    magicmirror lagging
    16 Posts 3 Posters 3.9k Views 3 Watching
    • 1 Offline
      1a2a3a
      my mm seems to be lagging after the recent update.
      on pi5 8 gb.
      any diagnostic i could check?
        sdetweil @1a2a3a
        @1a2a3a pi5 on the latest bookworm uses Wayland for its display manager.
        you can use the raspi-config app to set it back to X11…
        others have reported slower UI preformance
        also, we change the GPU setting to OFF by default, as this reduced unnecessary errors in most situations… as the drivers were not configured in the system either.
        you can enable it as s test
        add
        export ELECTRON_ENABLE_GPU=1
        to the script used to launch npm start
        before the npm start line
        1 1 Reply Last reply Reply Quote 0
        • 1 Offline
          1a2a3a @sdetweil
          @sdetweil it was working smoothly previously using the same pi. ill try to enable the gpu but where do i insert that line?
            sdetweil @1a2a3a
            @1a2a3a in the script used to launch MM
            if you are using my installer, and pm2 that is
            ~/MagicMirror/installers/mm.sh
            we changed electron versions too, and well, you never know
            • 1 Offline
              1a2a3a @sdetweil
              @sdetweil hmm not sure if its a placebo effect, but seems to be slightly better but still jerky, not sure. before the update, the marquee effect of ext3 and googlephoto transitioning was smooth. now its like uh… jerky transitioning…
                sdetweil @1a2a3a
                @1a2a3a and u restarted MM after changing the script…
                • 1 Offline
                  1a2a3a @sdetweil
                  @sdetweil yes i did, definitely…
                    sdetweil @1a2a3a
                    @1a2a3a can u look and see any new gpu related errors
                    pm2 logs --lines=50
                    • 1 Offline
                      1a2a3a @sdetweil
                      @sdetweil got this when i enter the command inside mm directory.
                      0|MagicMir |   source: undefined,
                      0|MagicMir |   lineno: undefined,
                      0|MagicMir |   colno: undefined
                      0|MagicMir | }
                      0|MagicMir | [11.01.2024 21:44.04.187] [ERROR] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AAJ1LKd3z4DnSUe5L1BE7e-FC_pskhLh8qgzww-omvYwOFtBiGVsKpqDYmvKZD0mxqWdY3fN1xmlcGXasptkJvlKlFku4fXyNJ_3sBeVfQr1FiqrLUBKfwL24EwZV4rEw69eSU9MapZBunE_Ey5NP8f00QRRpTp3epZkUmknUrFsMZEqtLeXICD_ekNaqEVF_E74TdBaLbdDC4e_jPzNiTKft13TD5YlyWFbcqmRFUCIlgTa4xov-PRt0MExDbZ6kKUMwzsG9RXN2J7h45K5YLKVafTzNkv0fkV-12keW9AZ3eBV7qaGfQOlMGQ-JcKqtwK0DEMizJfRjRfZHXxRLR-OWwXNuJ_otSKRWP5wQcExGkSxxypDt1oQihiRbBznDygTIFVFqYgQtk6rrD_po8MHsSyPYiQvwuvVqBzkpSc_1OJuMC5LYUL23lkQXx468oUDNmnTUQzjrM4KnSOXUV7vWnGpA4HMQIBq0tluQw-9-3nH97a_8X3AwZ4QllXWc9Xo6vaiItASDizjOx5REF7nrQ9sODXqbxgvQwaG4JJN12Mv_hQbMD4epKiLzIALs2wN1N-Z6U9VGNuikHrgJ-dg7dyMdj0uJL_vZthfX7CFwHZ8iNxLIOkeMW3lzDSTKpDJnSmFyXi289wVGnGZj-huCGXY4YbMHbdhLKPP8uSsOk6DYkWYkTn2VS8g9IKncvWkDvVt2ASQMrlZ2-1Eh2IuA-SE0gslF9_2Ck0u0ZtYk1V6Ea_5VvDAZbAn6rEfBFDJ6Q5945ngkG29NvkLm2fIiN_58Lb8DwDtD9lq7iIhkLRDI_eNfqIGN7DKEA3fjS2kxDPmS4-vtWgNe2K_l4iZJLSw2oQeaQNR-271qPLzg5cx39KhS0rDLiFqwNzYVWW2Inxj2T1VUkGAnn6GeY5Bj2DcnyeWcN0ry2qy5FpBKnEFq7DCPbViE2-RqU_zr7YiiUh9zUx2SBgubegJjC0_duDNdJQ2TReTfCMJ5thj6h-Ty-DeBTzOyEOHbhJLcwrPVP19Hru12RLrCIP-rQ4ijpSR8MJC=w1080-h1920
                      0|MagicMir | /home/hsa/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                      0|MagicMir | [2314:0111/215933.525635:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [2314:0111/215933.525875:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [2314:0111/215933.525982:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [2314:0111/215933.526092:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [2314:0111/215933.526216:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [2314:0111/215933.526332:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [2314:0111/215933.526438:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [2314:0111/215933.528604:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [2314:0111/215933.528735:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [2314:0111/215933.528835:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [2314:0111/215933.528930:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [2314:0111/215933.529025:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [2314:0111/215933.529123:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [2314:0111/215933.529221:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | Warning: vkCreateInstance: Found no drivers!
                      0|MagicMir | Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                      0|MagicMir |     at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                      0|MagicMir |     at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                      0|MagicMir |     at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                      0|MagicMir |     at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                      0|MagicMir |     at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                      0|MagicMir |
                      0|MagicMir | [4558:0111/220928.037273:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [4558:0111/220928.037465:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [4558:0111/220928.037555:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [4558:0111/220928.037643:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [4558:0111/220928.037720:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [4558:0111/220928.037801:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [4558:0111/220928.037880:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [4558:0111/220928.039683:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [4558:0111/220928.039825:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [4558:0111/220928.039920:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [4558:0111/220928.040015:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [4558:0111/220928.042133:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [4558:0111/220928.042266:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir | [4558:0111/220928.042352:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      0|MagicMir |
                        sdetweil @1a2a3a
                        @1a2a3a Oh such joy… not
                        • 1 Offline
                          1a2a3a @sdetweil
                          @sdetweil i remove gpu and it doesnt seems to have error.
                          so i ran npm start again seems to run fine but showing this
                          [6141:0111/221958.106148:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                          [6141:0111/221958.106492:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                          [6141:0111/221958.106652:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                          [6141:0111/221958.106803:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                          [6141:0111/221958.106975:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                          [6141:0111/221958.107162:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                          [6141:0111/221958.107343:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                          [6141:0111/221958.110017:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                          [6141:0111/221958.110444:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                          • 1 Offline
                            1a2a3a
                            so i assumed all is in good order ya? the reason for the supposed jerky lag is due to new mm version not playing well with pi 5 wayland?
                              sdetweil @1a2a3a
                              @1a2a3a electron not playing well with Wayland
                              we don’t know about either
                              I had another report that the wallpaper snow was jerky… thats all done in CSS
                              went back to X11 and it was fine
                              1 bheplerB 2 Replies Last reply Reply Quote 0
                              • 1 Offline
                                1a2a3a @sdetweil
                                @sdetweil ok boss. Will just leave it as it is and wait for a future update. Don’t think I’ll go back to x11 given the amount of time spent configuring wayland crontab to schedule on off :D
                                Thanks anyway!
                                • bheplerB Offline
                                  bhepler Module Developer @sdetweil
                                  @sdetweil - Do you think there would be any benefit to running the mirror in server only mode and using Chromium or Firefox in kiosk mode? It may succeed where Electron fails.
                                    sdetweil @bhepler
                                    @bhepler maybe. it’s a thing to try
                                    pm2 stop all
                                    npm run server
                                    and use your browser to localhost:mm_ip_port
                                    turning off the title bar etc is a task for the user!!!
                                    I have a setup to do this automatically using npm start if it works.
