse @sdetweil
                      if it works, then
                      pm2 save
                      then
                      sudo reboot
                      Omg it works!!
                      Oh man, what was the problem?
                      Thanks soo much !!!
                        sdetweil @Syosse
                        @Syosse said in Magic Mirror logo appears at Boot and then the Raspberry desktop:
                        the pm2 startup generated command fails when in a script suddenly
                        but it works when done manually…
                        I have issue open since May
                        https://github.com/Unitech/pm2/issues/5582
                          Syosse @sdetweil
                          thanks man , unfortunately there is still a problem as soon as I enter the following commands it works and magic mirror starts but after reboot the desktop comes back
                          with this command Magic Mirror starts
                          after this command it still works
                          pm2 save
                          and after this reboot command the raspberry pi restarts and it shows the desktop instead Magic Mirror.
                           sudo reboot
                          thanks so much
                            sdetweil @Syosse
                            @Syosse did you execute the command output from first
                            pm2 startup
                              Syosse @sdetweil
                              pm2 startup
                              yea of course:
                              Admin@magicmirror:~ $ pm2 startup
                              [PM2] Init System found: systemd
                              [PM2] To setup the Startup Script, copy/paste the following command:
                              sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u Admin --hp /home/Admin
                              thanks so much
                                sdetweil @Syosse
                                @Syosse and copy paste THAT command and execute it
                                sudo env…
                                  @Syosse we got it working in chat
                                    Syosse @sdetweil
                                    Finally it works many many thanks to @sdetweil
                                      sdetweil @Syosse
                                      @Syosse and your troubles convinced me to look at the pm2 setup problem from the script, and I was able to see the issue and fix it for others…
                                      thanks…
