    Magic Mirror logo appears at Boot and then the Raspberry desktop
    21 Posts 2 Posters 7.8k Views 2 Watching
      Syosse @sdetweil
      @sdetweil said in Magic Mirror logo appears at Boot and then the Raspberry desktop:
      @Syosse you don’t need to run all the commands
      the install asks if u want to turn off the screensaver. if you said yes, then it’s done
      if u said no then you would run the screensaver off script it’s the exact same script code. it’s just there if you changed your mind.
      now on to the pm2 thing
      same same. but
      in some systems the automation script has trouble
      do this
      pm2 startup
      it will output a command to execute
      copy/paste that command and hit enter
      when it’s done do
      pm2 start ~/MagicMirror/installers/pm2_MagicMirror.json
      pm2 save
      then reboot
      All right thanks for the Information with the Screensave, now its for me clear.
      I have done u Command but it shows me : [PM2][ERROR] Script not found: /home/Admin/up
      do u know why ?
      Thanyk so much!
        sdetweil @Syosse
        @Syosse if you used either of my scripts I download that file
        do
        ls ~/MagicMirror/installers -laF
          @sdetweil is Admin the root user, or the userid u created at SD card startup time?
          pm2 will run as user not root
            Syosse @sdetweil
            Admin is the Credentials that i insert at the beginning of Install Raspberry Pi Imager:
            ls ~/MagicMirror/installers -laF:
            Thanks so much!
              sdetweil @Syosse
              @Syosse can you do
              cat  ~/MagicMirror/installers/pm2_MagicMirror.json
              thx
                sdetweil @Syosse
                @Syosse can u also paste the contents of
                ~/MagicMirror/installers/pm2_setup.log
                  Syosse @sdetweil
                  yea of course:
                  Thanks so much!
                    sdetweil @Syosse
                    @Syosse ok, try this then
                    cat  ~/MagicMirror/installers/pm2_MagicMirror_new.json
                      Syosse @sdetweil
                      thanks so much!
                        sdetweil @Syosse
                        @Syosse and then if you do
                        pm2 start  ~/MagicMirror/installers/pm2_MagicMirror_new.json
                        if it works, then
                        pm2 save
                        then
                        sudo reboot
